Results 1 to 4 of 4
    Established Member Two Rings flasheverything's Avatar
    Jan 18 2018
    Markham
    audi a4 b6 sound explanation after letting go accelerator pedal
    alright, kinda new to this and just want to know what is sound this called. Is this a 'cool' sound? Should I be concerned? Could it be related to some boost / waste gate ? Originally car had k&n intake filter, I also have stock filter if that changes anything. Uploading link in a minute. under higher boost it produces more of this sound. https://youtu.be/o8HrN2mNkyU?t=191
    Feb 12 2008
    Michigan
    The horse like sound when letting off to shift? The bypass valve, itís normal. The sound is more pronounced when the factory air box is removed
    Jan 18 2018
    Markham
    it's stock, still factory airbox but with filter mesh filter.
    Established Member Two Rings APC123's Avatar
    Feb 05 2017
    Wilmington Delaware
    Diverter valve. No problem. If yours was going bad (is bad), it would be making a constant similar noice all the time, while your foot was on the peddle.
