Results 1 to 14 of 14
    Apr 13 2014
    israel
    Need help car cutting off between 1.5-2.5k rpm
    I have problem with my car ..it is cutting off somtimes not all the time last time before one month and today at low rpm 1.5-2.5k rpm ..it is cutting 3-4 times like there is no fuel going to engine ..or no ignition ..
    I changed sparks plugs and installed tsi coils
    Changed the tune back to stage 1 that i used 1 year with no problem
    New fuel filter
    Pressure test found small leak and fixed
    Smok test no vaccum leak ..
    Anyhelp what to check more ..
    Veteran Member Three Rings m_haiser's Avatar
    Apr 24 2011
    Highland Green Allroad
    Oregon Coast
    shuts off off? or just misfires?
    Feb 23 2010
    Lehigh Valley
    Maf could be reading goofy. Do you have vcds?
    Apr 13 2014
    israel
    Not shuting off just cutting 3-4 times
    Yes i have vcds ori ... no faults codes
    Senior Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    Your going to have to log constantly to capture the issue.
    Could use a wideband 02 gauge to see if the fuel is leaned out when it happens.
    I rarely have a similar situation on cold starts if a drive immediately...
    Apr 13 2014
    israel
    Quote Originally Posted by JustManson View Post
    all the time i start it and leave it for about 3-5 m
    today i drived it with vcds blocks 15 and 16 when cutting off cylinder 2 showing max 15 all other cyl 0
    Established Member Two Rings poor.decision's Avatar
    Nov 04 2017
    E30 325is, E36 M3, W204 C300, C5 S6 Avant, B5 S4 Avant
    Still have factory cats installed? Had an issue where the cat broke up inside and the honeycombs would block the exhaust depending on how and where they moved. Caused the car to misfire, not rev, was Undriveable. If you have cats still installed I would suggest doing a back pressure test with a back pressure gauge using the pre cat o2 sensor bungs.
    Apr 13 2014
    israel
    It is gutted and catless with postcat o2 deleted
    Apr 13 2014
    israel
    Update drive it gard limp mode and abs lights 2 faults p1557 p0103
    Nov 04 2017
    Quote Originally Posted by milanocito View Post
    Iíll run them in my system at work tomorrow to see what I can come up with for you. I log all the codes and repairs in my system to have a reference guide to speed up my diagnostics. PM me the VIN so I can pull it all up.
    Feb 23 2010
    Lehigh Valley
    Positive deviation. Check your wg lines.
    Apr 13 2014
    israel
    The maf and pozitive deviation fixed ..
    I changed also the maf for cutting off and testing the car
    Apr 13 2014
    israel
    I drived the car about one week no problem ...but today i pushed the pedal and it start cutting about 4k rpm ...and then from 1.5k-4k rpm ...this car get me crazy ..i will move the spark from cyl 2 to another one and to check if cyl 2 will not missfiring or the missfire will move to the another cyl...
    Or to change the inject in cyl 2 ???
    Apr 13 2014
    israel
    Today faults come on
    P0300 and p0302
    I moved the spark from cyl 2 on cyl 3
