Originally Posted by
dnchattan
That sounds about right for when LC activates.
While the car seems to indicate it’s “safe” to go full throttle by removing the redline restriction, generally I wait until at least 160 for any full throttle pulls. Especially in cold weather I use this as a rough approximation when the transmission is warmed up too (since I don’t have a gauge for tranny temp). The DSG does *not* like being used hard before it is warmed up (esp when using manual shifting). I’ve tried launching in previous DSG cars while it was too cold and the shifts felt like something was breaking.
That’s all I’ll add here in case it is useful to you or anyone else- but in the end it’s your car - drive it however it makes you happy
Oil temp needs to be above 70c (160f) for launch control to be enabled. Oil temp can take upto 5 miles to get to that temp from cold dependent on outside temps and driving conditions. Fortunately for the stupid that live amongst us, Audi build in some protection measures. The first restriction is engine performance (rev restriction), this is then followed by Launch restriction until warm.
I'm the same, won't bother with 4000rpm + performance from cold until I see the oil at 70c (160f) - it's just common sense.
There's no teaching stupid.
