Results 1 to 7 of 7
    Jan 12 2006
    Nebraska
    Timing Chain or Belt
    Is the 2012-2013 2.5 TTRS motor a timing chain or belt and does it need replacing? Is this an interference engine or not?
    Thanks
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    Chain, and I would assume its an interference engine almost all modern engines are.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Junior Member Two Rings
    May 11 2018
    Woodstock,ga
    in the 2012tt what mileage should this be changed? or just inspected? i have 82000 now
    Established Member Two Rings A6S4's Avatar
    May 19 2008
    Houston, TX
    110,000 is suggested limit
    2022 RS5 SB (now); 2018 RS5 coupe (now); 2018 TTS; 2013 A6 S-Line; 2013 TTS; 2008 A8 Sport (SWB); 2008 A6 4.2 S-Line; 2006 S4; 2001 A6 4.2 S-Line; 2001.5 S4 -- R.I.P., thanks to FedEx...; 1997 A6Q; 1994 90CS; 1993 100S; 1992 80; 1990 80; 1986 5000S -- yeah, 16 of 'em! Over 1M miles in Audis...(My wife has one ring, my cars have 4 each...)
    Aug 18 2016
    Arizona
    What is the usual cost to have it replaced by someone reputable to make sure it is done right?
    Nov 30 2023
    Munich
    Quote Originally Posted by krue92 View Post
    Thanks
    The timing chain generally requires less frequent replacement compared to a timing belt, but it's always a good idea to check your specific vehicle's maintenance schedule.
    As for whether it's an interference engine, yes, it is. So keeping an eye on the timing chain and following the recommended maintenance intervals is key to keeping your engine running smoothly.
    Junior Member One Ring
    Oct 20 2021
    Round Rock Texas
    Quote Originally Posted by ProfileTrader View Post
    my 2012 GTI 2.0FSI "CCTA" timing chain interval was 80k mi-- you need to replace the much-recalled tensioner if it has never been done, plus guides etc. IIRC the parts kit at ECS tuning (OEM) was $800 something and the install is tedious because you need to glue the chain cover on etc; most shops this will be $1200 in labor maybe a bit more. Not a driveway job typically Lol
    my 2012 TTS has the EA-113/K04 2.0TFSI but it has a belt; belt interval is the same, 80-90k.
    history of the TFSI engine here so you can look up your engine code: https://eeuroparts.com/blog/audi-2-0...omplete-guide/
    Cheers
    Alex
    sunny Texas
