Results 1 to 5 of 5
    Mar 02 2017
    Ann Arbor MI
    02 Allroad spongy brake pedal
    Pads and rotors are good. I've gravity bled the system multiple times but the brake pedal stays soft and spongy. Recommendations on what to do next?
    May 20 2010
    Maybe an issue with brake booster?
    2016 A6 TDI Prestige - S-Line, Black Optics, Driver Assistance, HUD, LED Headlights, Cold Weather, Warm Weather
    2003 allroad 6MT - STUKLR Stage 1, Hotchkis sway bars, RS4 engine mounts, Apikol rear diff mounts
    Apr 29 2009
    Quadzilla
    Longmont, CO
    i think there is a vacuum line that helps with the booster
    check that for cracks/breaks/leaks
    Rockin' the Rockies
    '01 allroad, 240k woot woot, still boosting on original turbos and tippy, slightly more modified. . .
    Sep 11 2009
    NE
    in addition to normal bleeding of the brake system you also need to bleed EPS pump which is only doable with VAG-COM/VCDS or equivalent tool (Xtool for example). Using the tool you can direct ABS module to engage the pump and bleed any residual air trapped in there.
    Dec 01 2017
    Olathe, CO
    Yep. Got to do this to mine yet. I see that the Bentley also says to do a weird bleeding order, RF, LF, RR, LR is the correct order on this car.
