Results 1 to 8 of 8
    Jul 08 2017
    Midwest USA
    Ride height increase after new tires ???
    I recently changed tires on my 2017 Audi A4 with sport suspension. After picking up the car it was noticeably higher. Higher off the ground, higher off the top of the tire. The tire diameter is exactly the same as the tires I replaced. Tire size is the same.
    Is there anything the shop could have done to the suspension to make it sit up a half inch higher? They say they didn’t change anything. I know for a fact it is sitting higher and has more wheel gap now. Thanks.
    May 12 2017
    needs cleaned
    Land of Archaic Anachronisms
    Quote Originally Posted by mward View Post
    V strange.....
    all four corners now have a greater gap?
    you say tires are the same size..... are they the same brand & model?
    there will be variation from brand-to-brand & model-to-model.... even when they are labeled the same....
    Billy
    2011 A5 2.0T Old Man Project
    1983 Porsche 944 (Modified)
    1971 Moto Guzzi Elderodo
    Avatar Chart
    Jul 08 2017
    Midwest USA
    Quote Originally Posted by wkhanna View Post
    V strange.....
    Same size tires. Different brand. I went from OEM to Michelin AS3+. The ride height change has the car clearing the ground more and clearing the tops of the tires more. The top of the wheel well is at 27.25”. It should be below 27”.
    May 12 2017
    needs cleaned
    what is the tyre size?
    Billy
    Avatar Chart
    May 12 2017
    needs cleaned
    look under the 'specs' for your tyre size in the "Overall Diameter" column .
    then compare to the spec for the OEM...
    https://www.tirerack.com/tires/tires...74VR0PSAS3XLN0
    Billy
    Avatar Chart
    Nov 06 2018
    Anaheim, Ca
    is the car still the same? sometimes when the suspesion is allowed to go full droop on the lift it may take time to settle a bit.
    visit http://www.mgcsuspensions.com suspension parts for Porsche Audi Volkswagen BMW.
    Established Member Two Rings Ripp3d_'s Avatar
    Apr 02 2015
    Nyc
    Quote Originally Posted by MGCSuspensions View Post
    This. It has happened to me with many vehicles i’ve owned numerous times
    Jul 08 2017
    Midwest USA
    It has settled about 1/8”. I had it checked again and there doesn’t seem to be anything out of wack. The new tires are adding some height with the new treads. I pick up on minor changes like that pretty easily and it drives me crazy. Most people probably wouldn’t even notice a difference.
