Results 1 to 9 of 9
Thread: AC Issues
    Veteran Member Four Rings Whitee's Avatar
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    AC Issues
    Just got my VCDS and scanned my car. Have a few pictures showing the codes. I replaced my A/C Pressure switch last night and the car still doesn’t blow cold at idle, only while moving.
    Does this point to an electrical issue of some sort of I replaced the sensor and it’s still not working? Any input would be appreciated.
    Apparently I can’t post a link with the new iPhone .
    Two codes 00256 Implausible Signal to AC Pressure Sensor
    01592 Air Quality Sensor No signal/Communication
    Here is the information:
    Address 09: Cent. Elect. Labels: 8K0-907-063.clb
    Control Module Part Number: 8K0 907 063 P HW: 8K0 907 063 P
    Component and/or Version: BCM1 1.0 H25 0380
    Software Coding: 26001091063CAF010000080300003D0D4F1C52080001016100 0000
    Work Shop Code: WSC 06325 123 12345
    VCID: 3C21375D16620AB782D-8068
    4 Faults Found:
    03020 - Local databus 2
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 96
    Reset counter: 195
    Mileage: 155360 km
    Time Indication: 0
    Date: 2018.09.09
    Time: 20:24:00
    00256 - A/C Pressure/Temperature Sensor (G395)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 234
    Mileage: 155372 km
    Time Indication: 0
    Date: 2018.09.10
    Time: 09:48:00
    01592 - Air Quality Sensor (G238)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 234
    Mileage: 155372 km
    Time Indication: 0
    Date: 2018.09.10
    Time: 09:48:00
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 234
    Mileage: 155372 km
    Time Indication: 0
    Date: 2018.09.10
    Time: 10:12:00
    Address 08: Auto HVAC (8T1 820 043 AQ)
    20:04:30
    ERROR Refrigerant Pressure (G395)
    3.0 Compr. Shut-Off Request
    19.0°C Outlet Temp. Evaporator (G263)
    ERROR Air Quality Sensor (G238)
    ERROR Refrigerant Signal
    From my understanding, if the sensor reads below 1.8Bar than the system throws a fault. Could getting the system refilled take care of this, or is it def related to wiring? I noticed on my old sensor it had white residue on it which leads me to believe it was leaking....
    2010 Prestige Ibis White S4
    Rock Euro | P3 Scanguage | EPL Stage 2
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Ran the block scans based on the Ross Tech help information which is posted at the bottom.
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Anyone?
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Sorry guys for being annoying but does anyone know where to go from here? Would like to get this taken care of. I can hear a loud hissing on a cold start that goes away after the sai warm up is done. I’ve also seen where the high pressure switch could be the culprit?
    Mar 21 2015
    Did you clear all the codes after the install?
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Yes I did. Same ones came back.
    Aug 15 2015
    1199 Panigale
    San Antonio , TX
    I had the same issue although possibly not the same cause. My 8.5 would not blow cold at idle, only when moving, also the fans would operate intermittently . I found that a loose connector was the cause. I snapped the connector back together and all was good. The connector is located under the plastic cowling that covers the brake reservoir.
    hope this helps
    Sep 10 2012
    London
    What pressure sensor did you put in? I had to change the one on my A5 and read hundreds of threads about it first m. Many pointed to the replacement not working when using the exact same part number but a slightly older revision than they should have - usually due to buying on eBay.
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Quote Originally Posted by Adamantium View Post
    I got it from fcpeuro
