Results 1 to 19 of 19
    Veteran Member Three Rings Tweakophyte's Avatar
    Feb 15 2012
    Boulder, CO
    tires super noisy after rotation - thoughts?
    Hi-
    I have a set of PILOT SPORT A/S 3+ which I use 9 months of the year. I rotate them regularly. This time after the rotation they became super noisy. Any thoughts? There is still a lot of tread on the tires.
    I don't know if the tires have been previously rotated using a front to rear pattern, but this time they did a cross-over. Could it be that is the main factor? If so, should I just deal with it?
    Note, these tires have an asymmetric tread pattern and are * not * directional.
    MY12 Ibis, Titanium, 6MT, Sport Diff, Leather, Prestige : 35% tint, AK, SC Badges... CPO (kind of a mod)
    Veteran Member Three Rings isles1's Avatar
    Oct 24 2012
    2017 GMC Terrain
    Nassau County, NY
    When was the last time you had an alignment done? Could be a result of how the tires wore and putting them at different corners resulted in road noise. Happened to me with a set of used PSS. When I moved the fronts to the rear and put new tires up front, things quieted down.
    2013 S4, P+, DSG, Ice Silver Metallic, Black/Silver Alcantara, Sport Diff, B&O, 19" Peelers, PSS, SC Badges, Alu Kreuz, Ferodo DS2500 pads (front), Endless MX72 pads (rear), APR Carbonio Stage I & II CAI, Audi Platinum Pure Protection (until 11/2021). Winter shoes: OEM B8 S4 18" Wheels w/ Nokian Hakkapeliitta 7 Studless. Original owner; custom ordered.
    Feb 15 2012
    Boulder, CO
    I have not done an alignment but have never experience any pull, nor have I felt any strange tire wear rubbing my hand over the tread. You'd think that if one was out of alignment I would have experienced the noise on previous rotations. I agree the cross-rotation pattern may have contributed to this. How long until it goes away? Three weeks in and I can't stand it.
    Veteran Member Three Rings esimp2k's Avatar
    Jun 17 2009
    2014 TTS, Specialized Stumpjumper Comp
    Till you fix it since all the tires are wearing however they are making contact currently.
    Jun 30 2018
    Port Moody BC PNW
    Measure tread depth across the front wheels, I am guessing your inner fronts may have more wear then the outer sides, consider an alignment with new tires installed to ensure you have no suspension issue
    May 12 2008
    Quote Originally Posted by Cisco Kidd View Post
    +1
    I had a similar issue and my alignment was of and the tires wore in incorrectly. Switch them back until you are ready for a new set.
    Mar 28 2016
    On a side note....
    How do you like those? I was thinking about them for my next set. Though I will drive on them year round, so it will include snow driving.
    Feb 02 2014
    2011 STI - full suspension upgrade, Stage II+, 2015 M235 coupe
    Knoxville, TN
    Many times the wear pattern that creates noise is due to the leading edges of the blocks wearing differently, so when they a cross corner switched all 4 corners would have changed the directon of tire rotation when driving. I usually only cross one pr (fronts) and move reas to frnot on same side. This will minimize the noise bc only 2 of 4 tires are rotating in a different direction at tire swap.
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    I have always rotated my Michelin PSS front to rear and vice-versa. I had been considering the Pilot Sport A/S 3 tires and checked the Tire Rack site to get more info. Here's an article from there that states: "Michelin has gone from a directional (V-shaped) tread pattern in the Pilot Sport A/S Plus to a non-directional asymmetrical (bigger outside shoulder) tread design with the Pilot Sport A/S 3. Their engineers use a varying number of longitudinal grooves to create a tread design that will resist hydroplaning and allow for cross-rotation, leading to more even wear."
    That said, if your tires have become noticeably noisy following a cross-rotation, I suspect that the tire noise will not go away as you drive additional miles on them. As mentioned above, your best bet would likely be to undo the cross-rotation and stick with F-R rotations until they wear to the wear bar indicators. You didn't mention how many miles your tires have accumulated but according to the reviews on Tire Rack, a number of reviewers complained about them getting noisy after 20,000 miles or so. I know my Pilot Super Sports always get noisy after several seasons (they're on their 3rd summer season and the wife can't stand the noise, so they'll be replaced in the coming spring.
    Let us know what you find/do to resolve the issue.
    2011 S4 | Prestige | Jet Blue | Black/Silver Silk Nappa | S-Tronic | Sport Diff | Drive Select | Side Assist | Titanium | Carbon Fiber Inlays | HRE R40s (summer) BBS RGRs (winter)
    Feb 15 2012
    Boulder, CO
    Quote Originally Posted by hilmar2k View Post
    On a side note....
    I like them a lot and got the same tires for my son's A3. I've driven in snow with them but still have a dedicated set for the winter. I drive about 25 miles each way to work and prefer the added safety, even though I only REALLY need them a week or two a season.
    Mar 28 2016
    Quote Originally Posted by Tweakophyte View Post
    I've driven in snow......
    And how are they?
    Feb 15 2012
    Boulder, CO
    Quote Originally Posted by LYKUNO View Post
    I could be close to that 20K point. I think the biggest problem is this is the first time they told me they crossed on the rotation, which means there is a chance the other rotations have been front/rear. That makes me wonder if the noise is exacerbated. I'll give it another week at most.
    Yes, I will work in an alignment, too. I know this is not conventional thinking, but I was raised that a car does not "just" go out of alignment. The people the make money off of them will tell you railroad tracks throw the car off. Yes, I've hit a few decent pot holes... I put my hand on the tires to check for feathering. That said, I think I will measure across tread as well, to check for coning.
    Last thing... there is a slight chance I am also hearing the start of a wheel bearing going out. I've had them go out on my GTi and A4, so I have a feel for what it sounds like... there is a teeny tiny hint of that. Of course, I will swap the cross-rotation first.
    Feb 15 2012
    Boulder, CO
    And how are they?
    I guess I should have finished the thought... They were good in the cold and the snow, but I couldn't give you any notes I took because I don't remember. The first winter after I got the AS 3+ I also got Alpin PA4s and an 18" wheel-set, so there was just a bit of driving on the AS 3+ in the later fall and early spring. 3 seasons in I really like those PA4s.
    Jun 30 2018
    Port Moody BC PNW
    Quote Originally Posted by whts4 View Post
    Exactly what I plan to do after I get my new Yoko Advan Sport V405's installed tomorrow. I had some uneven tire wear/feathering due to previous owner not rotating the DWS 06 properly and also letting car go out of alignment due to pothole. Dealer inspected everything and said no suspension issues but I will need tires or just deal with the noise which I am sick of, the front inner is 4/32 while outer is 6/32, rears are at 7/32 even across. I have decided to replace tires for winter and when first rotation is due rears will move forward on same side but fronts will cross over to the rear
    Senior Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Acura RDX
    Napa, Ca
    One time I waited a longer than usual to rotate my tires I did a 4 wheel slide into a tight turn that same day. It ended up taking about 2 days of driving for them to wear back to normal.
    Feb 15 2012
    Boulder, CO
    FYI, they crossed the rears to the front, and moved the front to the rears.
    - - - Updated - - -
    Hi-
    I had them measure tread-depth across all for tire (Left/Middle/Right) and am at 7/32" all across the tread on all tires. The guy said to let it run for 2K miles and see if the noise is still there. We shall see.
    Mar 28 2016
    That's backwards for an AWD car. Rearward cross is the correct rotation pattern for 4WD and AWD cars/trucks (without staggered tires, of course).
    Feb 15 2012
    Boulder, CO
    Finally made it in to the dealer for a quick listen... going in tomorrow to replace my right-front, outer wheel bearing... not a surprise, but geez that's expensive. Standard shop hour are high. I think they said 5+?
    I know about a year ago I hit a ridiculous hole the construction crew should have covered with a steel plate (which they did later). I was sure there would be some noticeable damage on the tire, wheel, or worse but could not fine any. Maybe that was the start of it?
    For those that care, I am also getting an alignment. I will be curious how far off my numbers are.
    Feb 15 2012
    Boulder, CO
    Wheel bearing... fixed it.
    I punted on the alignment this time (did a brake fluid flush instead). My all-season are at 5/32" and I will be switching to winter. I'll think about an alignment on my next new-tire buy.
