The holidays are right around the corner, take advantage our Month-Long Black Friday Sale!
There will be a new sale every weekend on different JHM products. This weekends’ sale, enjoy 15% OFF ALL JHM Trans/Drivetrain products!
Be sure to use Promo Code: JHMBF2 at checkout! CLICK HERE!
Also check out our new JHM Chrome-Moly Forged Flywheels available now! CLICK HERE!
The Chrome-Molly Forging allows fewer opportunities for failure and promotes uniform, efficient heat transfer from the clutch disc. This is to prevent warped friction inserts or loose ring gears. It is strategically lightened, stronger, safer and has better thermal capacity than OE cast flywheels. With smooth operation at all RPMs, these flywheels meet the needs of both the enthusiast and the hardcore racer.
Features:
• Chatter Free
• Easier engagement from a stop compared to aluminum
• Improved Engagement and momentum when Launching
• One-piece Chromium Molybdenum forging is stronger and more durable than billet steel, aluminum or cast iron.
• Tough, precision-made and dynamically balance
• Lighter and stronger than stock flywheels
• Integral ring gear is induction-hardened for maximum gear life
• Material is properly distributed for strength, greatest heat dissipation and reduced inertia
• CAD-designed, CNC-machined and computer balanced for quality and precision
• Improved throttle response and acceleration
• Smooth operation at all RPM’s
• Optimal mass distribution
• Lead-in chamfers
• Heat treated and tempered
• SFI Spec. 1.1 Certified Design
This sale is the PERFECT opportunity to save hundreds of dollars on JHM Transmission and Drivetrain components! Here are a few products you can save BIG on.
JHM B5 S4 Lightweight Flywheel & Clutch Combo: https://jhmotorsports.com/catalogsea...=JHM-27TLWFWCC
JHM B5 S4 Transmission Rebuild Kits:
https://jhmotorsports.com/catalogsea...on+Rebuild+Kit
JHM B5 S4 Shifter & Linkages: https://jhmotorsports.com/catalogsea...HM+B5+S4+Solid
Shop all Trans & Drivetrain products HERE!
Contact us today! 209-968-0077 or email Sales@JHMotorsports.com
