Results 1 to 10 of 10
    Oct 06 2018
    Philadelphia PA
    Want a 2009 a4 b8 how do I know its good?
    I found a 2009 a4 b8 with about 118,000 miles and I know about these engnes and that they can have the oil consumption problem. now this car is out of warranty private seller when I asked them about it they said that they did a oil change recently and nothing came up now error message. now I want to know do all engines have this problem? could this car not have this problem? If I go and check out the car how can I see that it might be burning oil ? scan ecu? check tail pipe? Thanks
    Established Member Two Rings NYDCB's Avatar
    Aug 22 2016
    Washington, DC
    That MY at the very least would require:
    Timing chain/tensioner/guides upgrade
    Engine de-carb
    Water pump replaced
    High pressure fuel pump replaced
    Look for a charred tail pipe. Put your finger in there (after it's cooled) and see if there is oil residue inside the exhaust pipe. I'd be surprised if there wasn't.
    Established Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    I'm as cool as a cucumber in a bowl of hot sauce.
    Jan 01 2012
    2004 A4 Avant
    CO
    Quote Originally Posted by Matt2408 View Post
    Get the vin and verify with Audi that the stage 2 oil consumption fix was done. If it hasnít been, move along and keep looking for another car.
    | 2004 A4 Avant | Gloss Dark Grey |
    | 2.7t K04 swap | 034 RSB | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
    Oct 06 2018
    Philadelphia PA
    Quote Originally Posted by jjvwg View Post
    If I take it to a audi dealership or a mechanic in general and do a compression test will that show if theres a oil consumption
    Registered Member Three Rings Nano909's Avatar
    Jul 25 2016
    California
    Do yourself a favor and skip it.
    Active Member Three Rings
    Jun 17 2018
    Colorado
    Not the case. Oil rings are separate from compression ring.
    Jun 03 2010
    2017 VW Golf Sportwagen 4motion
    Fort Myers, FL
    Quote Originally Posted by NYDCB View Post
    Engine de-carb
    Water pump replaced
    And upper control arms and struts and shocks
    Sent from my SAMSUNG-SM-G891A using Audizine mobile app
    Jun 17 2018
    Colorado
    So you could buy this one with 90k miles. ;-)
    https://www.audizine.com/forum/showt...issues-to-keep
    At least then you'd candidly know what's currently wrong with it.
    Cheers!
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    I would take a pass on any used B8 if the oil consumption has not been addressed no matter if the car has low km or how well the owner took care of it.Its like a ticking time bomb.
