Results 1 to 6 of 6
    Established Member Two Rings ava the a4's Avatar
    Mar 13 2018
    Newport News, Virginia
    Weird reverse shake
    Just went apr stage two and when i put it in reverse for the first few seconds i can hear something rattle or shake, anyone else experience this? Could it just be the downpipe rattling against the bottom of the car i was told it sat class to the underbelly when they did the install.
    Dec 12 2017
    Texas
    Shake/shudder or rattle?
    Mar 13 2018
    Quote Originally Posted by Phayl View Post
    Hmm, maybe a shudder, itís only for like half a second when you start backing up then it stops, and it never did that before i had the downpipe installed
    Dec 07 2016
    Long Island
    Do you have an aftermarket sway bar?
    I would check to make sure everything is tight.
    Sent from my SM-G935V using Tapatalk
    Dec 12 2017
    Texas
    Quote Originally Posted by ava the a4 View Post
    Make sure your heat shield isnít being pushed in onnthe midpipe. Thereís an external underside chassis support, and between that and the engine thereís another one. That heat shield can be pushed in by the midpipe and cause that issue. Had it with my DP install, had to bend the midpipe and pull back the heat shield a bit :)
    Mar 13 2018
    Thanks, iíll check
