Results 1 to 28 of 28
    Senior Member Two Rings slobdogg's Avatar
    Sep 24 2018
    Fairfax, VA
    Reliability on 4.0TT
    I am in the market for a 2016 S7. I apologize if this has been discussed but I did attempt a quick search for Reliability and found the following (I am not a gearhead so this may not all sound correct)
    - Turbos fail. Seems to be a regular issue for the 2013 MY but fixed after that. But people with tunes seem to experience a higher failure rate.
    - Turbo oil screen. Whatever it's supposed to do, it's not doing. Is it worth fixing this prior to failure?
    - PCV valve. Not really sure what this does but everyone recommends to fix this when replacing the turbo oil screen.
    All in all, that's about it right? With the turbo problems, the issue would be apparent when shopping around. Are there other hidden issues that are common? Things I should ask an inspector to keep watch for?
    Thank you guys for your wealth of knowledge. I've got another few months before I make a purchase (if I can maintain some patience). I want to wait for the 2019 models to hit the dealerships, and for the PODS recall to be sorted out. I expect that once those two things happen the price of a 2016 S7 will drop 10%. Is that reasonable? Right now, one with driver assist and comfort package, <40k miles is $60-65k. I would like to get the deal for $55k or less.
    Senior Member Two Rings aFOURstance's Avatar
    Jan 30 2011
    '04 DBP R32 PTE6266 Turbo, '01 Nogaro S4 Stg 3 & Bagged
    FAIRFAX, VA
    Skip the S7 and get an RS7, trust me
    Life is too short to drive boring cars.
    Sep 24 2018
    Fairfax, VA
    Quote Originally Posted by aFOURstance View Post
    It's hard to justify the extra $15k for a car two years older, with power that I won't use. It's a bit *too* aggressive for having two kids under six years old. But, believe me, the internal debate rages on.
    And - what's up Fairfax!
    Mar 13 2018
    Quote Originally Posted by slobdogg View Post
    I have a 3 month old and he thinks that the RS7 is just fast enough.
    2017 Audi RS7 APR Stage 1
    2019 McLaren 720s
    2022 Tesla Model S Plaid
    Forever in my heart but no longer in my garage:
    2017 Acura NSX
    2015 Alfa Romeo 4C
    2013 Lotus Evora
    2009 Porsche 911
    Veteran Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    With an oil change interval of 5,000 miles, and changing out the oil return screen and oil separator prior to 40 or 50k miles, (as well as the lines to the turbos), I would expect that you'd be fine. kpriv just completed his turbo swap at 24k on his S7, and his oil screen had minimal buildup, and all of his lines were pretty clean as well. They were all replaced with new, but I think 24k miles may be a bit too early to swap out the screen and the lines just based on that one data point. WhiteWhiteS7's thread for the DIY for the oil separator is excellent, and also gives us another data point with a bit more build-up on the screen at 64k miles, but not completely clogged.
    There are a few folks on here who've blown more than one turbo, but it appears their shops didn't change out the oil return screen or check valve, which just sets up the new turbos to be starved as well.
    2016 S6, mythos black, RS7 turbos, MRC inlets |Akrapovic exhaust| AMS downpipes and intercooler |Eventuri intake| Loba HPFPs |Tial wastegates| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights, OEM Euro tails |Sound: Navtv Zen-v preamp, Helix DSP Ultra, JL HD900/5 driving JL10W3 sub and Hybrid Audio speakers.
    Sep 24 2018
    Fairfax, VA
    Quote Originally Posted by OlyS6 View Post
    I saw that video and it's far above my comfort zone. Ballpark, how much would dealership charge to change the screen, separator, and PCV valve?
    2016 S7 Daytona Gray Pearl
    Sep 24 2018
    Fairfax, VA
    Took your advice and test drove an RS7 today at Carmax. Holy sssss. I'm still grinning, but it was way too much power for me. I had a blast driving it.
    Veteran Member Three Rings DocTJ's Avatar
    Jul 29 2016
    PA
    hahahaha nice!
    so s7?
    Prior: '16 A7 3.0T Prestige, '16 S7 Prestige, ‘17 S8 Plus, '18 Porsche Panamera Turbo S - E Hybrid
    CURRENT: '23 Nardo Gray RS5, Carbon Black Optics, '18 Q7 Prestige
    My S8 modified exhaust: https://www.audizine.com/forum/showt...Muffler-Delete
    Jul 29 2014
    2016 Audi A3 2.0T
    Clearwater/Florida
    Motor mounts are problematic and expensive to replace.
    Mine were replaced at 28k miles and I have another one giving a fault code at 48k miles.
    Nov 03 2016
    CA
    Quote Originally Posted by brad281 View Post
    Are there any stronger aftermarket ones?
    034 motorsports makes high quality replacements for the B8 cars.
    2011 Audi S5
    (GONE) 2011 Audi A5 2.0T [APR STAGE 2] [034 MotorSports HFC]
    Jul 29 2014
    2016 Audi A3 2.0T
    Clearwater/Florida
    Quote Originally Posted by brilliant_black View Post
    Not that I've seen.
    May 20 2010
    Turbos seem to be fail a lot due to oil starvation problems caused by the oil screens. Of course tuned cars would have it worse--the demands are higher.
    I've heard control arms being replaced within 40k-50k on some of these vehicles too. Bushings seem to go early.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Mar 26 2010
    US
    ....Turbos fail. Seems to be a regular issue for the 2013 MY but fixed after that. .....
    The Audi TSB for failed turbos runs from 2013 through 2017 and includes all the 4.0T models.
    There was one 2016 RS7 that had the turbos fail at around 18k miles on stock tune.
    "18,XXX miles, 100% stock, never tracked/abused, 2016 RS7 Performance": https://www.audizine.com/forum/showt...1#post13139207
    BMW M3 Competition X-drive
    Nov 03 2016
    CA
    Quote Originally Posted by wwhan View Post
    Wow that is such a downer. Seeing these threads is really pushing me towards an RS3.
    Yeah it's no where near as luxurious...not even close, but if anything does break it's a lot easier to work on.
    I really do love the 4.0T cars still they're so badass. Hopefully the new revision for the oil screen solves the blockage problem.
    2011 Audi S5
    Sep 24 2018
    Fairfax, VA
    I'd read that thread, but it wasn't until today that I considered how I would feel if I had to shell out $10k to repair a known issue. Given this information, I would 100% purchase an extended warranty for the car. I hope that would give me no issues if a claim were to arise from these turbos.
    Veteran Member Three Rings Avned's Avatar
    Apr 20 2016
    Las Vegas
    Yes. Don't buy this car without extended warranty. My extended warranty has paid out over 20k in repairs since I've hit the 50k mark. I love this car but damn the repairs.
    '22 RSQ8
    '13 S6 DS1 stage 4 flex fuel - SOLD
    Sep 24 2018
    Fairfax, VA
    Quote Originally Posted by Avned View Post
    Would you risk buying Non-CPO with extended warranty, knowing that Audi is out of the picture as far as warranty claims go? I would feel more comfortable knowing Audi sold me an Extended Warranty, even if they aren't the ones to underwrite it.
    Apr 20 2016
    Las Vegas
    Honestly, I bought mine non-cpo with CarMax extended warranty. They covered all repairs. The only one they didn't fully cover was both turbos since only one went out. Despite the recommendations from my shop they still only did one. Other than that, I've been really impressed with their warranty. I can't speak for other 3rd party warranties of course.
    '22 RSQ8
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    What about back washing the screen through the appropriate turbo lines with an engine oil cleaner, at each oil change, rather than a complete strip down, to get to the screen? Is this possible?
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Nov 06 2012
    Pennsylvania
    Quote Originally Posted by MadAboutCars View Post
    The oil flows through a check valve (one way valve) then the screen and then it heads into the turbo. The one way valve wont allow the system to be back washed. Only one way and that's to pull the screen.
    Current daily- '13 S6 - EPL stage 2
    Backups '08 A4 2.0 and '10 A6 3.0t
    Past fleet
    '07 RS4 misano red on black
    '05 S4
    '06 Jetta 2.5
    '01 TT 225
    Aug 27 2015
    New Zealand
    Quote Originally Posted by brian_216 View Post
    There goes that idea. Thanks for letting us know.
    Mar 13 2018
    Has anyone that has run a shorter OCI (5k miles or so) blown a turbo? I don't recall reading about anyone in that situation. If that is the case, if a car has short OCIs since new, it is possible that this could also prevent or at least significantly delay the build up of debris on the oil return screen.
    2019 McLaren 720s
    2017 Acura NSX
    2015 Alfa Romeo 4C
    2013 Lotus Evora
    2009 Porsche 911
    Sep 24 2018
    Fairfax, VA
    Quote Originally Posted by phaphaphooey View Post
    I think in the main thread someone said they changed every 5k and still blew turbo.
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Has anyone thought about deleting the factory screen (or taking the mesh out of it) and installing something like this X 2 along the turbo lines? Would be so much easier to check/clean with each oil change. I have no idea what micron filter we would need though, but to be fair, either does Audi lol.
    http://www.turbosmartdirect.com/Prod...4AN-Black.html
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Nov 06 2012
    Pennsylvania
    Past fleet
    '05 S4
    '06 Jetta 2.5
    '01 TT 225
    Veteran Member Three Rings 3g_bishi's Avatar
    Mar 03 2016
    07 a6. 13 A7, 13A6, 08 A8LW12, 16A3, 15RS7
    DFW
    2015 rs7
    60k miles and no turbo issues “knock on wood”
    But I do have a cyl #3 misfire as a lot is other 4.0t owners are experiencing.
    1 bad lower control arm
    That’s it. These are reliable cars. Oh mines flooded btw from Houston hurricane.
    Oct 27 2013
    2016 S6 52k miles, tuned ecu/tcu stage 2 since 20k miles
    One wheel bearing under warranty.
    One secondary 02 sensor
    Have Audi extended warranty to 120k (Fidelity?)
    Following 10k factory service interval.
