Results 1 to 13 of 13
Thread: Tune question
    May 14 2012
    new jersey
    Tune question
    Looked at a 2001.5 s4 guy selling the car told me the previous owner tuned the car himself. He called the tune a demon file. The car supposedly has frankenturbos, apr diverter valves and that is it. The thing that seemed weird was the maf was unplugged. It idled fine, drove ok (the clutch is on its last leg). Has anyone ever tuned a car where the maf sensor wasn't used or needed?
    Jul 31 2014
    NH
    no and i bet as soon as you plug it in it will run like crap, just a guess, but when you have a major vacuum leak such as a boost hose it will idle like crap and die out sometimes, unplug the maf and it runs on a sort of default tune. does it make boost? if it does it shouldn't be over 5psi
    Feb 23 2010
    Lehigh Valley
    Your best bet is to get the proper supporting mods for the turbos and get the car tuned by a competent tuner.
    May 09 2012
    Virginia
    And get honest info about the car...
    May 14 2012
    new jersey
    I questioned it cause the maf does need to be plugged in due to metering incoming air for fueling. He did have a fault code for maf low flow. I'm debating keeping my cactus s4 or his black one. After driving his it's looking more like I'll keep mine and work on fixing it up (body work only)
    Veteran Member Three Rings zatch_303's Avatar
    Jun 13 2009
    Colorado
    cactus vs black.... no question..... keep your car FFS!!!!! or sell me it
    // 2001 Volcano Black B5 A4 Avant 1.8TQM - Past
    // 2001.5 Pearl White B5 S4 Sedan 6MT
    Established Member Two Rings csobel's Avatar
    Mar 25 2018
    Portland, OR
    Quote Originally Posted by antzb5s4 View Post
    RUN
    Senior Member Three Rings slowSfaux's Avatar
    Apr 26 2015
    Phoenix, AZ
    Quote Originally Posted by csobel View Post
    RUN
    This.
    Sep 11 2009
    NE
    unless it is very very cheap.
    Veteran Member Four Rings MacDaddy's Avatar
    Aug 06 2008
    Canadia
    Car probably has a bad MAF. these cars run pretty good without a MAF, as they rely more on the MAP/EGTs andO2s for fueling.
    Sounds like he got a tune off nefmoto and stuck it on there.
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Walk away from it unless the car is stupid cheap.
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    2001 S4 Avant TIP STG 0, Vast snub mount, 710N's, AWE boost gage, Tints, more to come...
    1998 Jeep Grand Cherokee , beater/off road rig
    Turbo's are the Perfect Drug
    Jul 31 2014
    NH
    Quote Originally Posted by MacDaddy View Post
    they rely heavily on the maf, the o2's are narrow band and only good for cruising and lean/not lean, for anything but the default tune (limp mode tune) it needs the mass air flow to meter the air. if it had widebands then yes it could relay on just the o2's
    Aug 06 2008
    Canadia
    They are semi-wide band. Unplug your maf and go for a drive it probably wont even throw a code.
