Page 5 of 6 FirstFirst ... 3456 LastLast
Results 161 to 200 of 206
  1. #161
    Jan 03 2009
    Iowa
    Thanks for the update. How many miles on your car?
  2. #162
    Jul 22 2018
    Georgia
    I believe my hpfp is leaking. Where do they tend to leak? If I did the autotech upgrade and replaced the orings would that stop the leak? Or is the leak caused by mechanical damage to the cam follower or something else? Tia for any responses.
  3. #163
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Quote Originally Posted by Woodepic View Post
    Update: I followed the diagnosis criteria via the TSB, and verified the hpfp's to be the issue. I just installed the hpfp's and everything works great! Thanks to everyone on this thread, couldn't have fixed it without yall!
    Tracking this issue down was a PITA for me so I am glad to help others.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
  4. #164
    Junior Member Two Rings
    Dec 18 2019
    Edmonton, Canada
    Quote Originally Posted by qcrazy View Post
    about 77k (though it's been stage 3 APR since about 70k)
  5. #165
    Dec 18 2019
    Edmonton, Canada
    Quote Originally Posted by MrTorres View Post
    Not sure where the exact leak location is, but it wasn't due to cam follower damage. I took mine out while doing the fix and it looked great.
  6. #166
    Dec 18 2019
    Edmonton, Canada
    Another update:
    The issue has actually started to come back about 2 weeks after the fix, albeit not nearly as bad *yet*. When I swapped HPFPs, the car worked perfectly, but now it's slowly degraded. (only been about 5k miles on new HPFPs).
    It's worth noting my car is running APR stage 3 with 94 octane E10 fuel, and has been for about 7k miles. Is it possible that since my HPFPs are working double overtime (making about 650hp), that this prematurely wore them out. However, I did initially have this issue before tuning the car.
    It's worth noting that audi has gone through 5 revisions of this HPFP (oldest to newest):
    079127025T
    079127025AE
    079127025AH
    079127025AK
    079127025AJ
    My car (before the tune) was using the K variant, aka the first one ever made. I assume that due to leaks (from normal, non-tuned cars), they updated it. I replaced my pumps with Hitachi HPP0023's which cross reference to the latest AJ variant. (Hitachi is audi's oem supplier).
    So here's the possible scenarios:
    - The K variant was so bad that it broke even with stock cars. The AJ variant is improved enough for it to work without issue on a stock car, but not when tuned.
    - The K variant was so bad that it broke even with stock cars. The AJ variant is also bad, and would've broke anyways, even on a stock car, hence why it's broken on mine.
    - The AJ variant is good enough even for a tuned car, but now my Injectors are also leaking?
    One potential bandaid fix I may try is getting the dealer to update the ECM with SVM Code 01A225. (This is reportedly the fix as per TSB 2046724/7). I assume this software change prevents the intake from being exposed to crankcase fumes after turning off the car. This way when you go to start it, it won't be full of gasoline vapours, making it either run rich or not start at all. My concern is that fuel vapours are still in the crankcase, which means something is leaking.
  7. #167
    Jan 03 2009
    Iowa
    Are you sure you are running the correct HPFP for your tune?
    APR runs a different HPFP with a larger bore. This changes the calibration in the tune, as each stroke would be expected to provide more fuel. Is your APR tune set up to use their HPFP?
    It could be as simple as the wrong pump. Unfortunately, the Gen III pump from APR is $$pendy.
  8. #168
    Dec 18 2019
    Edmonton, Canada
    Are you sure that Gen3 APR pump is intended for the 4.0T? I've only seen it suggested for the 2.0T. In this thread, Arin suggests the Gen3 may work, but it's unclear. Before I bought new HPFPs I reached out to APR support to ask if there was any specific HPFP I should buy for a stage 3 setup. TLDR: they said go for the oem pump. Full email below:
    Also it's worth noting, I'm not having any issues regarding getting enough fuel, or making enough power. In fact, my car now has a 2.9s 0-60 lol. The issue is just longevity (if HPFPs is even the issue).
  9. #169
    Jan 03 2009
    Iowa
    I bought an APR Bi-pipe 20 years ago and I haven't purchased another APR product since. Just throwing out an idea as the B9 S4's are all currently working through HPFP selection and tuning, so it was fresh in my mind.
    If this was an issue for you, the car could accommodate with fuel trims so it may run fine. APR technically said you should contact your dealer and verify which software version you had flashed. May not be it, just throwing out an idea.
    FWIW, this pump lists the 4.0T.
  10. #170
    Dec 18 2019
    Edmonton, Canada
    Okay thanks for the thoughts! Regarding software, I believe Levi (in the email) was referring to a previous email where I also asked about updating the software as per the TSB. I'm now really curious what that software update does exactly
  11. #171
    Junior Member One Ring yoo_gabriel's Avatar
    Sep 16 2013
    I'm currently having hard start issue for about a month now, is it possible to upgrade the HPFP with autotech HPFP, or would I just have to replace the whole thing with part # 079127025AJ
    Thanks
    Black Optics, Mike's Catted DP, Custom Exhaust X-Pipe no mufflers, OBD11 Mods, AK-47 racing Module, Niche Misanos Gunmetal 20x9+26, Unitronic Stage 2 Ecu+Tcu. Insta: Socals6
  12. #172
    Veteran Member Four Rings ANMS4's Avatar
    Dec 18 2012
    Framingham MA
    Check the injectors. I just went through this, two new HPFP’s and changed nothing! Had two injectors leaking when the car was off/asleep
    2014 S8*SMR Intakes*HMD Exhaust*DS1 tuned by SLEEPERTUNED*E50* MELEN TCU TUNE
    SOLD 2014 A6-IE STG2 DP+ TB E40 tune and Melen TCU Flash, RS7 Airbox, AWE Touring Catback+Resonated DP, Ported SC By Shane
  13. #173
    Jul 29 2014
    2016 Audi A3 2.0T
    Clearwater/Florida
    Quote Originally Posted by ANMS4 View Post
    Engine out repair? Ouch.
    Sent from my SM-A716V using Tapatalk
  14. #174
    Dec 18 2012
    Framingham MA
    Quote Originally Posted by brad281 View Post
    No thank god LOL, Just remove the SC , still costly $860
  15. #175
    Jul 29 2014
    2016 Audi A3 2.0T
    Clearwater/Florida
    Different story on the 3.0T. The 4.0T has the injectors on the outside of the V. You have to take the engine out.
  16. #176
    Jan 18 2022
    Thus
    Quote Originally Posted by Qweklain View Post
    Figured I would post up here in case more people start having this issue (or still are without resolve). I have gone back to stock and my car runs fine ~85% of the time, however, the tune was not the issue, it was just making the issue worse. The car was running so rich due to the alteration from the tune that the car was maxed out on how much fuel it could pull. Now it runs, but it still has hard starts when warm sometimes and runs rich too much, but usually the rich aspect is only at idle or when off-throttle.
    I did find the cause of what causes the hard-starts, at least in my case (see attachments). Basically, whatever the root cause is is causing the high-pressure to build-up so high, with the car off, that when you crank the motor you flood it out. Take a look at the three log snips I attached and you will see the high-pressure is way too high and these are with the car off! I have plenty of logs showing that these high pressures are not normal and the hard-starts only happen when this pressure build-up occurs. The log with the blue horizontal highlight is right when the motor died.
    If you want to log what I am logging, use the variables below.
    IDE00148
    IDE00186
    IDE00188
    IDE00201
    IDE00202
    IDE00559
    IDE00565
    IDE00597
    IDE00598
    IDE00604
    IDE00605
    IDE01869
    I've noticed the same exact thing with the fuel pressure being way to high like yours. Normaily it wil not rise any further then like 8MPA +/-. Did you find the root cause?
  17. #177
    Jun 19 2020
    Summerfield, FL
    (Just a side note)
    After my APR stage 1 tune ... I went for a week long drive in the mountains of NC ...
    At an upper elevation ... I had a no start scenario ... I was freaking out ... push the start button ... turning over ... No Start ... I panicked a little ... but, I had an idea to pump the throttle as it was turning over ... viola ...!! it started up, with a very low idle ... had to keep pumping the gas pedal ... till it got over the low idle ... next mountain over ... same thing and pumped the gas pedal during the start ... and till the idle came up ...
    Back at home in the low lands ... no issue since ...
    2015 Audi S4 (totaled )
    2017 Audi S6 Wickedly quick | Prestige w/ Black Optic | H&R sway Bars |Eurocode Alu Kreuz Drivetrain Stabilizer | 034 transmission and differential inserts | SRM driveshaft carrier bearing | SRM shorty intakes w/ RS7 airbox | APR ECU stage 1 and TCU | APR (non-res) catback | Giro Disc Front rotors w/ EBC Yellow pads │ 034 2 piece rear rotors w/ Hawk HPS 5.0
  18. #178
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Optimus247 View Post
    (Just a side note)
    That is weird I moved from sea level to 6500 ft and have no issues like that.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
  19. #179
    Jan 18 2022
    Thus
    is it possible for someone to give a log of a fixed scenario . im currently doing diagnostic on my car per tsb but not sure if my hfpf are faling. everyone's experience is that the hard start needs more time then the tsb describes.. like myself. problems starting after 30 min +. Hope someone can upload a log of the 3 sensors (IDE00186 IDE00188 IDE06212) so i can do a compare of a warm engine shut off cooling period.
  20. #180
    Jan 03 2009
    Iowa
    2014 S6, just shy of 97k miles...add me to the list.
    It didn't want to start while running errands, finally got it going. Two new HPFP's and it is starting better than it has in as long as I can remember. I think it had been leaking for a while.
    I pulled the pumps apart, looks like it was the passenger side. I am getting data and pictures to make a longer post here in a few weeks. But for now, add me to the list...
  21. #181
    Jul 29 2014
    2016 Audi A3 2.0T
    Clearwater/Florida
    Same here. Had been dealing with the hard start issue for a couple years in a 2013 S6. It wasn't a huge inconvenience early on, but started getting worse, so I replaced the HPFP's. Been fine ever since. Going on 2 months now.
  22. #182
    Jan 18 2022
    Thus
    Quote Originally Posted by dtdeg View Post
    For me the fix was also replacing both hpfp.
  23. #183
    Jul 27 2013
    indianapolis/indiana
    My rs7 if I let the fuel get too low will do the hard, no start for a few weeks.
    2003 RS6 Apr stage 1 and tiptronic, Apr divertors, Clear bra, Yellow konis SOLD
    2014 S7 Audi exclusive edition 1, Havana black metallic exterior, Havana brown interior, APR stage 1 ECU/TCU, Total Loss Wreck
    2016 RS7 Stage 2, Mythos Black Metallic, SRM/DS1
    2025 RS6 Daytona Grey Pearl, executive package, carbon package, alcantra package, soft close doors, B&O, res delete
  24. #184
    Veteran Member Three Rings Botbasher's Avatar
    Jul 26 2018
    2014 S6 "Elsa" - Mk 6 JSW - Scratch Built Lotus 7 Replica
    Humidity, NC
    Q...
    What is "better"? My 2.0tfsi usually takes a couple cranks to start... sometimes it's nearly instant... sometimes it's a couple cranks. I've had multiple HPFP pumps (AutoTech issues), new S3 injectors and a ton of other work and it's always done about the same (after timing chains).
    The 4.0 seems to mimic that pattern (no timing issues) of randomly taking a couple extra cranks to kick in, but ALWAYS to a smooth idle.
    Is there a spec for the cranking that one can look at to start and determine when/if problems are happening? My 14 S6 has just crossed 106k so I am either really lucky or it's had a lot of this corrected already (bought at 103k).
    Cheers,
    Ken
  25. #185
    Jan 03 2009
    Iowa
    Quote Originally Posted by Botbasher View Post
    Q...
    Cheers,
    Ken
    For me, it wasn't the "cranks" for it to start, it was after it went to start. Prior to any issues it would start and go to a smooth stable idle.
    Then suddenly in late November, shortly before I put the car in storage, it started and suddenly died once (cold start). Not a big deal, started fine on the second try. BUT after that one instance, when I started the car it would start up...then the idle would drop down...and then it would go to a stable idle. Just a little blip in the start-up idle. It started intermittent, and then eventually went to every time.
    I did a start log of the car back then and nothing looked obvious to me.
    Then here a few weeks ago, suddenly it would not hot start when running errands (first time ever). Took a bunch of tries (5 or 6) to get it going. I went ahead and upgraded to Auto Tech's and put in new HPFP's at the same time. Now...it starts like it did before...straight to a smooth idle. I am thinking it is not a coincidence.
    Now that is starts better I will do a start log of it soon, just to compare. See what that looks like. When I have a little more data I'll post it up. Probably going to be a few weeks.
    Added more info in my post here.
  26. #186
    Oct 20 2016
    Los Angeles/CA
    Reviving an old thread that is unfortunately now relevant for me. Over the last few months, dealing with some hard starts and two no starts (earlier in the two months) on my 2015 S6 (63k miles). Has been driving me crazy as initially I thought it was the battery causing the gasping for air type start up.
    For those that have remedied with new fuel pumps, has the issue not come back since? Realize the two fuel pumps are bit more costly than I had thought - OEMs are roughly $500 each. Appreciate any feedback folks have here.
    2022 RS6 Daytona Gray
  27. #187
    Jan 03 2009
    Iowa
    Fixed it for me. Runs/starts like a champ now!
  28. #188
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Idle questions: 1) Is "age" of the fuel pump more related to time since manufacture or miles driven? 2) What effect (if any) does fuel quality have on the pump (for example, keeping water out of the tank minimizes rust on those components)? 3) Am I overthinking the issue - if the pumps are working, don't worry; if they're not, replace with an upgrade in quality?
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
  29. #189
    Jan 03 2009
    Iowa
    It is a wear item, which will be directly dependent on pump strokes. A decent, but not perfect, proxy would be mileage. Ethanol is harsh, and could have an effect on life. But hard to say if it would cause a material difference in life. My original pump died BEFORE I started running high ethanol.
    It seems to me about 100k miles (+/-) isn't an uncommon area for this issue to start to show up. But this is generic, as use type certainly affects timing. And like everything, they can fail at anytime.
  30. #190
    Jul 26 2018
    Humidity, NC
    What are you considering the "wear" item? The seal? The piston? The follower? I would believe the seal being the main wear item. The DLC coating on the pistons is simply too hard to wear out!!
    I had several go-rounds with rebuilding my HPFP on my A5 (one word Autotech... x3!) and the same OEM seal "felt" different depending on the Mfg of the piston (OEM v AT v 034). OEM and AT were both loose enough to the point that they would allow the piston to slide, where the 034 was so tight I almost thought I would damage it during assembly. Thankfully it didn't!!
    The seals are not "special". I'll look for my pics of it, but I swear it was an Elring or SK seal, like any crank or camshaft seal.
    Cheers,
    KS
  31. #191
    Jan 03 2009
    Iowa
    I'm sorry, you were saying something about an indestructible coating?!
    97k miles, factory HPFP's, fully stock fuel system...
    The center seals were equally worn.
  32. #192
    Jul 26 2018
    Humidity, NC
    I'll give you that one... I guess I should have ordered my thought.
    My stock one looked exactly like the left side. Scared me to death knowing the issues others were having. I was only replacing because of going to E40 and running out of fuel at the top so I wasn't thinking about it being damaged. Putting it on my granite block at work, I measured between 0.00000-0.00005 (step resolution of my micrometer at that decimal place) deviation over the length of the worn area despite looking extremely worn as yours does. The shaft over it's length actually had more deviation than the worn area did.
    I'd actually be more worried about the one on the right. Looks like the seal was barely contacting it compared to the other.
    Out of the 5 pistons I had in hand (1 OEM, 3 Autotech and 1 034), my OEM looked like your left side and had no issues at all. The AT units slid through the seal without any effort and looked worse than the right with less than 500 miles on each when I returned them. I haven't had the 034 out since install, but it was hard to push through, so I'd hazard it'll look more like your left example, but with 10k E40 24psi boosted miles on it, it is working as well as the day I installed it!
    It's a chicken/egg call. I'll split the difference with ya! The DLC coating wears, but I still do not think the shaft is the primary failure point in that chain. I think the seal goes bad and allows fuel to wash the oil off the shaft. Things spiral down from there. If OEM tolerances are anything like ATs were, I can see why failures are so hit/miss.
    Cheers,
    KS
  33. #193
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    Reading the beginning of this thread was kinda sad and frustrating. Oh how much was not common info in 2018 lol. People buying evap hoses n shit trying to fix that. I just want to hop in my time machine and go back to comment "HPFP!!"
    those are all the tell tale signs on any of these cars. Even older audis had the same issue.
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
  34. #194
    Jul 26 2018
    Humidity, NC
    Quote Originally Posted by Audibellybutton View Post
    But even then they probably still wouldn't believe you and still try the cheap, quick or easy options first!!
    It's human nature!
    Cheers,
    KS
  35. #195
    Jan 03 2009
    Iowa
    My stock one looked exactly like the left side. Scared me to death knowing the issues others were having....
    My left one was leaking. Right was "fine". Agree with you on failure mechanism. It can go along time, but when it goes, it goes. Like it almost "wears" out.
  36. #196
    Oct 20 2016
    Los Angeles/CA
    Swapped both mine out for new HPFPs today - already on the few starts it just sounds and feels a lot better. Hopefully resolved the issue for me. Sad that I only put 64k miles on it but it is an older car so perhaps age was more the factor for me. Also had to replace the coolant tank that had cracked and was slowly leaking - please no more for a year haha.
    Thanks to Audibellybutton for showing me some cheaper OEM pumps - saved me a couple hundred bucks!
  37. #197
    Feb 12 2023
    Miami
    Hey guys i’ve been having this issue for a little while and it seems to be getting worse. Sometimes if i leave the car off for 5 mins it’ll die immediately after firing up. Usually starts somewhat fine during cold starts. But if the car is off for more than an hour it’ll start then die right away or start really rough and die a few seconds later. I have to give it a good amount of gas in order to start properly. Once it’s running properly i have no issues. Drives and runs fine and everything. Only has an issue when starting. My question is even if it runs perfectly fine after it’s started, could the starting issue still be the hpfp’s?
  38. #198
    Oct 20 2016
    Los Angeles/CA
    Quote Originally Posted by PaoloLuvara02 View Post
    This was pretty much my issue - only a few times would it not be able to start at all. I was once stuck trying to start it for five minutes in my parking garage at work thinking I'd need to call a tow before it finally fired up. After starting, there was no issues and even the next time I started the car, it would sometimes be perfectly normal. After having a few more incidents like this though, I decided to swap them out entirely. Haven't had any hard or semi-hard starts since - but its only been four days.
  39. #199
    Jun 28 2019
    California
    Quote Originally Posted by snohman View Post
    Im glad I was able to help! your issue should be a thing of the past now, im willing to bet. But only time will tell. Good luck with everything!
    IG:@stolens6
  40. #200
    Feb 12 2023
    Miami
    Any updates? How are the new pumps treating you? Fixed the issue?
    - - - Updated - - -
