Been having a few issue with the car lately and I bought a Ross Tech V2 cable and ran the diags. But I am having trouble reading the results. Will someone be able to help me clear some things so I can start fixing them. Thanks in advance. I am having issues with the battery and alternator that I keep needing to jump my car. I also had an issue with the fans kicking on while the car was off (it was water in the ECM box). I already dried out the box and replaced the relays that were damaged by the water. But i think the car now is having trouble charging up the battery from it being drained by the fans kicking on before. I am also having issues with the ESP light on and before I had the EPC. Any help will be great.
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: Mileage: 300560km-186759miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8E0 910 115 B HW: 8E0 907 115 C
Component: 2.0l R4/4V TFSI 0140
Revision: --H02--- Serial number:
Coding: 010C010A180F0120
Shop #: WSC 02301 444 54128
VCID: 2019E289F6CDAE67BE5-8075
4 Faults Found:
008504 - Accelerator Position Sensors (G79) / (G185)
P2138 - 008 - Implausible Correlation - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 300510 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 98.0∞C
Temperature: 73.0∞C
Absolute Pres.: 1000.0 mbar
Voltage: 11.938 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0∞C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
001672 - ECM Power Relay Load Circuit
P0688 - 004 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 300564 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 26.0∞C
Temperature: 19.0∞C
Voltage: 0.000 V
001669 - ECM Power Relay Control Circuit
P0685 - 004 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 300564 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 26.0∞C
Temperature: 19.0∞C
Voltage: 0.000 V
Readiness: 0000 0101
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 C HW: 8E0 614 517 BB
Component: ESP8 quattro H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004526
Shop #: WSC 06325 000 00000
VCID: 270BF99593E3595FFFF-8073
3 Faults Found:
00493 - ESP-Sensor Unit (G419)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 13
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x00FF
Hex Value: 0xFFAE
Hex Value: 0x00FF
01314 - Engine Control Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 39
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0722
Hex Value: 0x00FF
Hex Value: 0xFF91
Hex Value: 0x00FF
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 14
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x00FF
Hex Value: 0xFFAD
Hex Value: 0x00FF
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AL
Component: A4 Klimaautomat 2728
Coding: 00000
Shop #: WSC 22011
VCID: 6B83C5A54A9BBD3F5B7-5161
3 Faults Found:
01272 - Positioning Motor for Central Flap (V70)
41-10 - Blocked or No Voltage - Intermittent
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0304
Coding: 10031
Shop #: WSC 06325
VCID: 3B2335E57A7BEDBF8B7-4B01
5 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
30-00 - Open or Short to Plus
01498 - Bulb for Parking Lamps; Right (M3)
01504 - Bulb for License-Plate Light (X)
01800 - Light Switch (E1)
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036N0002BTV
Coding: 0032607
VCID: 3C2136F97A65EA8782D-8069
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 02 0070
Serial number: 6332DRB401164B18F
Coding: 00032607
Subsystem 2 - Serial number: 6342DRB40112C627F
Subsystem 3 - Serial number: 6352ARB4003CDC21P
Subsystem 4 - Serial number: 6362ARB4003CE62BV
Subsystem 5 - Serial number: 63729RB4003986E4R
Subsystem 6 - Serial number: 63829RB40039850DM
1 Fault Found:
02511 - Control Module for Seat Occupied Recognition (J706)
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenks·ulenmodul 0601
Coding: 02042
Shop #: WSC 06325
VCID: 41DF470D1897876FD1B-4B01
1 Fault Found:
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 N HW: 8E0 920 981 N
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0023259
Shop #: WSC 02301 444 14849
VCID: 38292AE94E4DC6A7665-5185
2 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
004 - No Signal/Communication - Intermittent
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023259
2 Faults Found:
End----------(Elapsed Time: 05:43, VBatt start/end: 13.6V/13.7V)-----------
