Page 2 of 2 FirstFirst 12
Results 41 to 64 of 64
  1. #41
    Jun 08 2017
    london
    Why? Do you think the water is coming out of the cap? Is the cap faulty?
  2. #42
    Nov 02 2018
    Eskilstuna, Sweden
    I have read about ppl who has changed the cap beacuse of the "filterthing" thing is not operating well.
  3. #43
    Nov 02 2018
    Eskilstuna, Sweden
    So i followed the hard pipe towards the matrix hoses, and i found this U-Clip..removed it and saw pieces was gone from the housing....can air be sucked in and cause the overflow ?
    And a picture och expansion tank...
    https://imageshack.com/i/plU5OKcUj
  4. #44
    Nov 02 2018
    Eskilstuna, Sweden
    Its the coolantflange right ?
  5. #45
    Nov 02 2018
    Eskilstuna, Sweden
    I found this on the web...i got 2 plasitc pipes upwards, 1 for coolant and 1 for some sensor.
  6. #46
    Nov 02 2018
    Eskilstuna, Sweden
    Can the coolantflange suck air inside and "block" all of this....its kinda cheap to but its a pain to change when i see the youtube videos
  7. #47
    Established Member Four Rings Blazius's Avatar
    Mar 15 2018
    Romania
    What do you mean block all of this ? If something wouldnt seal tight you would be dripping coolant too.
  8. #48
    Nov 02 2018
    Eskilstuna, Sweden
    Quote Originally Posted by Blazius View Post
    I mean if its because i got the overpressure in the expansiontank if the flange sucks air...
  9. #49
    Nov 02 2018
    Eskilstuna, Sweden
    One other thing, the temperature take about 15min at idle to even starts to move at all.
    When it comes up to 90, it stays there so probably its working and prevent overheating.
    Its a new thermostat and no leakage.
  10. #50
    Nov 02 2018
    Eskilstuna, Sweden
    Can the new thermostat be faulty ? since the temperature takes ages to show on the gauges.
  11. #51
    Senior Member Two Rings Ryanic's Avatar
    Jun 03 2013
    Minnesota
    Quote Originally Posted by Fredofrance View Post
    I've found our cars take awhile to warm up, especially just idling. 15 Minutes idling doesn't seem unreasonable.
    If replaced your thermostat recently then its most likely good (Yes a new thermostat can fail or be faulty out of the box though, which is why its nice to put it in some boiling water first to see if it works).
    If your car comes up to temp 90C and stays there while driving in cold weather (<40 degree Fahrenheit) then it should not be your thermostat. If it comes up to 90C while idling and then your gauge goes down while driving you have a bad thermostat that's stuck open or failing to close properly
    You can also use the secret climate control menu by hitting the up fan direction and the recirculation Button at the same time. This will display a 1C on your climate control. Use the up and down temperature buttons to go to 49C and then hit the recirculation button to select 49C. This will tell you your actual coolant temperature.
  12. #52
    Nov 02 2018
    Eskilstuna, Sweden
    I just measured my Coolant Temperature Sensor.
    Cold = 2,8kOhm (should be around 2kOhm at 20C Celsius)
    Warm = 1,4kOhm (should be 200Ohm-300Ohm at 80-90C)
    I think i must change it :P
  13. #53
    Nov 02 2018
    Eskilstuna, Sweden
    Update again, i changed the Coolant Temperature Sensor and the Coolant Flange. The change went well and i filled up with coolant and started again.
    It took about 5-10 mins and it was up to 90C, but no hot air.
    Opened the matrix hose and bled the system. Sill no heat, i think its more air inside.
    And upper/lower radiator hoses are about 35C.
    After a while the gauge was about 110C, but 85 with a lasertemp at the tempsensor hose ?!
  14. #54
    Nov 02 2018
    Eskilstuna, Sweden
    How do i know if the waterpump is broken ? i dont wanna change it if its not faulty.
    Other of my friends says headgasket, but i dont have those symptoms.
  15. #55
    Jun 03 2013
    Minnesota
    Okay so you've changed,
    Thermostat,
    CTS,
    Coolant Flange.
    Engine gets up to 90C while idle, and stays 90C while driving? Or is it still showing 110C after awhile. 110C is way too hot....
    What does the climate control menu say 49C (See my previous post about how to do it) when the car is fully warmed up
    Bleed bleed bleed. You've opened the system in many different places now. Make sure ALL of the air is out. This can take many different methods to accomplish over a couple days. Have you ONLY bled from the heater core hole? On the 2.8 There is an allen bolt bleed spot on the front of the engine... Not sure about the 1.8. Bleed from all of the different places the 1.8 allows you to do so.
    Is the car still bubbling and spitting coolant out the overflow hole of the expansion tank?
    Is the system getting pressurized? Do you hear any gurgling from the heater core when reving the engine and taking your foot off the gas?
  16. #56
    Nov 02 2018
    Eskilstuna, Sweden
    Hi Ryanic, when the car is idle i got 90C+ after maybe 5-10 mins.
    I think i have an bleed spot on the hardpipe, and one beside the coolant temperature sensor.
    I think i have heard small gurgling from the heatercore the other day when i switched from HI to LO.
    I have removed the glove compartment just now and looked at the flaps, it seems ok the arms are moving.
    Todo tomorrow:
    *Check the Climate Control menu.
    *Bleed, bleed, bleed.
    Thanks again.
  17. #57
    Nov 02 2018
    Eskilstuna, Sweden
    So i have idle the car and went into the menu 49C, its a little slower than the gauge...i turned it off when the 49C read 100C, strange part is that i dont have none of the 2 hoses into/from the heater core hot now...i did not had the time to bled today.
    It must be more air ?
  18. #58
    Nov 02 2018
    Eskilstuna, Sweden
    One other thing. When it was 100c and turn the car off, I have about 75-80c after 2minutes. ..
  19. #59
    Nov 02 2018
    Eskilstuna, Sweden
    SOLVED Info abut this: it was the waterpump, changed it at a local store for only 380 and a expansion tank. I got heat and all is good:)
  20. #60
    Mar 15 2018
    Romania
    dayum, 380 for a waterpump and expansion tank?
    2000 B5 A4 Avant FWD Manual - Sport package
    NA ARG Block - 10.3 CR | AEB Head w/ NA valve cover and Coils | AWT Intake | SAAB 370cc | China T3/T4 57 Trim ~9 cm | Custom 2.2 inch uppipe | Ford Mondeo 2.0 TDDI FMIC | Custom 3.1 inch Vband DP | Self ME7 Tuned
    https://www.audizine.com/forum/showt...rbo-Conversion
  21. #61
    Nov 02 2018
    Eskilstuna, Sweden
    No, for the labor..they had to change some rounded torx screws, 1 vaccum hose, change of expansion tank and the waterpump.
    The waterpump (SKF with metal shovel) costs 30 from Germany
    Expansiontank costs 5
  22. #62
    Mar 15 2018
    Romania
    Shouldve done it youself, changing the waterpump is not a big deal :P specially on 058 blocks.
  23. #63
    Jun 08 2017
    london
    What was wrong with the water pump? All the symptoms were there was flow? Weird??
  24. #64
    Nov 02 2018
    Eskilstuna, Sweden
    Well, i got no knowledge or space, just outside to do it..so....no big deal.
    - - - Updated - - -
    Quote Originally Posted by scaphan View Post
    The impellar fell out when he took out the pump :P and it was in 2 pieces.
