Results 1 to 2 of 2
    Stage 3 Forum Advertiser Four Rings Jake@JHM's Avatar
    Aug 31 2011
    MK7-GTI-APR-STG2-Grand-Cherokee-R6-Raven-IRON-1250
    Lathrop
    Thumbs up AVAILABLE NOW! JHM Performance B9 A4-A5-Allroad 2.0T 3" High Flow Cat Pipe
    Introducing the JHM B9 A4-A5 ALLROAD 2.0T 3" Cat-Pipe!!!
    Following the success of our performance exhaust components for the B8 2.0T, we are proud to release our High Flow Cat-Pipe for the B9 A4-A5-Allroad with the 2.0T. If you are looking to get the most performance out of your stock turbo B9 2.0T, this is the HFC Pipe that you need!
    WHY REPLACE YOUR OEM CAT PIPE?
    The first restriction in the OEM cat-pipe is the huge catalyst sitting right behind the turbo. The second major restriction is the diameter of the pipe. as it chokes to about 2.25 inches or smaller before the downpipe flange. This problem is solved with our JHM 3" HFC which removes exhaust flow restrictions allowing optimal performance and retaining perfect OEM fitment.
    FEATURES:
    +20-25 HP with appropriate Downpipe and ECU Software (We recommend APR, contact us to schedule your tuning appointment).
    Larger, 3" Mandrel Bent System for optimal flow and performance.
    American T304 (.065) Stainless Steel for optimal durability and longevity.
    CNC Laser Cut Flanges for perfect fitment, every time.
    Stainless Steel O2 Bung.
    High Flow Catalyst
    Plug and Play OEM Fitment.
    PROUDLY MANUFACTURED IN THE USA WITH USA SOURCED MATERIALS
    Click HERE To Order!
    If you have any questions or would like help placing your order, don't hesitate to contact us!
    Sales@JHMotorsports.com
    209-968-0077
    Jake
    Stage 3 Forum Advertiser Four Rings Tech/Sales@JHM's Avatar
    Jun 04 2008
    The Fastest Audis
    California
    Thanks for all of the orders! Let us know if you have any questions
