Results 1 to 16 of 16
    Mar 14 2012
    Portland Oregon
    Good Audi shop in Portland
    Well after seeing all this about the class action. I think I am gonna be out of luck to get them to pay for the tensioner/chain update so I think I might bite the bullet myself :( I was looking at some new wheels, tires and tune but think the money will
    Be better spent on preventative equipment.
    Anyways, anyone in the local Portland area know a good shop that is reasonable priced and I could trust with the tensioners and timing chain? Iíve heard horror stories about shops doing this job and causing more issues after the job is done.
    Established Member Two Rings base14's Avatar
    Jun 01 2017
    OR
    I would only go to either futrell autowerks or matrix integrated for a job like that. I follow futrellís IG and Iíve seen them do a fair share of ea888 carbon cleans, rebuilds, and tensioners.
    2013 allroad Prestige | APR Stage I | E85 (his)
    2010 Q5 P+ | OEM+ Build Thread (hers)
    Aug 20 2009
    Portland, OR
    Only dealt with new car upgrades, but both Futrell on the West side of Portland or Double J on the East have been great to work with.
    Veteran Member Four Rings A4_2.8tuner's Avatar
    Sep 16 2004
    1997 Audi A4 12v VRT (project), 2000 S4 stgIII, 2017 Audi S3 Vegas Yellow, 2006 Lotus Elise
    St. Helens, OR
    I am an advisor at Audi Beaverton and have been in the enthusiast community for 15+ years. I'd be more than willing to help get you taken care of. Definitely a good idea to get it taken care of. Are you out of the warranty extension by time/mileage?
    Instagram: brianbement
    EUROTUNER Feature-November 2009 http://www.superstreetonline.com/fea...-1997-audi-a4/
    Current Fleet: 1997 A4-Eurotuner feature car & current VRT project, 2000 S4 stage 3, 2017 Vegas Yellow S3, 2006 Chrome Orange Lotus Elise
    Sep 16 2004
    St. Helens, OR
    by the way, you're welcome to shoot me over a text or call at 971-317-8546 to discuss further also
    Established Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Quote Originally Posted by A4_2.8tuner View Post
    Are you guys covering the full expense of installing the new tensioner etc as part of the extended warranty/class action lawsuit for preventative maintenance? I've got a 2010 with only 81k miles and would prefer to get it taken care of BEFORE the tensioner blows up.
    I'm as cool as a cucumber in a bowl of hot sauce.
    Sep 16 2004
    St. Helens, OR
    Quote Originally Posted by BeerBrent View Post
    Audi will not cover it as a preventative item. The warranty extension is 10/100k from the original in-service date. In order to get it covered under the extension there has to be a failure of some sort whether that's a drivability issue or a CEL with fault codes related to it. We can definitely do it as preventative, but Audi will not cover the expense.
    Established Member Two Rings rvcahawaii808's Avatar
    Mar 18 2017
    Portland
    i dont know what independent shops are charging for this job. but i will say i took my car in to brian and they fixed it no questions asked. they verified the noise and got right to work. very easy to work with.
    i think beaverton audi does a really good job.
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    So I've got 19,000 miles to hope the tensioner gives out and possibly destroys my engine. That's sad. Thanks Audi.
    Thanks for the info. Appreciate the response. Not blaming you directly, its obviously not your fault.
    Established Member Two Rings viciousone's Avatar
    Oct 03 2013
    PDX Area
    Futrell
    vIcIoUsOnE "Go Hawks!"
    _______________________________________________
    RS6-AMD Tuned "Cover girl"
    S4 B5 Avant Stage III AMD Tuned "Scarlett"
    S4 B5 Avant AMD Tuned "Baroness"
    MK6 GTI APR Stage II "Trix"
    Feb 07 2018
    Camas WA
    If you go with an independent shop Audi only knows what the shop said they found right? Say you took her in for slapping noise and they found the tensioner was failing... I've never had an issue finding someone to do some paid work who saw things my way. Given the problems Audi has had with the 2.0t and not willingly stepping up to fix these issues I wouldn't lose any sleep.
    Sep 16 2004
    St. Helens, OR
    hey Brent-essentially, yes. If the timing chain does fail within the warranty extension and does cause damage, those items would fall under consequential damage, which would be covered. I rarely see major damage caused by the chain, but i can't say i haven't seen it...just not as common as everyone would like to make it seem. If it were me and my own personal car, I would wait it out because if it did fail and cause any further damage it'd be covered, but if no failure occurs within the period, then I would have it done as preventative after the fact.
    I know you aren't blaming me, and I don't take any offense to it. Part of my job is to educate and help people make the right decisions for them and their vehicles, however I do originate from the enthusiast community and have been on these boards for over 16 years. with that being said, there is some good information that can be found on the forums, but also misinformation as well as we all know. I am just hoping I can offer some clarity to the issue at hand, and am always willing to help however I can!
    also this information and extension is assuming your engine is not modified, because a tune or similar will void that just like a new vehicle warranty, but the paperwork should go over all of that.
    Sep 16 2004
    St. Helens, OR
    Quote Originally Posted by rvcahawaii808 View Post
    Thanks, Cameron!
    I just want to help change the "stealership" misconception that people tend to have. We always try to do a good job and take care of people however we can, as well as stay competitive in the market. At the end of the day, people have the option to choose to take their cars wherever they want, and we'd love for folks to choose us as we have factory trained techs, all of the correct tools, etc.
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Thanks A4_2.8tuner. That's my plan.
    Active Member Two Rings PDXliam's Avatar
    May 14 2018
    PDX
    Brian is the best! Iíve been in a few times and they fixed everything I was having issues with. No charge. The best part is I call him with 20 minutes notice and he still gets me a loaner, A+ service!
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Quote Originally Posted by base14 View Post
    ...matrix integrated for a job like that
    Thanks much!
    I've known Brian a long time and he's always been personable, a straight shooter, excellent service! He'll take great care of you.
    Trained techs, proper factory tools, etc. Very important, and something most independent shops (including ones suggested here) won't enlighten you about as you might not be pleased to know who they have working on your car, the technician's level of experience/how long they've been in the auto industry, etc. Want to know who's on our team and their specialties? No smoke and mirrors here. We make it clear who our professionals are and who will be working on your vehicle(2 of them were previously the head techs at one of the other shops mentioned), as we're very honored to have the experienced staff we do, no hiding it!; http://www.matrixintegrated.cc/about-us/team/
    PS--Brian, under the warranty repair are you guys also replacing the lower/balance shaft timing chain and camshaft bridge timing cover (due to the oil screen often popping off the original)?
    Jeremy Williams
    Matrix Integrated Inc.
