Results 1 to 4 of 4
    Senior Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6
    Billings, MT
    Cylinder 6 misfire 05 C5 2.7 allroad
    Had an issue with cylinder 6 misfire, swapped all plugs for oem plugs, coil packs replaced, issue went away, 2 weeks later cylinder 6 misfire only at high rpms. Thoughts? It's driving me mad especially since we are on a 7 hour road trip
    Sent from my XT1650 using Audizine mobile app
    Clarice
    JHM intake spacers, DIY intake flapper mod, ported TB, heat wrap IM, 034 motor mounts, 15mm wheel spacers, CustomCAI, ZimbuTune, A8 D2 exhaust manifolds. soon to be VinnyS DP's, custom Catback straight pipe exhaust, magnaflow resonated xpipe. https://www.instagram.com/raudi.audi73/
    Feb 07 2008
    04 Silverado V8, 06 Touareg V8, 03 RS6 V8TT, 01 allroad, 01 A6 6MT
    The boonies, near Seattle
    Try moving coil packs again. If not, Id suspect injector or a wiring issue.
    -dre
    Oct 05 2015
    Billings, MT
    New injectors already, going to get all new fcp euro 2.0t coil packs and plugs, going to change the valve cover gaskets, still trying to figure out if I have to remove timing belt, and cam shafts just to replace the damn gaskets to stop making into the injector tubes
    Clarice
    Oct 05 2015
    Billings, MT
    Noticed oil on the plugs and plug tunnel, So I am going to replace the gaskets on the valve covers, clean up the plugs and packs and try her again.
    Clarice
