Results 1 to 8 of 8
    Sep 17 2008
    California
    Smaller SC pulley
    Are all the smaller pulley upgrades using the same size pulley? For example, I noticed the CTS Turbo pulley and belt to be $100 cheaper than the APR. Being I already have a GIAC tune are all the pulleys on the market going to do the same thing if I upgrade to stage 2?
    Established Member Three Rings MSq5's Avatar
    Feb 14 2017
    Gulfport, MS
    Most will by 57-57.5 mm or so. That is the equivalent of a 179mm crank pulley. That produces a ratio of about 2.8:1 compared to 2.6:1 stock. That us the standard Stage 2 "single pulley" ratio for such tunes.
    May I suggest going with a solid crank pulley, as there is far greater variety in sizes and ratios. They are easier to install and you can readily swap back to stock or change to higher ratios.
    But, if you do want to go the s/c pulley route, there is no reason to pay APR prices. I cannot vouch specifically for CTS, but there are a lot of pulley vendors out there. Just read the threads to see what others are using and pick a lower priced choice that is reliable.
    Ratios matter, but if you get a pulley that produces a higher ratio than your tune, it will still work, your tune will just bleed off the extra boost.
    2017 Q5 3.0T S-Line | Brilliant Black | EPL Stage 2 93 octane tune | JHM 179mm crank pulley | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose
    Sep 17 2008
    California
    Thanks for the advice. Do they make a crank pulley for the 09 A6?
    Sent from my SM-G960U using Audizine mobile app
    Jul 17 2011
    Sin City, USA
    Smaller SC pulley
    Quote Originally Posted by gabec007 View Post
    Several companies (EPL, Fluidamper, etc.) make one piece lower pulleys. Going this route also eliminates the potential failure of the OEM pulley/balancer/dampener. Had this option been available when I did my stage 2 tune (I have an AWE S/C pulley), I would have gone that route.
    Going to a dual pulley setup will be my next step where the lower pulley will be replaced with a solid unit.
    '09 C6.5 A6
    Nov 12 2016
    Finland
    Crank pulley install for the 09 A6 is not easy as S4 and S5. There is motor support below crank pulley A6. You have to modify support for install for example 183mm crank pulley, but it can be done.
    Jul 17 2011
    Sin City, USA
    So the snub mount had to be ground down a bit for the pulley to fit?
    '09 C6.5 A6
    Nov 12 2016
    Finland
    Yes, little ground down.
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by KimmoL View Post
    Good to know. Thank you!
    '09 C6.5 A6
