Results 1 to 7 of 7
    Aug 26 2017
    Columbus Ohio
    Removing Roof Channel Trim
    Has anyone removed the roof channel trim? I've searched around and couldn't find much info regarding our cars. The best I've found is this thread that provides a part number.
    I was able to pull each end up but the rest of the trim wasn't budging. With the price of this part, I'm hesitant to rip it off without hearing about prior experience.
    Pictures of the part are included. Thank you in advance!
    My images have rotated 90 degrees counter-clockwise when I uploaded to audizine. I'm not seeing how to remove the old images (first post), but they should still show the trim fine.
    Established Member Two Rings charmar's Avatar
    May 29 2017
    Northern PA
    I had these pieces off when I had my car repainted last year. You need to work them out very slowly and carefully to keep from bending them. I got one end picked up enough to hold onto it, then kept steady upward pressure while working it out with a flat blade screwdriver padded with a soft cloth. As I remember, it worked best to pry under the rubber seal that the metal strip is pressed into. The seal can be peeled off after the whole piece is off the car. It would be a good idea to mark the front side of the pieces, as it can be difficult to tell after they removed. Good luck
    Sent from my XT1575 using Tapatalk
    Aug 26 2017
    Columbus Ohio
    Thank you! That helps a lot, I just wasn't sure if there were any specific direction clips or the like.
    May 29 2017
    Northern PA
    Nope, it's just a T-shaped metal strip that fits into the rubber seal.
    Veteran Member Three Rings A4_PimP's Avatar
    Jan 18 2012
    Waterdown/Ontario/Canada
    OK so is there a trick to getting it to stay seated? One my care the front and rear ends are always popped up. I push down on them and they go back down but then after a couple days they are up again. Do I just need to apply more pressure?
    Veteran Member Four Rings RDA990's Avatar
    Jan 07 2013
    Germantown, Maryland
    Quote Originally Posted by A4_PimP View Post
    This is happening to mine in the rear. They were removed when the side was painted after an accident and I believe they bent it a bit. I think the solution for this would be to remove it and bend it a bit downwards so it stays seated.
    Brilliant Red 2004 A4 1.8T quattro Ultrasport
    Frankenturbo F21L | Motoza Tuning | FMIC | Test Pipe | Bosch 550cc | 710n DV | Podi Boost Gauge | 21 PSI
    Dolphin Gray A4 1.8T quattro 2004
    Brilliant Red A4 2.0T quattro 2007
    DIY - A4 B6 Boost Leak Test
    Jan 18 2012
    Quote Originally Posted by RDA990 View Post
    I bought my car used but I'm starting to see evidence like it was repainted. I'm going to give that a try taking them out and bending them downwards I'll let you know how it goes.
