Posted on Facebook in the 3.0TFSI Technical Group:
So..... First and Foremost, I want to thank Issam Abed for allowing us at Tampa Autosports to test his Throttle body solutution for the 3.0T platform. We made 4 runs today, two before and two after install and below you can see the results.
Here is the important part....
We used a Mustang AWD dyno which was calibrated 09/24/18 at Vortex Performance in Tampa Bay. This Dyno was calibrated by Mustang so we are 100% confident it is as usual the heartbreaker that we are looking for. This dyno will read approx. 10-12% lower than any other dyno so the data we gain is reportable without question. We also as always do our due diligence and use the figures entered exactly vs being inflated or altered.
Power at 50 - 13.4
Vehicle weight - 3800
3.0 displacement
4 cyl stroke
Shell 93 oct Vpower Nitro
GIAC DP tune (Old revision)
pump map confirmed with tune switcher
Wheel diameter is 19" with 255/35/19 Michelin tires
Redline set to 7k - vehicle was run to 6500 max RPM
Ambient air temp in the Dyno was 101* F and average Florida temp currently is 94* ambient.
The vehicle was run twice with stock throttle body and twice with Issam Abed new solution installed.
The first picture below is max power at 392.8 WHP/ 379.9 WTQ.
We then literally just threw this throttle body on this car without any adaptaition or anything , did not allow the car to sit longer then the amount of time to swap throttle bodies ( maybe 15 mins) and made two susequent passes.
Max Hp gain with the upgraded Throttle body was 401.3 WHP / 376.5 WTQ at what we considered heatsoaked substantially.
This solution provided 8.5 WHP in the exact same conditions as base test with literally no planning other than slapping it on.
We all know these cars like adaptation and run time etc. We wanted to show what just slapping in on would do.
If this car was run on MS109 as it was on prev. power peak and better conditions, with time to sit and cool , the gains would be substantially more.
I have to give credit where credit is due !! As an engineer and pioneer in the Audi world, Issam Abed has provided a solution that is truly plug and play with no issues, that clearly provides notable gains and does not cripple the user to a specific brand of anything. The craftmanship is as expected ( awesome) and install can be done by a 5 year old. Our intake system was a direct fit with absolutely no modification needed.
Although September 3rd may have passed, his solution and commitment to offering a viable option to this community was spot on and on time.
I am driving this vehicle and logging for the next 5 days to see what more this solution can provide and will be testing this same car next week on the same dyno on race gas for a big dog comparrison.
Well Done Issam Abed, you just gave this community what they have been needing.
Thank you for bringing us along for the ride !!!
- - - Updated - - -
Reply from Issam Abed:
Thanks !
For those bombarding me with PM's just hold tight.
All I will say is the juice was worth the squeeze.
The info page will have the 75mm , 80mm (dodge hemi) ,and 82mm vs the oem.
This will allow users to make an educated choice as to why the 75mm unit is the best unit for 95% of the enthusiasts in here.
I wont say more other than watch out (and share the product page when it is up) and use the promocode
