EVERYTHING YOU NEED
FOR THE POWER YOU CRAVE
Enhanced power delivery, unique safety features and exhilarating response at your disposal, the Revo Performance Pack delivers much more than peak power figures. Whatever drives you, the Revo Performance Pack has it all. Engineered to perform, only Revo offers a complete tuning solution specifically designed for your vehicle.
KEY COMPONENTS
Air Intake System
Performance ECU Software
Intercooler Pipe Upgrade Kit
Turbo Muffler Delete
Intercooler
Downpipe
OEM+
AIR INTAKE SYSTEM
Get impressive performance benefits without compromising on the factory look of your engine bay. Revo OEM+ Air Intake Systems utilise the existing air box, replacing the restrictive ir filter and intake hose with parts precisely engineered to reduce turbulence and improve airflow.
KEY FEATURES
Increased Airflow by up to 20%
Three-layer foam filter
Stepped Silicone Hose
PERFORMANCE ECU SOFTWARE
Revo performance Software is designed to safely enhance the driveability of your vehicle, giving access to more power and torque throughout the rev range while maintaining the extensive factory safety mechanisms. Revo Software offers a perfect balance of performance, economy, longevity and safety so you can drive harder, for longer.
INTERCOOLER PIPE UPGRADE KIT
The Revo Intercooler Pipe Upgrade kit offers incredible power and torque increases by reducing charge system resistance and improving flow compared to the restrictive stock pipework. Featuring larger internal diameters, fewer restrictions for smoother airflow, and optimised routing, the turbo meets less resistance and can perform more effectively.
KEY FEATURES
Increased internal diameter
Smoother airflow
Fits Revo and stock intercooler
Water Meth Bung
DOWNPIPE UPGRADE
The Revo downpipe upgrade is designed to replace the restrictive OEM component with a hi-flow 200 CELL Sports CAT, allowing exhaust gasses to flow much more freely. Designed alongside Revo Performance Software, it forms an important part of the Revo Performance Pack, unleashing more potential power from the engine.
KEY FEATURES
Maximises flow
Lighter than OEM part
British manufactured
De-CAT or Sports CAT option
TURBO MUFFLER DELETE
The Revo Turbo Muffler Delete offers a high-quality single piece replacement for the OEM part which allows for smoother uninterrupted air flow, increasing throttle response and providing improved turbo acoustics.
KEY FEATURES
CNC machined
Single piece design
Anodised black
Improved boost response
Increased turbo sound
INTERCOOLER UPGRADE
The Revo Intercooler was built around a simple principle; create a cooler that can keep up with your demand for power. Unique design features lower intake air temperatures, minimise pressure drop and allow the engine to produce impressive power and torque with Revo Software, ensuring you get consistent performance when you need it most.
KEY FEATURES
Unique Core design with 4 fin types
Fully Cast End Tanks
140% Increase in Surface area
Up to 90% Increased Core Volume
Bar and Plate Core
STOCK
Power 248 HP
Torque 272 TQ
0 - 60 MPH 5.8 S
0 - 100 MPH 14.5 S
PERFORMANCE PACK
Power 331 HP
Torque 345 TQ
0 - 60 MPH 4.3 S
0 - 100 MPH 10.3 S
CLICK HERE TO FIND YOUR NEAREST REVO DEALER!
Revo Software is available for the B9 A4 / A5 in Stage 1 and Stage 2 configurations, with and without the Performance Pack. The best value is to purchase the entire Performance Pack, but individual components are available seperate if desired.
CLICK HERE TO VIEW THE FULL REVO PERFORMANCE PACK PAGE!
