Results 1 to 17 of 17
    Mar 23 2019
    KS
    HELP - RS7 rough idle, no boost
    2017 RS7. Stock turbos, 25,000 miles. APR stage 1, catted Redstar DPs and SRM intakes. Had all of that for 10,000 miles or so. Regular oil changes obviously.
    Today was driving normally, and then turned one corner and hit the gas and noticed no boost. I was at my destination and didn’t have time to test it out much. I parked the car and noticed the idle was rough. 2 hours later left, car started fine, although idle was rough. Car drove ok but since it wasn’t warmed up I didn’t punch it and test the boost. 10 min highway drive taking it easy, no issues, and got off the highway and when I approached a stop the engine got very rough, drove 6 more blocks home and when I pulled into the garage the idle was the roughest yet by far.
    On the gentle 6 blocks home I gave it a little gas and could hear the turbo whirl but zero boost on the gauge. At home the idle was so rough that once in park the engine damn near stopped and like started itself back to life a couple times. I didn’t turn it off immediately just so I could get the video. And it smells horrible, far stronger than catless downpipes for example.
    See videos of engine bay, and you can almost hear better at the rear how rough the idle is. But you can see the engine moving.
    Zero check engine or other lights. I have a simple OBD code reader and no codes.
    By default I’m obviously most worried about turbo failure… Are the turbos the culprit? Boost leak? Neither of those would explain the rough idle or shutting off while coasting though right? Spark plug? Ignition coil? I am absolutely not a mechanic. The dealership and good shops around me have a months-long wait to get in, which is frustrating obviously, but I’m dying inside to at least have an idea of what it is.
    Edit: trying to figure out how to add videos
    Mar 23 2019
    KS
    - - - Updated - - -
    - - - Updated - - -
    Apr 24 2017
    Kansas City
    Chicane in Olathe is a trusted shop with the KC Audi group.
    Most people seem to have luck getting in with them quickly
    16' A8L Sport 4.0L V8TT
    05' S4 6MT Moro Blue - Sold
    01' A4 5MT 3.2L - Sold
    Senior Member Two Rings rabbitdog's Avatar
    Aug 03 2018
    Ontario
    I see your passenger side wastegate actuator seems to be moving it in your second video. Mine doesn’t do that.
    Senior Member Three Rings GlacierS5's Avatar
    Jul 27 2017
    San Jose, CA.
    Damn! Pull the SRM inlets off and check for any shaft play.
    Sent from my SM-G975U using Audizine mobile app
    2018 Glacier White S5 | Prestige | Sports Pkg | Dynamic Steering | Carbon Fiber Pkg | 034 Motorsports Parts
    2016 Sepang Blue RS7 | Prestige | SRM Intake |EuroCode Sways
    2014 Glacier White S6 - SOLD
    Veteran Member Four Rings VinnysS4's Avatar
    Nov 12 2015
    2004 s4 Avant, 2005.5 S4 Manual swapped, 2002 A4 3.0 6 speed, 2004 A4 1.8 5 speed
    Oregon
    +1 for turbo inspection. If the oil feed screen hasn't been taken out/care of... that's 5 years on the screen.
    That being said, the wastegates bouncing like that looks more like a vacuum iissue.has the pcv been taken care of?
    Sent from my SM-N960U1 using Tapatalk
    1997 VW GTI VR6 (sold), 2003 Audi RS6 (sold), 2010 Audi A4 2.0T (RIP Totaled on 11/2/2015 ) 2005.5 Audi S42011 Dieselgate Q7 TDI..... patiently waiting for my warranty to expire!!
    My build log
    "Everyone is An expert when they make their own category."
    Mar 23 2019
    KS
    Thanks for the replies.
    No on the PCV… I don’t think my car was eligible for the service covered by Audi.
    I’m just curious if folks here think a boost leak or wastegate problem would cause such a rough idle? I have very little knowledge of this stuff if I’m being honest.
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    My guess is turbos and metal is in the engine. Real bad move to run the engine without inspection.
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
    Nov 12 2015
    Oregon
    Quote Originally Posted by zabds319 View Post
    I’m just curious if folks here think a boost leak or wastegate problem would cause such a rough idle? Audizine Forum
    No and no
    My build log
    Junior Member Two Rings
    Dec 29 2015
    willmar mn
    Any update? Just started having this same problem yesterday. I'm at 41k so need to do plugs and hopefully that is it!
    Mar 23 2019
    KS
    Quote Originally Posted by edg71908 View Post
    Turbos. Actually just the passenger side turbo. The shop is confident there's no other damage so hopefully they're right and I should be good once I get the turbos replaced... but I guess there's always a chance there could be some issue not yet seen, so I was holding off on updating until I have it back and running smoothly. I'll post some pictures eventually. Pretty sad at 25,000 miles for a $150,000 car in my opinion (regardless of a tune).
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    The recent turbo warranty extension may not help you, but it is surprising that an RS turbo failed like this.
    Mar 23 2019
    KS
    Quote Originally Posted by Alabama View Post
    Agreed. Curious to see what the oil screen looks like
    Nov 12 2015
    Oregon
    25k miles is ridiculous low mileage for failure too
    My build log
    Mar 23 2019
    KS
    Public service announcements: remove or replace your oil screens!
    5000 mile oil changes is not enough. This is my screen at 25k with 5k changes.
    Mar 23 2019
    KS
    And here’s the passenger turbo. The shaft is snapped and can hardly even spin, which I’m told explains the rough idle.
    Engine was fine. Interestingly the driver side turbo is pristine with no shaft play.
    Do these turbos have any value? I obviously have no use for them.
    I went SRM +4mm and with my SRM intake and Redstar downpipes I’ll be doing DS1 stage 3 unless someone talks me out of it.
    Sep 09 2019
    2012 Acura MDX
    Michigan
    First, sorry that really sucks; second, way to make lemonade.
    Yes, you should be able to recover a good chunk from your stock turbos! For the least hassle you can sell them as-is and let someone else rebuild one/both, or for a little more work have the bad one rebuilt to stock and sell them as a stock pair. I guess you could rebuild the bad one to +4mm and sell them separately, but that may take longer (?) Having them both rebuilt to +4mm may be another option, as you could get more from the +4mm pair, but you'll have to do that tradeoff with real numbers or maybe someone smarter than me already knows. But you definitely have options. New RS+ turbos go for what, $1700 new, people are asking $1500 refurbished.
    DS1 is a no-brainer IMO. I've barely scratched the surface of the tuning capability, incredible support and user community. I just flashed the DS1 OTS Stg 3 S6 tune over APR stage 3, and besides just getting a lot stronger tune now I get to learn how to do it myself, by starting with a proven map and making slight adjustments in a safe environment.
