Results 1 to 1 of 1
    Senior Member Two Rings Ryanic's Avatar
    Jun 03 2013
    Minnesota
    Climate Control Graphics Channel (#53) Help
    1998.5 A4 2.8L 30V
    Something has to be wrong with my climate control right? I checked out the #53 option on the climate control hidden menus (Recalculation button plus Temperature up button)
    Here is what my climate control is showing for 9 different settings. There is a note on the guide saying G1, G2, G3 should all be lit up if the system is working.. And none of the 3 ever show up.
    Running option 1 on the climate control gives me a .0 for a diagnostics trouble code, which means no issues?
    If anyone who has a B5 with perfect working heat could you go into menu 53 and see what yours looks like? I had my temp set to max
