Results 1 to 3 of 3
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    APR Spherical Pendulum Mount Now Available! (7 Speed DQ381)
    APR is pleased to present the ultimate Pendulum Mount Upgrade!
    The APR Pendulum mount replaces the factory mount with a new, thick, billet-aluminum and billet-stainless-steel two-piece design, featuring a PTFE-lined spherical bearing and new bolts. The system stiffens the driveline to improve shift quality and power transition. It is easy to install, addresses all concerns with the factory setup and includes all necessary hardware to bolt on and enjoy!
    Quick Facts:
    Reduces transmission movement
    By removing the factory rubber bushing, the APR system reduces slop in the driveline to improve shifts, and transmission of power to the ground. Expect a sportier feel during acceleration, deceleration and gear changes without an excessive increase in NVH when paired with the factory sub-frame mount.
    Spherical bearing
    Spherical bearings offer far less unwanted movement over rubber and polyurethane inserts. As such, the APR mount uses a spherical bearing, made possible by upgrading the rear mounting hardware. The bearing is fully-serviceable, features a heat-treated race and precision-ground ball, with a self-sealing and self-lubricating PTFE lining.
    Billet-aluminum and Billet-stainless-steel construction
    The front and rear pieces replace the factory cast aluminum and stamped steel pieces with precisely machined, billet-aluminum and billet-stainless-steel pieces that are strong. The aluminum piece is anodized black and the stainless piece is electropolished to provide corrosion resistance and the APR logo is laser etched on each side.
    Replacement Bolts
    The factory bolts are one-time-use, and must be replaced when installing a new mount. The APR system includes non-one-time-use bolts for their strength, quality and longevity over the factory bolts.
    Easy to install
    The system is easy to install, doesn’t require dropping the sub-frame and is compatible with the factory and factory-like modified sub-frame mounts. Full install directions are included with each system.
    Application Guide:
    7 Speed DQ381 Transmission found in the new S3, TTS and Golf R
    MS100180 - $249.99
    Product Page
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Stage 3 Forum Advertiser Four Rings Excelerate Rep's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    Hey Audizine,
    We have APR's new pendulum mounts in stock and ready to ship,
    Feel free to reach out to sales@excelerateperformance.com to get setup!
    Happy modding!
    May 20 2009
    Socal
    Increase vibration/rattling? If so how noticeable?
