Results 1 to 10 of 10
    Aug 16 2018
    wellfleet, ma
    Code p164e after oil change
    Received the following from the APR Mobile app shortly after an oil change:
    Code “p164e oil pressure regulating valve electrical malfunction”.
    Audi service manager said not to worry and they would look at it at the next service.
    2017 S6 with APR stage 1 & TCU.
    Any experiences or insight appreciated.
    Established Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    Quote Originally Posted by bturnbull View Post
    If you have a VAGCOM cable and VCDS cable (if you don't get one! You can get a 3VIN cable for $199 at Europaparts.com) clear the code and see if it comes back. Likely that the oil change may have tripped a sensor that needs to be reset.
    2016 S6, mythos black, RS7 turbos, MRC inlets |AWE touring exhaust| APR downpipes| Eventuri intake| AMS cooler| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights |Sound: Navtv Zen-v, Audiocontrol DM-810 DSP, JL HD900/5 driving JL10W3 sub and Focal KX3 up front. Rear; JL HD600/4 driving Focal KX2.
    Active Member One Ring RuckusX's Avatar
    Aug 13 2017
    Orange County CA
    I am having the exact same problem! Changed my oil and code came up, used vag-com cleared and was gone for about 5 miles and came back. I have tried to clear it numerous times and sometimes it comes back instantly. I can’t figure it out, but I did do the pcv oil cap test and it’s a lot of suction and engine starts idling up and down and wants to die. So maybe it’s the valve? I got no other codes except that and o2 code from apr downpipes since I have epl it’s not coded out.
    Oh btw I have a 2017 s6 18k miles on epl stage 2 with tcu tune.
    Mar 26 2010
    CA
    I would look into it. The 4.0T has a complex ECM controlled oil pressure system.
    From Audi Self-Study Program 920223
    Oil Pressure Regulation Valve N428 is switched by the ECM.
    Oil Pressure Switches F22 (high) and F378 (low) . There are two oil pressure switches above the oil filter. They monitor the two pressure stages.
    A third oil pressure switch, Level 3 F447, is installed for monitoring the oil pressure of the piston cooling jets.
    Piston Cooling Nozzle Control Valve N522 controls oil jets under the piston crowns.
    2016 S6 Sport, black optic
    Mar 26 2010
    CA
    Maybe check to see if the two oil pressure sensor connectors near the oil filter are seated properly.
    Aug 16 2018
    wellfleet, ma
    Thanks all for the replies and wwhan for the diagram. I will take the car into a local Audi guy next week to check the connections and report back.
    Aug 13 2017
    Orange County CA
    Keep me updated ... I have been hesitant to bring it in because I have intake, exhaust, heat exchanger, etc... hoping I would find a solution so I won’t have to. It’s not my daily so its just been sitting till I decide what I should do.
    Active Member One Ring youngsolodolo's Avatar
    Mar 11 2014
    Stamford, CT
    In because i got the same code earlier this week - hoping its nothing serious.
    Aug 13 2017
    Orange County CA
    Have you guys tried the oil cap test for the pcv valve? If there’s a lot of suction and engine start to bog like mine, then maybe bad pcv causing the error or vice vesa? Just a thought
    Aug 13 2017
    Orange County CA
    Any updates?
