Results 1 to 19 of 19
    Jun 09 2018
    New york
    3.2 timing chain job labor costs?
    Hey guys I’m just wondering how much a timing chain replacement job would run me through Audi. I was going to do it myself but I just don’t have the time. The car has 176k on it and I don’t think it’s been done. Also what’s the replace intervals on these?
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    In for responses too. This is a motor out affair right?
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Aug 19 2013
    Miami
    Around $1800 to $2200
    Sent from my G3313 using Audizine mobile app
    Ivan
    Aug 14 2018
    NV
    Is the timing chain on the front of the engine on the 3.2's? Or the rear like the 4.2?
    Aug 19 2013
    Miami
    Quote Originally Posted by Audidrew99 View Post
    3.2 if i recall is front
    Ivan
    Nov 03 2011
    All Over!
    Chain assemblies are at the rear, as in 079 V8 engines.
    1986 Type 85 Audi 90 quattro
    Jun 09 2018
    New york
    Yeah it’s in the rear. If it were in the front I’d have had it done. If anyone has done it does the engine absolutely have to come out or would taking the trans out give me enough room. I do have two lifts in my garage so I wouldn’t be working off the ground
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    You’re going to want to drop the motor. If you have a lift maybe you should just drop the whole motor, tranny and subframe all together and separate the transmission on the ground.
    Veteran Member Four Rings Axis's Avatar
    Nov 15 2011
    3.0T 6MT Stage III Allroad | A4 B8.5 Sedan
    Montreal | I sell in USD
    3/4 of the part # for the chain job start with 079, they do share alot.
    We dont call them mini 4.2 for nothing haha
    Currently doing one
    Wagons are made to haul things, mine is made to haul ass
    *****I sell in USD*****
    Click here to read my seller feedback
    B8.5 Allroad 3.0T 6MT Sport Diff 034 Stage II+
    Nov 03 2011
    All Over!
    Quote Originally Posted by Toddyp2004 View Post
    I would pull both, and separate the assemblies on the bench.
    You could do the chains with just the trans pulled, leaving the motor in the car. But do you honestly wish to be working in such a tight space, with very little sideways room?
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    What problem are you having with the motor?
    Jun 09 2018
    New york
    Quote Originally Posted by JayDog747 View Post
    No problems just a preventative maintenance thing. It runs great but has 180k on it and I don’t think it’s ever been done. The second owner said he hadn’t had it changed and I can’t recall how many miles it had on it when he bought the car
    Mar 10 2010
    WI
    Save your money. The chains do not need to be replaced.
    Veteran Member Four Rings a4lownslow's Avatar
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Like said above save your money.. the 3.2 engines do not have a high rate of catastrophic failure like the 4.2. Having done both a few times, when the 3.2’s have timing issues it’s the upper tensioners which are easily replaced engine in the car. Haven’t done it in awhile but maybe took 6-8 hours to do upper tensioners bank 1 & 2.
    Edit: I did the repairs on an a6 3.2 larger engine bay, but I believe upper tensioners should still be doable on the a4 engine in.
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by dalmation53 View Post
    ROASTED ...... Shouldnt answer a you dont know the answer to. Google next time
    APR KO4, APR HPFP,RS4 LPFP Cntr,145 bar PRV, APR TP, TT DP, GFB DV+, AWE FMIC, BFI CC, AWE Exhaust, RS4 Exh tips, ST CO, 034 RSB,034 St Dnsty Mtr Mts, New Sth West Bst guage, B7 RS4 8 pot Calipers.Goodridge SS brake lines frt & rr. Hawk HPS frt & rr. RS4 PS rack, RS4 Servotronic Relay,RS4 rims. S4 mirror caps,DTM frt bmpr and rs4 fogs,LED tail lites
    Aug 19 2013
    Miami
    I couldn't understand what you said you type like a female with all the emojis. You mad bro? That's why i said if i recall heres the meaning if you don't know.
    This is a phrase that you say*when*you're trying to*remember*something, but you're not sure that you're remembering it*correctly
    Ivan
    Jun 17 2013
    jersey city nj
    I couldn't understand what you said you type like a female with all the emojis. You mad bro? [/URL]
    Never mad . You not smart enough to make me even come close . But I do find you very amusing ...
    Aug 19 2013
    Miami
    You're *** That's good I amuse you no hard feelings. We cool
    Ivan
    Jun 17 2013
    jersey city nj
