Results 1 to 8 of 8
    Senior Member Two Rings Sick S4's Avatar
    Apr 14 2016
    Charlseton SC
    Need help... Street Shield Install
    Hey Guys
    Plan was to change oil and install street sheild. Oil went well as usual but can not install street shield because my M10 Triple square bolts holding the power steering shield are completely shaved... guess the consequences of being low. Anyhow any suggestion on how the hell to get these out? Note: I tried easy out and no way that is going to work.
    All suggestions or crazy ideas are welcome.
    - Brian
    Apr 14 2016
    Charlseton SC
    Btw here are the pics of the heads of the bolts...
    Sep 14 2018
    2015 S4 Daytona Grey
    Michigan
    Did you try easy out in a screw not pictured here? Because the screw head would have to be perfectly cleaned out and the proper size hole drilled into it so you can use your extractor.
    Apr 14 2016
    Charlseton SC
    Quote Originally Posted by Mac's View Post
    Mac, itís not that easy out wouldnít have worked. The problem is I canít get the car high enough off the ground to get drill and bit to fit under the car to drive it straight in. I should have been more specific.
    Jul 02 2018
    Yeg
    Hey sick s4 I was in similar situations before, I installed ecs street shields for pan and tran....
    Try to break the tension of that bolt with a needle nose or locking pliers they work best
    or
    Use a small screw driver with the extractor bit on the end, if you're really desperate
    just brainstorming...
    Active Member Two Rings audi_403's Avatar
    Mar 04 2017
    2011 s4 2015 a6q 3.0 1993 Urs4 1987 4000q20vt 1984 4000S
    sw Ohio
    Keep it simple, use a chisel and a hammer.
    If you donít know what that means see the link at about the 4:49 mark
    https://youtu.be/WDOWPekMX44
    Apr 14 2016
    Charlseton SC
    Thanks guys. I will try these out and let you know how it goes.
    Apr 20 2011
    Hackettstown, NJ
    It looks like theres just a bunch of shit built up in the head, i bet you can get a pick and pick some of it out and be able to get the triple square bit in there
    2012 Phantom Black Pearl S4 6MT / B&O / Sports Diff / 3G+ Conversion
    -19" S4 Peelers w/ 255/35/ZR19 Michelin PSS, 034 25mm Solid Rear Sway Bar, H&R Sport lowering springs, AWE Track Exhaust w/ 90mm polished tips. P3 Multigauge w/ Track Pack
