Quote Originally Posted by Matt_C View Post
So I’m pretty sure the car is stuck in “limp mode” at this point. At low speeds, I could floor the pedal and he car barely moves, the rpm “shooting up” is when I’m in a higher gear and floor it and it downshifts. I am able to get up to about 65mph from a slow crawl, it just takes me a while
Hook up to vagcom and check your transmission module for fault codes, just to be sure. Then go back to your engine module and check your measuring values for your low pressure fuel pump duty cycle and your HPFP output. You also have an underboost code which very well good be the reason for loss of power. Time to do some logs.
