Results 1 to 2 of 2
    Established Member Two Rings LifeOfKetchup's Avatar
    Jan 21 2017
    Heating system takes a long time to warm up
    Hey everyone!
    Just trying to get some insight on a particular problem Iím running into. Itís getting colder here in WA and my heating system is taking a very long time to blow heat into the cabin. My commute to the dealership in the morning is 40 mins. It was only when I arrived at the dealership where it started to blow hot air.
    I took it into a dealership and they said my heater core needs to be replaced. Took it into a mechanic to get a second opinion and they basically said my car just takes a long time to heat up the cabin. Last winter, it would take a few mins to get warm air at the very least from a cold start.
    The temp gauge gets up to temp and stays in the middle. The system blows cold air until engine oil temp gets to 200+ degrees in the dash and then the air gets hot. Dealership topped off the coolant.
    Itís probably a simple solution (hopefully), but I appreciate any help! Thanks!
    Veteran Member Three Rings Spinnetti's Avatar
    Dec 10 2004
    Dallas, TX
    Def. some kind of issue - maybe the valve that sends the coolant through the heater core. My car blows heat by the time I get to the end of the block.
    2015 S3: Uni Stage 2 ECU/TCU / Most of the 034 chassis and suspension catalog / APR Intake, Turbo inlet and Downpipe / ECS resonator delete / Neuspeed turbo muffler delete & discharge piping / 18x8.5 ET35 255/40
    2008 R8 V8 Manual: Uni 93 ECU tune / Avior Exhaust / 15mm Spacers / R8 Puddle lights / Custom mats
    1991 LS400: Literally every part replaced or modified in some way (24hrs of Lemons car)
