Results 1 to 2 of 2
    Aug 31 2018
    PA
    2014 S6 rough shift into first
    Just purchased my first Audi and my first experience with a DSG transmission. I'm noticing that the shift down to first is often a bit rough when coming to a stop. I thought maybe this was normal for a DSG because my manual transmission cars have sometimes been a bit more clunky going into first but spoke to a couple of friends with Audi DSG transmissions and they didn't think this sounded normal.
    I'm particularly concerned because, immediately prior to buying this car, the car threw a code and went into limp mode (3rd gear only). Seller was completely up front with me, I spoke to the mechanic that looked at it. Fluid and filter had just been changed a couple hundred miles before. Fluid and filter was changed again as part of the diagnosis and nothing seemed out of order. Car is performing fine other than this somewhat rough shift into first gear. Both my local Audi dealer and the Audi mechanic on the seller's side indicated to me that they don't think they've ever needed to replace one of these transmissions so I'm hopeful that there isn't anything horribly wrong.
    Borrowed a vagcom cable from a friend - no transmission codes. Car has APR stage 1 ECU.
    My question is, does anybody else experience a rough shift into first? Any thoughts as to what might be wrong, if anything?
    Registered Member Two Rings rey_reysA7's Avatar
    Sep 21 2018
    '84 VW GTi
    CO
    Quote Originally Posted by sbaker25 View Post
    I was trying to replay to you and some how made a separate thread. https://www.audizine.com/forum/showthread.php?t=830926
    Sent from my G8142 using Audizine mobile app
    Current Cars 2012 Audi A7 1984 VW Rabbit GTI
    Sold Cars '78 Rabbit '87 Scirocco '99.5 Jetta 2.0 '00 Jetta VR6
