Results 1 to 31 of 31
    Active Member Two Rings slobdogg's Avatar
    Sep 24 2018
    Fairfax, VA
    Question Where do you put your cell phone?
    (I believe the A6/S6 is the same as 7s)
    The front compartment in the center console is a little too big for my S9 (the phone falls and is hidden); the cupholder is a little too tight (though it's default). So what mounting solutions is everyone using? I'd prefer no magnetic mounts, and not interested in wired charger mounts.
    2016 S7 Daytona Gray Pearl
    Established Member Two Rings Kodachrome's Avatar
    Nov 12 2011
    Aspen
    I plug mine in using the center storage console and get it out of sight and out of mind.
    The last thing I want to deal with when driving is the distraction of a phone.
    2015 Audi RS7, Prism Silver, stock for now.
    2012 Audi A4 Prestige, Brilliant Black, APR Stage-1, sold
    2005 Toyota Tacoma 4WD, stage-3, 407HP
    Established Member Two Rings MolonLabe300's Avatar
    Aug 16 2017
    Chattanooga
    Rear cup holder for me.
    Sent from my Pixel 2 XL using Audizine mobile app
    13 S6 APR S1, Milltek turbo back, roc-euro
    May 20 2010
    I throw mine in the front compartment, usually sitting upright (it falls over though). It's not an S9 though, so it does actually fit.
    2016 A6 TDI Prestige - S-Line, Black Optics, Driver Assistance, HUD, LED Headlights, Cold Weather, Warm Weather
    2003 allroad 6MT - STUKLR Stage 1, Hotchkis sway bars, RS4 engine mounts, Apikol rear diff mounts
    Jun 23 2011
    Toms River, NJ, USA
    I use the Proclip mount. It stays put, even with a hard Stage 1 launch. It will run about $70 with the mount and cell phone holder, but it's worth it.
    https://www.proclipusa.com/vehicle/d...4-audi-a6/2013
    Senior Member Three Rings SpectreGadget's Avatar
    Oct 22 2014
    Atlanta, GA
    Sep 24 2018
    Fairfax, VA
    Quote Originally Posted by gimpgutter View Post
    Pricy for sure, but does seem to be the best choice. Thanks!
    Feb 14 2018
    2005 Yamaha R1
    Minneapolis
    Quote Originally Posted by slobdogg View Post
    I put mine in the crack of the passengers seat leg bolster that extends.
    Jun 06 2016
    Florida
    +1
    I attached mine on the passenger side. Had one in my S4 that worked perfectly and I’m 100% happy with the one in my S6.
    2018 Daytona Gray S6 | S Sport | Black Optic | Carbon Atlas |
    2011 Phantom Black S4 | S-Tronic | P+ | Nav | Sports Differential | Titanium Package | Silk Nappa | SOLD
    Aug 08 2018
    New Hampshire
    Quote Originally Posted by Cam.CL.S7 View Post
    Same here, works well until you have one of those pesky passengers.
    Mar 11 2007
    Twin Cities, MN
    In my suit jacket inside pocket.
    2012 A7Plus Stage 2+
    2013 A8L
    2010 A5 2.0T Stage II
    1998 A6 2.8 PES SC
    Active Member Two Rings MaverickRS7's Avatar
    Aug 11 2018
    Houston/TX
    Under arm rest plugged into MMI....now we have waze and pandora on MMI don't need to see it and I can voice text so perfect place.....except I keep leaving it in the car...out of site out of mind....
    2017 RS7 Performance/1991 964 Turbo/2007 997 Turbo/2016 GLE63S
    Sep 24 2018
    Fairfax, VA
    Quote Originally Posted by MaverickRS7 View Post
    Throwing shade all over us <2017 ;)
    Apr 22 2018
    OC, CA
    CD slot magnet mount.
    Sep 24 2018
    Fairfax, VA
    Quote Originally Posted by tabio42 View Post
    Perfect. Just ordered, thanks!
    Jul 20 2018
    Brampton, ON
    Quote Originally Posted by SpectreGadget View Post
    How does this stay on? I've tried mounting stuff there before but I can only use double sided tape which eventually falls off. Especially when it's hot.
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    Plus 1
    1 of 1 in the United States - 2015 A6 TDI Prestige with 19" Sports Package and Season Dedicated Tires - Oolong Gray Metalic, Nougat Brown Interior, Dark Brown Walnut Inlays, Black Headliner, Driver Assistance Package, Cold Weather Package, Night Vision Assistant with Pedestrian Detection. Summer - Michelin Pilot Super Sport. Winter - Yokohama Bluearth Winter V905. Eurocode Sway Bars and Links. XPEL Ultimate.
    RIP - 2005 A6 4.2 - (February 2005 - August 2014) (142,000 miles)
    Oct 22 2014
    Atlanta, GA
    Quote Originally Posted by Vinng86 View Post
    I use 3M molding tape, since it's meant to deal with heat. A couple of things I've learned. I run the tape perpendicular to the direction that gravity pulls. Plus, the back of the mount adapter that I 3D printed (pictures are of a previous version) butts up against the plastic, so I tape the bottom of the adapter, along with the back of it, which keeps it from pulling up and falling off.
    This is a magnetic, wireless charger. I have the metal ring in between the case and the phone.
    Aug 16 2017
    Chattanooga
    Which one do you use?
    Oct 01 2018
    Atlanta
    passenger seat plugged in.... sounds like I'm a safer driver than most of you :P
    13 S7 // factory color // Stage 1 // Wooshing intake // burping exhaust // speed bump killer // cruise control // goudy warmers // factory sky light // head lights // not a ZF // hacked // more annoying descriptions to come
    Oct 08 2017
    Somewhere
    I leave them in my pockets. Works quite well.
    Established Member Two Rings jsilas's Avatar
    Dec 29 2015
    2016 S6, 2018 SQ5, 2016 R1M, 2004 R1
    Snoqualmie, WA, PNW
    I used some toolbox foam to make organizers for my center console upper/lower sections. I keep the pictured items in the top section, and in the lower section, I installed a Qi charging pad with the foam, so that I can simply set my phone into the designated spot. This allows it to charge, and the foam holds it in place to keep anything from sliding around. Works perfectly.
    2016 S6 | Mythos / Black | Prestige | Carbon | Black Optic | Bang & Olufsen | Driver Assistance | Sport | APR Stage II ECU/TCU | CoD disabled | APR DPs | AWE Touring | VIM (OBD11) | -16mm height (VCDS) | +30mm width (H&R) | EuroCode Sway Bars | Opti-Coat Pro+ | XPEL Ultimate PPF | XPEL ceramic tint
    Jan 09 2018
    97 B5
    Somerset, NJ
    Magnet mount on the AC vent.
    Active Member Two Rings Zuhlaynuh's Avatar
    Aug 12 2018
    California
    I put mine in front of my shifter. Horizontally of course so it doesn’t get in the way of shifting.
    Established Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    Scosche Magic Mount fits nicely in driver's side air vent, just to the left of the MMI screen. Works perfectly.
    2016 S6, mythos black, RS7 turbos, MRC inlets |AWE touring exhaust| APR downpipes| Eventuri intake| AMS cooler| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights |Sound: Navtv Zen-v, Audiocontrol DM-810 DSP, JL HD900/5 driving JL10W3 sub and Focal KX3 up front. Rear; JL HD600/4 driving Focal KX2.
    May 09 2014
    Delco
    Quote Originally Posted by jsilas View Post
    That’s great! Looks super slick and you are probably like me wanting everything organized and neat!
    What is the foam. Took box foam? Home Depot? Did you. We’d to take them down or do they stay in place bc of the fit? Cut it with a razor blade?
    What Qi Charger did you get? I only see the white “my charger” Qi certified pad at Best Buy
    Aug 16 2017
    Chattanooga
    Thank you.
    Dec 29 2015
    Snoqualmie, WA, PNW
    Quote Originally Posted by sd761 View Post
    Used toolbox foam from Amazon. Cut with a razor blade. I might try to 3D print something next, since the result may be more precise, but this works well for now.
    The Qi charging pad was also from Amazon - FASTPAD Ultra-Slim is the name.
    Jan 30 2017
    I use this one.
    https://www.amazon.com/Vena-Universa...DnL&ref=plSrch
    Sent from my LG-US996 using Audizine mobile app
    Nov 22 2016
    Olympia, WA
    JSilas, that is pretty awesome OCD-ness! No cigar humidor?
