Originally Posted by
ntsantos
Anyone have good DIY for this? I've seen the oil screen thread which has some good info (whitewhites7?).
Or maybe just some good pointers or lessons learned that aren't really apparent in the Audi manual or previous threads.
Thanks guys and please don't hate me if this seems like a "dead horse beating" topic.
Sent from my SM-G960U1 using
Audizine mobile app
WhiteWhiteS7's original thread is really all you need. It gets you all the way to the turbos, and has great pics and step by step instructions:
https://www.audizine.com/forum/showt...=oil+separator
In hindsight, having done it a few times (mine and a few cars of friends), things I wish I knew the first time around:
1) No need to take off the wheels in order to remove the front bumper. Simply turn the steering wheel all the way to the left to get to the bolts on the right, and turn the steering wheel all the way to the right to get to the bolts on the left.
2) Do yourself a favor and make sure you double/triple check all part numbers before starting. Totally sucks to find that you've been left hanging and can't finish the project because you're missing something.
3) Do yourself another favor and change out the oil separator to the newest 'E' version, and the oil return screen to the turbos to the newest 'G' version. At a minimum, make sure you change out the o-rings for all your
turbo lines, and to be extra safe, just swap out for new
turbo lines. They come with new o-rings on them.
4) The toughest part of the project is getting to the 6 bolts that hold the huge charge-air housing in place. You need to be able to tilt the entire 'lock-carrier' (the entire radiator housing in one unit) forward, so you can get to the bolts. No need to remove the crash bar for this, but do remove the large 16mm bolts (3 on each side) that hold the whole front lock-carrier to the long body rails.
5) If you have an AMS cooler installed, you will need to completely unbolt it's coolant tank on the passenger side in order to best tilt the lock-carrier forward.
6) You will need a very long and skinny 'size 5' Allen wrench to get to the front passenger side bolt in the top of the charge-air cooler housing. Only way you can get to it, as the opening is too narrow and too far away to get to it with anything more conventional.
7) Drain as much coolant as you can from the lowest point that you can. Cover all coolant lines that you detach with saran-wrap and rubber bands. This will prevent you getting coolant all over everything.
8) If you don't have one, immediately order an airlifter from Amazon to be able to vacuum fill your coolant when complete. Get new coolant. Your dealer has it in concentrated form, just mix either 1:1 or 1:2 with distilled water (either 50% or 33% coolant).
9) No need to undo the downpipe connections to the midpipe connections underneath the car. There is easily enough play to get the old turbos out and the new turbos in and attached to the downpipes.
10) If you don't have one, immediately order a hose clamp cable ploers. You will need one.
11) Lots of Oetiker clamps (ear clamps) need to be cut and tossed. To get the best fit, replace with new Oetiker clamps and use a good clamp tool to cinch them down.
12) While you're doing all this, good idea to swap out your spark plugs for the latest OEM version.
13) After mission complete, make sure you run your engine at idle for some time to allow both oil and coolant to circulate- you don't want to immediately drive it and stress the turbos that have completely empty oil and coolant lines.
14) If you want even more explicit instructions than WhiteWhiteS7's post, (although not necessary in my opinion, his post is fantastic), go to audi Erwin online and get a 1 day subscription for $35. Then download every pdf file that you can related to your car that day. Done. You now have all the shop manuals, with a how-to on pretty much everything you can think of, including
turbo replacement.
Some of these points may be obvious, but as a newbie-learning hobbyist, I learned some of these points the hard way.
