Part 1. Ordered and installed the Chinese, replica B&O type, raising tweeters, a 10" JL Audio 10TW3-D4 300W Subwoofer, XD300/1v2 300 Amp and AudioControl LC2i. These did improve the sound but only marginally, there where still many songs that did not play right, some frequenciencies and instruments did not sound properly to me, somebody else might love it but I am too picky. My mistake, believing you can really improve on the Bose Amp, it has so much roll off and variable equalization that I have to modulate the Sub's volume all the time.
Part 2. After using it for a while and realizing there would not be any adjustmens to make it sound really fine, I decided to bite the bullet and make a FULL AUDIO UPGRADE removing the Bose Amp. For this setup I would remove all speakers and Bose amp, replacing them with the following:
a. Nav.TV Zen-V interface. Good equipment, I recommend it.
b. TwK-D8 JL Audio Digital Signal Processor.
c. XD700/5v2 JL Audio 700W ,5 Channel Amplifier.
d. C5-653 JL Audio 3 way component sepakers set for the front.
e. C5-650 JL Audio 2 way component sepakers set for the back.
f. 10TW3-D4 JL Audio 10" Subwoofer.
But, the install was not well made, I let the not so professional installer, mount the front 6.5 Midwoofers into the Bose baffles, bad mistake. He also left the Chinese raising Tweeters installed just in case it would sound right after tuning. The sound certainly improved a lot from the Bose+Sub Upgrade, but still even after tuning the DSP, there where many songs that did not play right, some frequenciencies and instruments did not sound properly. The Mids where mounted on the stock location without some back acoustic reflection prevention. I also learned that, to me since I like a well defined front stage, a single 300W 10" TW3 Sub and 300W Amp is not enough for this car, the cabin and trunk are too large for it to handle.
Part 3. I checked all the theads I could find on the subject, reconsidered the options and decided to find a real professional installer. The System was upgraded as follows:
1. Add a second 10" Subwoofer to fill in the cabin, even at lower volumes.
2. Add two JL Amps, XD300/1v2 for the second sub and a XD200/2v2 for the rear speaker sets.
3. Install the C5 front tweeters, remove the Chinese B&O knock offs.
4. Separate the 3 way front speakers sets, the Tweeters and Mids use one channel that passes thru the passive crossovers, the MidWoofers get their own channel with crossover duties left to the TwK-D8 DSP.
5. Install the 4" Mids directly on the door panel, not the door itself, therefore separating it from the metal and allowing the installation of antireflective acoustic material behind them (SoundSkin rings backing).
6. Remove the P.O.S. Bose baffles on the front woofers, install the Audi OME covers on the holes and sound proof it all.
7. Install SoundSkin rings on all speakers.
This work took one week to complete with a real Proffesional once I had all the materials ready. I just got the car back yesterday and it now does sound great, all frequenciencies and instruments do sound properly. I know it will be good this time around since the system doesn't fall on it's face now when tested, there is no wishing it will fix deficiencies with tuning.
Now on to do some DSP tuning during thanksgiving weekend.
I also learned that, since I can not stop improving things until I am fully satisfied, I should have planned it better from the get go, I could have saved a few dollars and time. Since tuning my car is my hobby, I do not complain, I enjoyed the process but how could I have known the Sub upgrade would not be enough...?
