Results 1 to 34 of 34
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    B7 becoming a money pit.
    I'm really getting tired of this car. When it works it works wonderful i now have 175k miles i know is not a new car and don't expect to nothing to fail but is getting really annoying. I got my first motorcycle to daily it and not drive the b7 as much. But this limp mode situation makes me want to junk it. I have replaced turbo, low pressure fuel pump, fuel level sender. Cam follower is good chaged 12 k miles ago never had a hole cams are good. Map sensor is good. Changed to a better working MAF. No misfires. Coils are good plugs are new. No leaks in valve cover gasket replaced when i did my head. Then today i throw an underboost code and a new one. Then limp mode. Full throttle wont go past 4000rpm. What the fock is wrong with this car? Is not like it has old parts. I replaced my oil filter housing due to it leaking. Stopped leak car ran wonderful but today... Today is has run like shit. Theres my new amazing code. Seems like my HPFP took a dump on me? If i can log it please tell me how. I dont mind getting one just want my car to be fine. In the next days ill be driving my new bike post picture. But since i wont daily the b7 i just want it working for when i do drive it.
    @Evolutionarmory help me brotha lolScreenshot_20181109-132209.jpgIMG_20181109_012344_391.jpeg
    Sent from my G3313 using Audizine mobile app
    Ivan
    Veteran Member Four Rings IronAudi's Avatar
    Jun 13 2007
    Middletown, CT
    Welcome to all Used cars. My exhaust feel off on the highway and I have random missfires. Sell the car and buy a Honda.
    2008 B7 A4 2.0 T Brilliant Black|20% Tint|18" RS4 Reps LE|Bone Stock Brand new old Engine.
    Established Member Four Rings
    May 20 2017
    New Hampshire
    Could be the fuel rail pressure switch, the high pressure fuel pump or a clogged fuel line. Itís hard to say.
    A lot of people would say replace your high pressure fuel pump because this code generally refers to the sensor on top of the HPFP but an equal amount of people have probably been bitten in the ass over this code.
    Generally you would want to do a log of the HPFP and see if rail pressure is dropping off somewhere and examine the data to get a better idea of what itís doing
    2005.5 A4 Avant: JHM K04R, GIAC K04 tune, NGK BKR8EIX plugs, RS4 PRV, RS4 fuel pump controller, Treadstone TR6 intercooler core with JHM pipe kit, CTS Turbo test pipe, ECS Tuning snub mount, 034 street tranny mount, 034 street motor mounts, ECS Tuning turbo inlet pipe, ECS Tuning RA4 clutch conversion, Billy Boat Stealth cat back, Fluidampr
    Senior Member Four Rings Dondbg's Avatar
    Mar 12 2016
    MB w203
    New Zealand
    Engine, live data , ch 230
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    At least its not the p0089.
    I replaced my entire fuel system chasing it. Ended up being the hpfp.
    Sent from my SM-G960U using Audizine mobile app
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Jul 22 2016
    Washington, DC
    Are you getting any hesitations or stalls?
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Quote Originally Posted by BillyK View Post
    I am. Driving under 3000 rpm seems to work fine but once i do a WOT doesn't go past 4000k rpm wanted to pass a semi today doing 40 on a 65 and i couldn't pass him. I was so mad you have no idea it caught me by surprise.
    Ivan
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    I replace my fueling system exept the HPFP. Honestly i will run data logs on channel 230 what i'm i looking for here? In idle or wot or normal driving? Also i is the pressure switch the one on top or the side one? That one has been replaced 20k miles ago oem. When i did my cylinder head.
    Ivan
    May 20 2017
    New Hampshire
    Fuel rail pressure switch. Itís on the underside of the manifold. That switch, the HPFP and the fuel line seems like itís all you have left.
    Donít you have a friend who has a downed B7? Could you use his HPFP to test with?
    Oct 03 2018
    New York
    I just took in an A4 parts car with a 2.0, if you're stuck and want to try anything to remedy it let me know. I still have to defeat some kind of security system since this car was repoed, but I'm about 95% sure it runs fine.
    Sep 27 2008
    Phoenix
    At 175k miles most cars start crapping out in one way or another.
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Ok since the car sometimes rides nice and sometimes i doesn't i'm going to buy an HPFP. They fail internally too correct?
    Ivan
    May 20 2017
    New Hampshire
    Quote Originally Posted by dalmation53 View Post
    Honestly I think the sensor on the top is what fails the most on them and they arenít available separate.
    You should break down and buy VCDS. A full throttle log of the HPFP could help figure out what is going on. Youíve got 3 things that are going to mess with high pressure the most. Your PRV could be failing and dumping pressure too early, the pressure switch on the fuel rail could be giving the wrong readings or you could have a bad HPFP because the N276 on top is bad. Or it could be a clogged fuel line.
    Feb 15 2016
    Cambridge Ontario
    just curious, will the car rev to redline while in neutral ?
    if it cant unscrew your o2 sensor first in the stream if it then revs up you have a clogged cat
    2014 A4 2.0TQ Technik
    2006 A4 2.0TQ 6spd
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Registered Member One Ring WhiteTrashB7's Avatar
    Nov 06 2018
    Aurora, CO
    Have you checked the fuel pressure regulator on the rail?? I had a very similar situation a couple weeks ago and that ended being my issue
    Oct 14 2018
    melville, NY
    if the HPFP is dying on you wont it cause cam follower to fail and then break camshaft as well? i think you might have to bite the bullet on this one. all in all you paid for what you got and your maintaince is a day late and a dollar short. you gonna fix or you gonna sell as is?
    May 20 2017
    New Hampshire
    Quote Originally Posted by joepickems View Post
    Every time you post shows me how much I wish you wouldnít...
    May 05 2014
    Adelaide Australia
    Dalmation has a rep for replace rather than diagnose, just about the only part of the HPFP to fail is the switch again it could be PRV although that is remote, should be able to get a HPFP to test with before throwing $300 at a new pump.
    May 20 2017
    New Hampshire
    Quote Originally Posted by Jet08 View Post
    And the way this new member Joeís posts have a familiarity to it. He post like this douche that used to post here... Doesnít know shit about cars, takes jabs that make no sense, all too familiar.
    Maybe ahotboy15ís alias.
    Senior Member Four Rings tloft4's Avatar
    May 15 2016
    Lock Haven, PA
    hes already admitted that
    "account terminated"
    and now hes back with this
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    That is ahotboy15 indeed. Look at the way he types. Thinking we won't notice haha
    Ivan
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Hahaha this is funny because is the truth. No i can get a used working pump from my friend only thing he lives 90 miles away. I guess i could drive up there and test it with his new hpfp.
    Ivan
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Quote Originally Posted by WhiteTrashB7 View Post
    Sorry i havent heard of this have a pic or something i can look at?
    Ivan
    Nov 06 2018
    Aurora, CO
    Its on the firewall side of the fuel rail. It has a ball and spring valve inside of it to help build pressure in the rail.. i think i got my new one from ecs for like $7520181110_231329.jpeg20181110_231246.jpeg
    Oct 14 2018
    melville, NY
    $125 for used HPFP on ebay. i have a feel damnation is gonna need a new fuel pump.hahaha.
    https://www.ebay.com/itm/06-08-Audi-...M/263987131595
    May 20 2017
    New Hampshire
    Quote Originally Posted by tloft4 View Post
    Come on mods!! IP ban this guy already. What a douche.
    Oct 14 2018
    melville, NY
    where there is a will there is a way (IP ROLL)
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2006 A4; 2007 Audi Q7 3.0 TDI
    Brandon, Suffolk, England
    If you need to buy either a pump or stock PRV let me know. I have both items and will sell them and they are guaranteed in working condition.
    Edgar
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Damn that sucks you moved to NY you were so close to me. Ahotboy15
    Ivan
    Oct 14 2018
    melville, NY
    come replace my oil filter housing ill give you 200 cash
    Feb 06 2009
    Audi A4, Mit. Montero
    Goldsboro, NC
    My A4 became a money pit back in 2009
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    May 20 2017
    New Hampshire
    Maybe you should take that 200 and pay for the turbo you stole.
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Hahahahahhahahahahahahahahhahahahahahahahahahahaha hahahahahhahahahahahahahahahahahahahahahahahahahha hahaahahahahahahhahahah
    Omg i shed a tear. That comeback was priceless i'm deaddddd...
    Ivan
    Aug 20 2013
    Audi A4 B7
    Orlando, FLORIDA
    Quote Originally Posted by i3oricua View Post
    Edgar
    Ok ill let you know brotha. Right now i'm kinda broke since i bought the bike. Lol trying to level myself before i buy a hpfp.
    Ivan
