Results 1 to 16 of 16
    Dec 01 2007
    Orange County, NY 10918
    Transmission Malfunction message
    So other morning i got a transmission malfunction message on my dash. Car seemed to not want to shift. No gear indication etc.
    Stopped for coffee let car sit about 5/10min went away and car worked fine. Scan car for codes....got none.
    Any insight?
    Avantoberfest is tomorrow and worried now.
    Symptoms..... 2nd gear is real short...shifts hard into third only when car is cold
    .....had trouble going into reverse after a cold start.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    May 23 2016
    Edmond, OK
    What were you using to pull codes? VAGCOM can read TCM codes that a normal OBD2 scanner won't see.
    May 23 2016
    Edmond, OK
    Also, how's your battery voltage? Transmission will act in all kinds of random ways (along with random modules throughout the car) if the battery isn't at full voltage.
    Established Member Two Rings a1dan_87's Avatar
    Mar 07 2018
    Utah
    Any insight?
    The hard 2nd to 3rd thing seems common. Family members own a B7 a4 and a B8 Q5, both of them have that exact same issue. Not necessarily the other ones, but everything seems smooth until a jerky 2nd to 3rd shift
    Sent from my ZTE B2017G using Audizine mobile app
    Senior Member Two Rings jdaudi's Avatar
    Oct 26 2010
    US
    Set of clutches about to go bad. Scan for pending codes you'll see some positioning issues most likely
    Dec 01 2007
    Quote Originally Posted by 95blkmax View Post
    Generic scanner. For some reason my vagcom wont work. (Think cable is bad) anyway, I'll try to scan codes again. For now its driving easy.
    Sucks was going to EPL Tune this weekend.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    T.O.
    when was the last time you did a flush? also if you have never got a tcu update from audi best to take it in and tell them you have hard shifts and they will update for you. this got rid off all the rough shifts i had when i first bought my c6.5
    C7 4.0T - EPL stage 1 ECU/TCU.
    Donated - C6.5 Apr Stage 2
    Feb 15 2018
    Vancouver, WA
    Damn avant!! They are going up in price like crazy some listed for 40k
    That ski rack is insane!! Perfect fit for car what is it
    Active Member One Ring lazerghost's Avatar
    Jun 11 2018
    2011 Subaru Legacy 2.5i (Winter Beater/Commuter)
    West Virginia
    Mine is currently having a similar issue. Won't go into reverse unless you put it into drive and then back into reverse. Once it's warm it's okay, but just okay. It shits very hard. Dealership said fluid/filter change. It goes in on the 10th. I'll let you know if it helps. Nearly 60k miles atm if that helps at all(?).
    Dec 01 2007
    Quote Originally Posted by lazerghost View Post
    Yes my symptoms as well.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Jun 11 2018
    West Virginia
    It goes in the shop tomorrow so I will let you know what happens! Best of luck!
    Jun 11 2018
    West Virginia
    So, I got the car back last night. They said they performed a basic transmission service. Fluid, filter, gasket. It seems to have helped a lot, but I can still notice some not-so-smooth shifts. The service manager said they found an above average amount of metal shavings in the fluid and told me just to make sure nothing changes in the feeling of the transmission. They also said I will more than likely need a transmission. Just wanted to let you know what they said. Best of luck!
    Dec 01 2007
    Thanks for the follow up. I dreading taking the car in
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Aug 24 2014
    Newport Beach, CA
    My car (2009 3.0T w/ 87k miles) has always had a lack of smoothness around 3rd gear in certain conditions. However, it's always consistent and never harsh enough to be concerning. I just chalked it up to the way it is.
    I had the full factory fluid and filter change done and it was slightly smoother but overall there was no change. All other gears are totally smooth under any condition. There can be some hesitation when slowing down and the transmission shifts down from 2nd to 1st (which others have noted on their cars too).
    Imola 2001 Stage 3 S4: 312K - 2.4sec FATs - Completely Refreshed/Built Motor - SRM K24s w/ Custom Turbosmart wastegates - Clutchmasters Stage 4 - Etspec - Cinesnow WG/Oil Lines - SRM V3 Intercoolers - AA built trans - 4:1 Diff - JHM Trio - 034 - H&R Coilovers - FCP - Bosch Motorsports - OZ Racing - SRM/SSAC exhaust - Tons of New OEM parts
    2009 C6.5 A6 3.0T Prestige - stock, daily driver
    Jul 17 2011
    Sin City, USA
    I am VERY skeptical that you would need a new transmission after only 60k miles. Sounds like “stealership” tactics to me. Plus, the rough shift between 2nd and 3rd is a well documented occurrence. On top of that, if the transmission was truly going bad, then the new (more viscous) transmission fluid would make it worse not slightly better.
    I am at 160k miles and my transmission has never been touched and I drive Stormy hard! Not saying that it is by any means in great shape, but it demonstrates that these transmissions are more durable than they are given credit for.
    That being said, I am going to be replacing my transmission with a ZF 6hp19 that is “bulletproof” and rated to 1000hp at the crank. Cost is about $5800 plus shipping and labor, but it addresses the shortfall of the stock transmission which is the relatively low HP rating. With my future planned mods and the high mileage of the current transmission, a failure is imminent.
    '09 C6.5 A6
    Jun 11 2018
    West Virginia
    Quote Originally Posted by christianb5s4 View Post
    I've heard that about the 3rd gear. I'm just glad that it's a common issue.
    To be honest, I was thinking the same exact thing. Long story, but basically they've already tried screwing me once. Driving home tonight it drove fine and 2nd to 3rd has felt the best it has since I first purchased it. I'll have to look into that trans just for peace of mind although I doubt I would ever need it. Thank you both very much!
