Results 1 to 7 of 7
    Nov 22 2005
    socal
    Cracked wheel spoke
    Not sure how this happened. Had a new tire mounted/ balanced and a 4 wheel alignmenr today. Drove 1mile to grab lunch afterwards and looked at the wheel with the new tire and notcied this crack.
    I had the car detailed last week and am 100% positive the crack wasn't there.i had not driven the car since the detail as the tire I replaced today was showing wire.
    I called around and showed pic and seems is not repairable.
    Aug 12 2015
    Minneapolis MN
    I would assume whomever did your alignment screwed something up. Problem with those situations is unless you catch it directly afterwards no way to prove etc.
    2017 Audi RS7 Glacier White w/ Black Optics
    2014 Porsche Panamera Turbo Executive Amethyst
    Nov 22 2005
    socal
    Yes that's certainly possible, although I'm not sure what they could have possibly done that would crack a wheel. Even if they dropped it that shouldnt crack the wheel, and there is no damage or scuffs anywhere near the crack.
    Veteran Member Three Rings gk1's Avatar
    Aug 06 2014
    2014 SQ5
    NJ>CO
    Are those wheels painted or powder coated?
    2015 S6 Quartz Gray
    Black, Carbon, Night, Cold, DA, ACC, VCDS lowered, 034 Trans mounts, EuroCode Alu-Kreuz, {APR v1.1 & TCU}, Rohana RF2 20x9, 11.660@114.83 (4615lbs.)
    2014 SQ5 Glacier White
    Black Nappa, Carbon, B&O, NAV, 21's, stock 13.527@102.11 (4615lbs.)
    2012 S4 S-Tronic Monsoon Gray, Stage II 12.868@107.8 (4275lbs.)
    2008 A6 3.2Q S-Line Daytona Gray
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I 14.746@95.29 (3944lbs.)
    Nov 22 2005
    socal
    Powder coated
    - - - Updated - - -
    I'm not sure who did the powder coating I purchased the car CPO and the wheels were already black
    Aug 06 2014
    2014 SQ5
    NJ>CO
    Quote Originally Posted by kanahoot View Post
    Powder coated
    - - - Updated - - -
    Not saying this happened to you in particular, but I thought I read some posts where the powdercoating process if done incorrectly can cause cracks. It's a thought anyway. I know the powdercoating should not cause this issues, but there is always a possibility.
    2015 S6 Quartz Gray
    Aug 11 2016
    CA
    Sucks either way! Good luck.
