Results 1 to 11 of 11
    Dec 28 2006
    '03 A4, '13 A5, '18 MB-GLA
    Western Maryland
    Wiper Blade Chatter Cure
    The driver’s side wiper blade on my A5 has been chattering ever since I purchased the car. I have tried numerous different blades as well as numerous different windshield treatments. Bosch, Amco, OEM, Rain-X blades. Aquapel, Janvil, Rain-X, Gtechniq, F11 topcoat, clay bar. You name it I tried it. All of them worked for a short period of time and then the chatter returned.
    Well I think I have finally found the cure. With the last wiper change I noticed that the wiper attachment to the arm had a bit of slop in the connection. I fabricated a small shim with a .018” thick piece of plastic and inserted it between the wiper arm and wiper blade attachment. This took all of the slop out of the attachment. So far it seems to have finally cured this annoying issue……..
    If you are dealing with the same issue the pics show what worked for me.
    Nov 20 2016
    omg, all this god damn time this is probably what my issue was lol instead i replaced the arms for 175 dollars, polished the glass with 30 dollars worth of griots garage glass polish, and went through 3 sets of wiper blades in one summer.
    Established Member Three Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    Defective arm? Interesting
    2011 A4 Avant Prestige S-Line
    Established Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Good tip. I get the chatter/stutter on the down swipe sometimes and it annoys me.
    I'm as cool as a cucumber in a bowl of hot sauce.
    Nov 20 2016
    Quote Originally Posted by BeerBrent View Post
    On other cars its usually because the arm has "relaxed" in a position that its pushing the blade on the wrong angle, but in this instance the arms are massive and very thick, I can see the actual stretch occuring where they clip to the blade and making the whole blade itself wobble on the stroke back and forth.
    Established Member Two Rings SlvrArrw's Avatar
    Nov 05 2016
    Richmond, Texas, USA
    Great tip, I'll try for sure
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Definitely going to try this...
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Veteran Member Four Rings if6ws9's Avatar
    Feb 08 2012
    Grand Cherokee
    Palm Harbor, Fl
    Been having the same problem with my '14 A5. I recently returned a nice set of Bosch blades because it did the same thing. I'll try this, thanks!
    2014 A5, Brilliant Black, Black Optics, Sport package, MMI+, B&O, AWE Touring w/Black Diamond Tips, AWE DP, USP HFC, CTS CAI, APR Stage 2, ST Coilovers, Alu Kruez, 034 TX insert, ECS diff bushing, Apikol blue diff mount, VAG's, Escort Redline, ZR4 shifters, 20% tint, Sprint Booster, ECS dipstick, FB steering wheel, piston diverter valve, ECS rear lower control arm brace, 10mm & 12mm spacers, BFI shift knob
    Nov 17 2010
    Pemberton, BC, Canada
    Strangely , the pic's don't show in Firefox 62.0 but are fine in Chrome. Anyone else get this?
    Aug 12 2014
    2009 Audi A4 Prestige, 2004 Ford Taurus, 2013 Chevy Malibu, 2017 F150 Sport, 2012 CBR600RR
    Green Bay WI
    Couldn't you just pinch the metal together a bit to bring it back to shape? Seems like the wipers stretched it open more over time?
    Sep 03 2014
    2014 Audi Q7 Premium Plus, 2014 Audi A4 2.0T Quattro S-Line
    Ellicott City, MD
    Quote Originally Posted by A4Mods View Post
    I was thinking the same thing as I was reading the thread
