Results 1 to 21 of 21
    Jun 16 2011
    996tt
    MA
    Coolant Leak - Thermostat
    Hey guys,
    I have a coolant leak coming from the front of the motor. I was told it was the thermostat but I figure, if I am right there, might as well do the water pump as well!
    So, since Ill be doing those 2 things at a minimum. While in there is there anything else while the supercharger is off that I should take care of?
    PCV? Catch-Can?
    Garage:
    04 996tt, 06 Boxster S, 88 911 targa, 96 911 Convertible, 10 B8 S4
    Established Member Three Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Pcv 100% and coolant crossover pipe. Also if you have really bad carbon buildup you could get it cleaned. Also make sure you don't have any signs of sc intercooler leaks.
    Dual pulley e85 w/ TCU tune (EPL)
    Full custom exhaust (Catless)
    Jokerz ported blower
    Brembo BBK
    APR CPS cooling system
    USP intake
    034 front and rear sway bars Transmission inserts, cr 15 bar strut brace, density control arms
    Koni sport shocks with Eibach lowering springs
    VMR v804 Wrapped in PSS (255/19/35)
    Jun 16 2011
    996tt
    MA
    By crossover pipe you mean the front one that runs along the front of the motor?
    And I will check on my PCV. I believe the previous owner, a friend, had updated that system already once before... only 20k miles ago.
    Has anyone seen lower oil consumption post install of a oil catch can?
    Garage:
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by Gberg888 View Post
    This boi right here.
    https://www.shopdap.com/06e-121-045-ae.html
    Brembo BBK
    USP intake
    Established Member Three Rings Ford Prefect's Avatar
    Jan 20 2017
    2011 Silver S4, Mercedes Benz R350 ('07 & '11), Suzuki SV1000
    New Hampshire
    Quote Originally Posted by Morritse View Post
    Why would you replace that?
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by Ford Prefect View Post
    https://www.google.com/search?client...71.0vmxWfVQgls
    Brembo BBK
    USP intake
    Jan 20 2017
    New Hampshire
    Does t really answer my question, a lot of those links are other motors. First time I have ever seen a recommendation to change that pipe.
    May 08 2018
    Berkeley, CA
    I thought it was pretty well known that this was a fairly brittle piece of plastic and has been known to crack.
    Brembo BBK
    USP intake
    Senior Member Four Rings 14S4GWM's Avatar
    Mar 21 2015
    People crack it while working on the front end.
    May 12 2008
    I canít say Iíd for sure replace it, but Iíd definitely have one handy. On the other hand, I havenít seen it for $66 before and it would be worth it IMO.
    Jan 20 2017
    New Hampshire
    Yeah, I busted it and had to rig up the overflow tube. So Iím sure Iíll be due soon. Just never heard or proactive. Having one on had is def a good idea...
    Jun 16 2011
    996tt
    MA
    Ill grab that piece, a thermostat, water pump and, im gonna check the PCV before I order everything to see if I need to replace that.
    Ill have the carbon cleaning done and I wanna make sure the intercoolers in the SC arent going or leaking.
    I am debating on tackling part of things myself or having a shop do it...
    Garage:
    Jan 20 2017
    New Hampshire
    Itís kinda all or nothing for those 4 items. They are all within half a square foot of each other Once the SC is off. I think you can do it without service position but itís tight, especially when taking off the SC belt and getting the water pump pulley off.
    I had to remove the vacuum pump, be careful there. I inadvertently unscrewed some set screw and blew 3 liters of oil out of the car when I started it.
    Jun 16 2011
    996tt
    MA
    I just txted the previous owner and my buddy. He did the PCV and a Carbon Cleaning at 75k, car has 93k now. So I will check them both, but I dont expect to do them this time around.
    I will def replace the water pump and thermostat cause i dont know which is leaking, and I will def replace that front plastic pipe as well.
    Garage:
    May 08 2018
    Berkeley, CA
    The plastic pipe I'm referring to is actually down under the blower and sits right above the PCV
    Brembo BBK
    USP intake
    Jun 16 2011
    996tt
    MA
    I kinda thought it was that and not the front one but i cannot seem to find just that pipe on ECS.
    Is it this one:
    https://www.shopdap.com/make-model-y...121-065-n.html
    Garage:
    May 08 2018
    Berkeley, CA
    Is it this one:
    Yes
    Brembo BBK
    USP intake
    Jun 16 2011
    996tt
    MA
    Perfect Thanks!
    Garage:
    Jun 16 2011
    996tt
    MA
    Confirmed my leak is just the T-stat.
    Ill buy those pipes, the t-stat and, then maybe a new crank pulley and MercRacing HX. Get a few more ponies.
    Garage:
    Established Member Two Rings BucDan's Avatar
    Jul 19 2017
    San Diego, CA
    If it's the original waterpump, change it as well. Crossover pipe, tstat, water pump, pcv. All in one go. Maybe do super charger oil as well.
    Sent from my ZTE A2017U using Audizine mobile app
    Jun 16 2011
    996tt
    MA
    I may do the SC oil. Most of those other items have already been done before.
    PCV has been updated and changed
    Waterpump has been replaced
    Garage:
