Results 1 to 40 of 73
    Feb 09 2013
    WNY
    Unable To Clear Central Locking Module Memory
    2000 Audi A4 1.8T Quattro 5MT
    No auto scans yet.
    I've been having issues trying to program the key fob. It is an eBay 3 button key fob. The car only came with the valet key. The key fob did work initially and was able to successfully program it to the car, this was around March shortly after purchasing the car. Been having issues ever since the trunk area where the module sits got flooded due to a disconnected sunroof drain hose (car is parked outside). I did my best to dry it out and clean the corrosion off the board and the connector housings. I don't know how long it was underwater for. Fast forward to last night and I installed a CLM from the junkyard. The part number of the new module is the same as the old one (8L0 862 257 N). I also grabbed the pigtails and connectors from the car in the junkyard, but have not replaced them yet.
    With the new CLM installed, I changed the soft coding to what it was on the old CLM (also changed the WSC if it matters). I've been trying to program the fob to the new CLM and been unable to do it using the following procedure:
    When I do the initial part of the procedure the car gives no confirmation of any button presses and the door does not unlock with the fob. I have also tried to clear the CLM memory using Adaptation Channel 00. It says that it's saved successfully, but when I go to measuring blocks, group 003 it shows memory positions at 1111 (memory full, 4 fobs programmed).
    I’ve checked the fob battery, it’s good (3.2v).
    Also tried the output tests via VCDS and they’re all successful...
    The new CLM didn't have any fault codes stored during all this either.
    I don’t think the key fob is bad or anything because it was working fine before the CLM got flooded. I think my issue is with the full key fob memory positions.
    With the weather getting colder here in Upstate NY, I have been having issues with the battery going flat while sitting outside. But during the above work, I had the battery hooked up to a charger with the car parked in the garage. I will be replacing the battery once it comes in at the dealer.
    Sep 16 2010
    Central Wash
    Wish I had a good answer for you. I ran into the exact same problem on a 99’ A6 I owned a few years ago.
    After being perfectly fine and working great for years it suddenly wouldn’t program new remotes, It also decided to permanently assign seat memory to the drivers seat. I was never able to program new ones or even erase the saved ones.
    I never did figure it out. It had no flooding or any other real problems, and replacing the CLM didn’t fix it.
    Feb 09 2013
    WNY
    Interesting. At least with my situation this all started after the flooding.
    Dug into it a little more tonight and found the shielding wire for the antenna was broken. There’s a section where it’s has no insulation and that’s right where it broke from corrosion.
    The black wire is the shielding that then goes around the clear jacketed wire. The shielding is pin 7 of the black 12 pin connector.
    So I figured between the corrosion on the pins and the broken wire, that HAD to be my problem. I went ahead and spliced in the new pigtail and connector. The other two connectors looked fine so I left them alone for now.
    Plugged in the “new” CLM and still couldn’t get the memory to clear or key fob to be recognized through any programming procedure. For poops and giggles I swapped back to the old one that I tried cleaning with deoxit. That didn’t work either. Both CLMs would not clear key fob memory. For what it’s worth the old one had 1 slot (0001 in field 2 of Measuring block 003) taken... which makes sense because I only had one remote programmed before this all started. The new CLM has all 4 slots (1111) taken. I couldn’t even get the remote to program in any of the unused slots on the old CLM. Both CLM’s successfully went through the output tests with VCDS as well.
    Ran an auto scan, will post that later.
    Needless to say I’m a little frustrated after messing around with splicing in the new connector. At this point I’m ready to just live without the key fob... but I just hate not knowing why it’s not fixed.
    Nov 13 2009
    Victoria, B.C., Canada
    Do you have a second key? If not, know anyone who is a machinist? I had my brother in law cut a couple from a picture he took of the key and loaded it into Solid Works. Worked beautifully. With two keys, you can do it the non VCDS way which is what I did.
    Doug
    Feb 09 2013
    WNY
    Quote Originally Posted by Cybersombosis View Post
    Doug
    I do have a second key, it’s a valet/mechanic key. Whatever you call it.
    I tried clearing the memory with the key method before I fixed the antenna wire, so I’ll have to give that a try.
    Veteran Member Four Rings RENOxDECEPTION's Avatar
    Nov 04 2012
    2000 B5 A4 1.8TQM, 2000 B5 A4 1.8TQM
    Reno
    eBay three button for a car with a two button...I would call that a conflict of interest but I was able to program an eBay 3 button for my 2000 sedan.
    Ugh I’m going to have this issue with my 98. Stole the button for the panic off the key fob pcb because I never planned on getting the car running, and accidentally lost the tiniest resistor/diode SMD off of it.
    Do you still have the old pump?
    Rollerton probably knows where I’m going with this based on the other thread he participated in.
    2000 Audi A4 B5 1.8TQM AEB/06A
    1998 Audi A4 B5 4.2QM (Thread)
    2000 Audi A4 B5 1.8TQM K24 Turbo, AEB Wideband
    Feb 09 2013
    WNY
    Quote Originally Posted by RENOxDECEPTION View Post
    Yeah, the car never came with a fob so I wasn’t sure which style fob it took.
    I still have the old pump
    Active Member Two Rings Estarossa's Avatar
    Nov 02 2017
    Hyattsville MD
    I’ve been having the same issue with my 01’ sedan...... 🤦🏽*♂️
    Feb 09 2013
    WNY
    One thing that I’ve noticed is that locking the driver door with the key blade doesn’t arm the alarm. The red light doesn’t blink. I’m not sure if that’s related to my issue. I do remember that the alarm would set when locking the car back when I first starting having issues with the key fob. So idk what happened between then and now.
    Maybe there’s an issue with the micro switch the door latch module?
    Veteran Member Three Rings PringlesInVic's Avatar
    Oct 31 2015
    '05 Touareg V8, '11 MkVI Jetta TDI
    Victoria, BC
    Quote Originally Posted by fR3ZNO View Post
    This might be your problem. I had a bad door switch on the rear driver side, couldn’t tell under the little rubber boot but it was broken. So my alarm never armed when I locked the doors with the key in the lock. Once I fixed the door switch, alarm started arming.
    Do your front foot well lights come on when you open the front doors? What about the back courtesy lights when doors open?
    SOLD - '98.5 A4 1.8TQM - Aluminum Silver Metalic
    REVO Stage 1 - BW K04 - CTS Test Pipe - Milltek Exhaust - ST Coilovers - Hyperboost DV - ECS Snub - TFSI Coils/ICM Delete - eBay SS - Valeo SFW - DEPO Ecodes - 18" BBS Reps - OEM RS4 Grille - Alpine/Hertz Stereo - PODI Boost Gauge + POD
    Build Thread HERE
    Feb 09 2013
    WNY
    Quote Originally Posted by PringlesInVic View Post
    I thought the footwell lights did come on. I’ll have to check.
    Feb 09 2013
    WNY
    Just to bump this, noticed yesterday that the footwell and interior lights do come on when opening the driver's door. Also, when locking the door with the key, only the driver's door locks. None of the other doors lock. Only way to get the other doors to lock is with the interior lock button.
    Feb 09 2013
    WNY
    Here's an auto scan:
    Code:
    Tuesday,20,November,2018,21:34:12:22664
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 18.2.0.3 (x64)
    Data version: 20180212 DS287.0
    www.Ross-Tech.com
    Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2002)
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    Address 01: Engine        Labels: 058-906-018-ATW.lbl
       Part No: 4B0 906 018 P
       Component: 1.8L R4/5VT     G   0006
       Coding: 07201
       Shop #: WSC 06335
       VCID: 2E53E2A5EA4FCD34BA-5140
    4 Faults Found:
    18014 - Rough Road/Engine Torque Signal from ABS
                P1606 - 35-10 - Electrical Malfunction - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
                P0300 - 35-10 -  - Intermittent
    16687 - Cylinder 3
                P0303 - 35-10 - Misfire Detected - Intermittent
    18010 - Power Supply Terminal 30
                P1602 - 35-10 - Voltage too Low - Intermittent
    Readiness: 0010 0001
    Address 08: Auto HVAC        Labels: 8D0-820-043-1D.lbl
       Part No: 8D0 820 043 P
       Component: A4     KLIMAAUTOMAT D56
       Coding: 00140
       Shop #: WSC 06335
       VCID: 2D51E5A9E749B62C83-2594
    2 Faults Found:
    00779 - Outside Air Temp Sensor (G17)
                30-00 - Open or Short to Plus
    01206 - Signal for Duration of Ignition Off Time
                27-10 - Implausible Signal - Intermittent
    Address 15: Airbags        Labels: 8D0-959-655-AI8.lbl
       Part No: 8D0 959 655 K
       Component: Airbag Front+Seite 1002
       Coding: 00104
       Shop #: WSC 06335
       VCID: 3E73D2E53A2F3DB42A-515C
    1 Fault Found:
    00532 - Supply Voltage B+
                07-10 - Signal too Low - Intermittent
    Address 17: Instruments        Labels: 8D0-920-xxx-17.lbl
       Part No: 8D0 920 980 C
       Component: B5-KOMBIINSTR. VDO D09
       Coding: 02244
       Shop #: WSC 00000
       VCID: 2B55EBB1D95DB81C9D-5140
    No fault code found.
    Address 35: Centr. Locks        Labels:. 8D0-862-257.lbl
       Part No: 8L0 862 257 N
       Component: CV-Pump             D11
       Coding: 16204
       Shop #: WSC 06335
       VCID: 408FAC1D40DB4B4458-4EEA
    Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
       Part No: 4B0 951 173
       Component: Innenraumueberw.    D03
       Coding: 00101
       Shop #: WSC 06335
       VCID: 60CF4C9DE01B2B4478-4B4E
    1 Fault Found:
    01382 - Alarm triggered by Anti-Theft Sensor; Front Left
                35-00 -  -
    Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
       Part No: 8D0 035 195 A
       Component:  Radio              D00
       Coding: 00201
       Shop #: WSC 00001
       VCID: 2447008DB48377645C-4B36
    End-------------------------(Elapsed Time: 04:10)--------------------------
    I believe the alarm code is an older stored code, because I haven't been able to arm the alarm as I mentioned...
    Nov 13 2009
    Have you tried the 2 key method and what were your results?
    Feb 09 2013
    WNY
    I have tried the 2 key method to program and clear memory and haven't gotten anything. When programming I get zero notification from car that it's been programmed (no light blink, horn honk, etc)
    Jun 30 2008
    Erie, Pennsylvania
    I am fairly certain the VCDS programming method does not apply to the B5. At least North American B5 A4's. VCDS can show you how many remotes are programmed and that's about it. You must add keys using the 2-key dance. (Oddly, B5 Passats are a completely different story.)
    For the 2-key dance to work, it is critical that the microswitches in the driver's door lock cylinder are all working perfectly and all those signals are successfully getting to the CLM. In VCDS measuring blocks, I would test that the cylinder positions and all status bits are responding correctly. Especially those for the driver's door. I think it is not uncommon for these microswitches (or perhaps the wires in the door) to fail. A friend of mine was trying for hours to program a B5 Passat fob. With VCDS I was able to see the drivers cylinder microswitch was not responding and thus not allowing the manual program. Luckily there's a "Plan B" on the Passat: you can program with VCDS instead. This workaround is not available on the A4 as far as I know, so everything has to work.
    Also make sure the part number / frequency / FCC ID of your fob is correct for a North American B5. Lots of European fobs end up on 'Murican ebay and they operate on a different band.
    Myself, I program stubborn remotes by just force-loading the CLM EEPROM using a homemade in-line adapter cable, an Arduino and a Super NES controller. << j/k, but wouldn't I be so cool?
    Feb 09 2013
    WNY
    Thanks for your input, Walky.
    I didn't suspect an issue with the micro switch for the driver's door since the interior lights come on when opening that door. However, I will definitely double check and see what bits are showing in VCDS, perhaps there's an issue with the lock cylinder.
    and yeah, you don't directly program the keys with VCDS on a B5 A4. By programming with VCDS, I meant that I use it to help show what's going on during the procedure. I have programmed keys on my B6 A4 and B5.5 Passats before and they are definitely different in that it can be done completely with VCDS and no "dance" required. lol. However, they have completely different CCM's from the B5 A4, etc.
    lol, a friend of mine suggested removing and soldering the EEPROM from my old CLM to the new one. But that does sound way cooler.
    Jun 30 2008
    Erie, Pennsylvania
    Yep, it's just Up-Down-Up-Down-Left-Right-A-B-A-B, then key in the remote ID in binary (X for Zero, Y for 1), hold L+R to burn the ROM and presto!
    Feb 09 2013
    WNY
    BRB trying that
    Jun 30 2008
    Erie, Pennsylvania
    Veteran Member Four Rings Joe Jr.'s Avatar
    Mar 09 2017
    Longmont, CO
    tagging this. i need to program some fobs soon also.
    Need another!
    Veteran Member Four Rings Mattr567's Avatar
    Mar 20 2016
    1989 Honda CB-1, 1986 Suzuki SP200
    I did the two key program after I had to replace my locking pump since the original got flooded, worked perfectly with the junkyard pump.
    I have 3 keys total: 2 fobs and a normal one
    FWD in the tradition of AutoUnion
    99.0 B5 A4 1.8TMS
    I turned a $750 car into a $10,000 car worth $2500
    Feb 09 2013
    WNY
    Quote Originally Posted by Joe Jr. View Post
    Hopefully you don’t have the issues I’m having lol
    Quote Originally Posted by Mattr567 View Post
    Yeah, I think there’s something else going on that’s not the CLM.
    Nov 13 2009
    Hey Matt. Can you confirm if there were any beeps or flashing lights when you programmed yours. I don’t recall mine doing anything when I reprogrammed my fobs.
    Doug
    PS. All you are missing is the plastic emergency key you get when new
    Mar 20 2016
    Doug
    I don't remember, but maybe some flashing? Kinda in the same boat as you. 99.0 fyi.
    The whole key is plastic? Damn never seen that!
    99.0 B5 A4 1.8TMS
    Oct 31 2015
    Victoria, BC
    I got lights flashing when I cleared my codes, and programmed the fob. But no horn.
    Build Thread HERE
    Feb 09 2013
    WNY
    This is what I recall it doing as well when I was able to program the fobs. Lights but no horn.
    Nov 13 2009
    I keep mine in my wallet just in case.
    Doug
    Nov 13 2009
    Sounds like there is a wire in the door loom that is broken. Pull back the accordion looking thing in the door jamb and inspect.
    Feb 09 2013
    WNY
    Will do
    Jun 30 2008
    Erie, Pennsylvania
    Ding Ding Ding. I'll take Lock Cylinder Microswitch Signals for $1000, Alex.
    Feb 09 2013
    WNY
    I'll check it out and see, I just find it strange that it managed to stop working right around the same time the CLM flooded. So who knows at this point. Hence why I didn't really suspect the microswitches.
    Nov 13 2009
    One is not related to the other. The fob controls the pump which in turn locks the doors. The switch in the lock is used to tell the pump to lock/unlock and to program the CLM. It’s probably been out for a while. Unless you lock your doors with your key and noticed your other doors not locking you wouldn’t be able to tell it wasn’t working because you would have used your fob all this time.
    Feb 09 2013
    WNY
    Well yeah, I'm aware they're separate things. Just the order of failure was strange to me. So yes, the switch likely stopped working sometime between A) having a functioning key fob and B) not being able to program the keys after swapping the CLM.
    Oct 31 2015
    Victoria, BC
    Hmm...
    I know you said that the battery was tired, but you were charging it. However I'm wondering if the locking issue may be caused but he weak battery. When it got cold here a couple weeks ago (read cold for here) my CLM failed to open the secondary doors, it would only unlock the driver door. Even the interior lock switches wouldn't work to operate the doors. This was a huge PITA when you're trying to load your toddler into the car and have to run to the other side to unlock the door fro the inside.
    Anyway, I charged up the battery overnight and the next day everything worked as it should. And has since. It may not help with the programming issue, but maybe the overall function. Maybe test it with your B6 battery?
    Build Thread HERE
    Feb 09 2013
    WNY
    Hmm...
    I was wondering that same thing myself. However, I did put a new battery in it this past weekend and it hasn't magically fixed itself yet. Although it has fixed the issue of needing to jump it all the time.
    Planning to work on the B5 a bit tonight... so I have few things to check and will report back.
    Feb 09 2013
    WNY
    Checked out the wires in the door rubber as suggested. Found two wires with frayed insulation... but no complete breaks as far as I could tell.
    Referring to the wiring diagram on post #3 the red w/ blue tracer wire is one of the door switch circuits. The other wire with what look to be chew marks is white w/ blue tracer goes to the instrument cluster?
    Also checked the microswitch signals with VCDS in measuring blocks 001 or 002, can't remember which one, but one of the fields had 4 bits under "rotary switch position" or something along those lines. I'm guessing that's the signal the CLM is looking for when you turn the key in the door lock cylinder, didn't see any of the corresponding bits change when turning the key in either direction.
    So now it's down to investigating the switch and repairing the wires...
    Nov 04 2012
    Reno
    Now you'll be noticing clean door grommet rubbers also.
    Jun 30 2008
    Erie, Pennsylvania
    I think that Red/Blue wire is just power to the interior lock/unlock switch on the door panel and the door warning / courtesy light.
    Feb 09 2013
    WNY
    If that’s the case, then both of those things work fine. Which make sense since it’s not a complete break. So, then the microswitch for the lock cylinder is bad, no?
