Results 1 to 8 of 8
    Feb 06 2013
    WV
    Mystery coolant leak
    My coolant keeps disappearing. It's a 2001 awm. It's not the coolant flange, and I don't see where it's leaking from.
    I think when I did the engine I over torqued the oil cooler.
    I am open to common places or ideas, it's not heater core either.
    If you can read this thank a teacher, since its English thank a veteran...
    Audi make a great car, but their heater cores are, well $h!t.....
    Feb 22 2018
    San Jose California
    Iíd check the dip stick to rule the head gasket out first if you got water in the oil ya know... mine did it and didnít even know about it till when to change a spark plug ran fine and everything
    Feb 22 2018
    San Jose California
    Or even disconnect the fuse I think itís 29 or 34 if Iím remembering rite for fuel pump then pull the coil packs and spark plugs and crank the engine over a few times to see if coolant splashes out... I was checking for a misfire and found out I needed a head gasket replaced as well
    Jun 08 2017
    london
    I had the same symptoms. Put a bottle of kseal in the coolant. Problem went away.
    Senior Member Two Rings Ryanic's Avatar
    Jun 03 2013
    Minnesota
    Quote Originally Posted by scaphan View Post
    Jesus... Never put any stop leaks in these cars. RIP your cooling system and heater core.
    Also OP, I assume you really checked the radiator? I had my 2.8 leaking from my radiator for a good year or two before I finally found my leak. It wasn't leaking enough to leave coolant on the floor and there was no way to see the leak from the fins without removing the condenser in front of the radiator
    Feb 22 2018
    San Jose California
    Quote Originally Posted by Ryanic View Post
    EXACTLY......!!!!
    Jun 08 2017
    london
    Well I put kseal in about a year ago and still have heat. I also read the warnings but it seems to be okay. Maybe I am the exception?
    Jun 08 2017
    london
