Page 2 of 2 FirstFirst 12
Results 41 to 64 of 64
  1. #41
    Established Member Two Rings jason bouchard's Avatar
    Jun 08 2008
    Quote Originally Posted by Darel View Post
    Not for a manual trans.
    Can be done, I've seen it but I'm working on finding out more info now
    2014 S5 6-Speed -dual pulley 187/57.5 ( PR 3.25) | Eurodyne Maestro tune| AWE coldfront HX | AWE coldfront upgraded reservoir | CF ECS tuning Intake pipe with K&N filter | JHM racepipes | ECS 2.5in Valved exhaust | SPEC stage 3+ clutch | Clutchmasters 23lbs AM singlemass flywheel | P3 Gauge w/ trackpack + analog boost sensor | 1 stage colder NGK plugs (BKR9EIX)
    2001 Audi TT 225Q (sold)
  2. #42
    Senior Member Three Rings Darel's Avatar
    Mar 27 2018
    Mountain Top, PA
    OK, I haven't had time to mess with this lately but I've narrowed down the problem to not the waist seal, but the small 5" or so vertical section of the window along the mirror (leading edge of the window). I admit I kind of neglected this short piece in the whole process so far. As soon as I can get out there to lube it up, I am hoping that will be the fix. Fingers crossed.
    '09 S5, 4.2 / 6MT / H&R springs & spacers, AWE Track exhaust
    '76 Triumph TR6
    '14 Mercedes E350
  3. #43
    Sep 02 2016
    Just be careful with silicone spray it will create fish eyes in your paint .
    Try this product form GM safe to use in weather stripping. Regular silicone has petroleum products and can eat away at the rubber . To avoid this with a spray spray on a rag first then apply .
    Genuine GM Fluid 12345579 Dielectric Silicone Grease*
    Sent from my SM-G950W using Audizine mobile app
  4. #44
    Mar 27 2018
    Mountain Top, PA
    OK, first off I'll say I was wrong about it being the vertical rubber channel, it's definitely the waist seal. There's the rubber lip, then under that there is a felt strip that actually wipes the glass. On my car this absorbs water and freezes to the glass all the way across.
    Couldn't find anything in the garage so I had to go get something. At the NAPA near my house about the only thing they had was "Silicone Lubricant Spray", Mac's 8300. It did specifically say it was good for rubber seals and weatherstrip so at least I know I'm not hurting anything.
    What I did to avoid getting this crap all over everything was take a putty knife and fold a scrap of rag over it. I then soaked the rag in silicone spray, holding it inside of a garbage can, then wiped it into the felt strip. I tried to really soak the felt strip good, but I will probably have to repeat this several times as I try to displace the water that's already soaked into the felt.
    Window up, window down, window up, clean. Lather, rinse, repeat until at least most of the streaking is gone.
    I initially was going to dry the felt out with my heat gun, but not knowing the temperature limitations of the felt, or the myriad hydrocarbon-based trims and rubbers surrounding it, I basically just blew it off quickly at low temperature.
    16 degrees this morning and both windows moved freely. However, I will qualify that by saying it was a clear morning with no frost or precip, so there wasn't really much to test it. However normally it would have been frozen.
    I'll update again on the first moist morning.
    '76 Triumph TR6
    '14 Mercedes E350
  5. #45
    Veteran Member Three Rings snocat17's Avatar
    May 12 2017
    2016 S5 Cab, 2016 Mazda CX-5, 2012 Ford F-250
    Steel City, USA
    Have you tried putting a small amount of vegetable oil on a paper towel and wiping along all rubber seals?
    -Joe
    2016 S5 Cabriolet Prestige Glacier White Metallic w/ brown comfort seats and piano wire black wood trim. RED Brake calipers holding EBC RedStuff pads, APR Carbonio Intake, ECS carbon fiber back-pipe, VCDS cable
  6. #46
    Mar 27 2018
    Mountain Top, PA
    No, it's really just this felt seal. I've already used weatherstripping lube all the way around the window. The glass doesn't stick anywhere other than the felt waist seal. Never heard of using veggie oil.
    '76 Triumph TR6
    '14 Mercedes E350
  7. #47
    Established Member Two Rings S5_SID's Avatar
    Apr 07 2018
    2011 S5 Quartz Gray Cab
    Orange County, CA
    Any updates on what has worked or not worked?
    Curious in the case I want to go to the mountains
    Keep Deep Sea Alive!
    Deep Sea Diver 🇺🇸
    2011 S5 Cabriolet • Quartz Gray Metallic • 3.0T •B&O•Sport Seats• Peelers•Carbon Inlays•Mods to come...
  8. #48
    Mar 27 2018
    Mountain Top, PA
    I definitely think the silicone above helped. It's been cold, and some nights of snow, light frost once, and no sticking. I am pretty sure this method will need a couple of re-applications but I really feel like I'm getting somewhere. No sticking in the last 2 weeks.
    '76 Triumph TR6
    '14 Mercedes E350
  9. #49
    Veteran Member Three Rings ColtS5's Avatar
    Aug 18 2013
    2022 Kia Telluride, 2024 Jeep Grand Cherokee, 2018 Porsche Cayman S
    Indianapolis
    Interesting thread. I had a left rear brake freeze to the rotor. We had rain all morning, temps were 38 degrees, then a quick drop to 15 degrees. The entire left side of the car was coated in ice, and when I tied to drive, the left wheel dragged in the parking lot. Dash lit up, and I feared the worse.
    Dumped some hot water on the wheel/brakes, and all was good. Had done a four wheel brake job with full brake flush, so this was odd.
  10. #50
    Mar 27 2018
    Mountain Top, PA
    Reminds me of that picture making the rounds on the interwebs last year of that Honda (I think) completely encased in ice parked at the shore.
    '76 Triumph TR6
    '14 Mercedes E350
  11. #51
    Mar 27 2018
    Mountain Top, PA
    Frozen yesterday morning. This is after 3 soaking applications of silicone. Looks like it's just something I'm going to have to live with, and keep a putty knife in the trunk. Seriously, I can't believe no one else is having this problem. It's so pervasive.
    '76 Triumph TR6
    '14 Mercedes E350
  12. #52
    Veteran Member Four Rings Neil F's Avatar
    Jan 13 2017
    marlton/nj/usa
    I assume you have searched for similar problems. It looks like there are others.
    audi a5 windows frozen site:www.a5oc.com
    audi a5 windows frozen site:www.audiworld.com
    audi a5 windows frozen site:www.audizine.com
  13. #53
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    I don't think the seals are necessarily the problem. It's not very humid here, but it is cold. With that said, I can have my windows freeze up on me, but it generally pretty rare. Over the last week I've had it happen twice, and in both cases I was still able to carefully get the door open. Even with the door open, the windows would not roll down even the slightest bit. So, in my case it seems the actual window is freezing in place, not freezing to the seal. There's no easy fix that I've found. To avoid breaking my windows I've just had to be very careful opening the door, very careful pulling it closed (it usually won't latch), and then giving it a tug after it's already mostly closed by not latched. In one or two instances I've actually had to drive with the door slightly ajar for a couple of blocks before the car heated up just enough for the windows to function again.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
  14. #54
    Mar 27 2018
    Mountain Top, PA
    It is both bitterly cold here and exceptionally humid, normally over 80%. Glad I'm not the only one. I don't even try closing the door with the window up, usually with the door open if I give it a quick shake grabbing the top of the window, that will free it up. If not the putty knife does it. Just kinda hoped there was a fix for it, it's not like Germany is exactly a tropical country that this sort of this shouldn't have been considered or addressed.
    '76 Triumph TR6
    '14 Mercedes E350
  15. #55
    Jul 17 2015
    Colorado
    Honestly, any car that unrolls the windows just a touch when you open the door seems to have this issue. So that pretty much covers cabs/verts and many (but not all) cars that don't have frames around the windows.
    If you do choose to close the door with the window still frozen, use caution.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
  16. #56
    Veteran Member Four Rings 03TLSinCO's Avatar
    Feb 02 2018
    '16 S5 Prem Plus; '13 Q5 Prem Plus S-Line; '09 Honda Odyssey (The Wife's, in the driveway)
    CO
    This situation sounds like the perfect excuse for a remote starter. Let the car warm up a bit before you need to open/close the doors.
    2016 S5 Prem+, Moonlight Blue Metallic/Lunar Silver, Sport Diff, Black Optic Plus, B&O, Adaptive Damping Suspension. 034 Stage 2 ECU/TCU, RS5 grill, AWE S-FLO Intake, 034 X-Brace, 034 Rear Sway Bar, CR-15, Magnaflow non-resonated X-Pipe
    2013 Q5 Prem Plus S-Line, Moonlight Blue Metallic, 034 Stage 1 ECU/TCU
  17. #57
    Mar 27 2018
    Mountain Top, PA
    Manual
    '76 Triumph TR6
    '14 Mercedes E350
  18. #58
    Jul 17 2015
    Colorado
    Quote Originally Posted by 03TLSinCO View Post
    Do a bit of poking around, and you'll find that remote start on these cars, while possible (ish), it's excessively difficult. As far as I know, there's no "out-of-the-box" method for doing this. I believe I've seen in the past where one person had it working, but their cost was well into the $5k range by the time they had it work. As far as I recall, they had some secondary issues that came up later due to the auto start. It was a long time ago and I'm feeling super lazy right now, otherwise I'd go search for the thread and link it.
    I remember discovering the remote start on our Tacoma was one of the biggest facepalm days of my life. We had owned the truck for probably close to a year before I discovered there was a remote start on it. The dealership had never advertised it, and I hardly ever drive the truck. One day I accidentally hit a button on the remote and the truck started a few seconds later. I thought I was crazy at first, but it turned out we had a pretty high end Viper remote start system on the truck. The installation was shoddy at best though, so my wife and I have rewired everything more appropriately. The poor installation was eventually causing batteries to brick themselves, because the required disable/kill switch was soldered by a fking toddler and it was shorting out.
    Manual
    There are ways to put an auto start on a manual these days, but naturally that includes putting something in place to keep it from attempting to start when it's not in neutral. So for most of us, that still wouldn't be an option since we've got decades of experience of leaving the car in gear to oppose whatever grade might be on the road. For me, I just can't trust an E-brake and always feel the need to leave my manual cars in 1 or R depending on the direction of incline.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
  19. #59
    May 12 2017
    Steel City, USA
    Try vegetable oil on the felt seal. Don't drench it, put some on a paper towel and gently wipe it.
    -Joe
  20. #60
    Feb 02 2018
    CO
    Manual
    Ah, yes, you've mentioned that before. I should have remembered.
  21. #61
    Veteran Member Four Rings Treeskier's Avatar
    Feb 06 2017
    RS6; SQ5; Q7; S2k; ROW D90
    Philly
    Quote Originally Posted by HazeMyth View Post
    Yup. I had a remote start in my manual WRX for 10+ years (it also had frame-less windows). It takes someone who really knows what they're doing to install it properly, but depending on the car there are a number of solutions. In Subaru's, the manuals used to have a "neutral wire" which allows the ECU to know when the car is in gear or not...so an install on these is fairly easy. For other cars, it involves (at least used to involve) a "shut down process" - basically a series of brake pedal presses or other buttons in a certain order to "arm" the system so it knows the car is in neutral and the remote start can be used.
    So, yes, a remote starter can be installed on a manual and yes, it's more complicated...but a good installer will know how to do it for sure.
    As for the Audi-specific complications, well, that's another set of challenges which I haven't tried to tackle yet, so can't comment...but it seems to have been addressed elsewhere.
  22. #62
    Dec 09 2019
    Chicago
    Started having this issue as well living in Toronto, Canada. Have you ever found a solution?
  23. #63
    Mar 27 2018
    Mountain Top, PA
    Just running my driver's license between the glass and the waist seal if it's icy out. That's about all you can do.
  24. #64
    Dec 09 2019
    Chicago
    Lol I’ll give that a try
    Right now I have my heat gun on standby 😂
