Results 1 to 3 of 3
    Registered Member One Ring bbeecher's Avatar
    Sep 24 2018
    Radiator Fan not coming on? Fan works, New Module.
    Replaced the Module and VCDS turns the fan on but car gets to middle temperature and fan still does not turn on.
    Any idea?
    Senior Member Three Rings egovreau's Avatar
    Sep 08 2015
    2002 VW Passat Wagon
    Renton, WA
    Do the fans come on when you turn on the AC?
    Did you try replacing the lower temperature sensor?
    It could also be that with the cooler temperatures, enough air flow is passing through the radiator that the temperature never gets high enough to come on.
    Sent from my SM-G965U using Tapatalk
    Sep 24 2018
    Quote Originally Posted by egovreau View Post
    High pressure sensor is bad or something so AC fan wonít come on. Itís 80 degrees here, temp is getting slightly past middle line. I replaced lower temp sensor, when I go into VCDS, I see there are two temperature readings for the engine, one says 45C and other 95C, did I get the wrong temp sensor? I can manually turn fan on with VCDS.
