Results 1 to 2 of 2
    Established Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    What Pressure washer tip?
    I just got a 2900psi gas pressure washer. Should I use the 25 or 40 tip?
    2011 A4 Avant Prestige S-Line
    Feb 02 2017
    Beaverton, OR
    Either will work. The 40 is a wider spray with a less pressure while the 25 is a narrower spray with more pressure. I usually use 25 for quick rinse before wash and use the 40 to rinse soap off.
