Results 1 to 12 of 12
    Aug 28 2018
    Cornwall
    Cam belt change wrong tensioner
    Please help I've got a A4 estate 2003 2.0fsi.ive just changed belt and water pump but I've got a hydraulic tensioner and not what came in the cam belt kit
    Registered Member Four Rings EuroxS4's Avatar
    Jan 24 2010
    Paramus,NJ USA
    There is no way you have a 2003 a4 with a 2.0FSI engine unless it was swapped in!!
    Aug 28 2018
    Cornwall
    im just going on what my log book and service history book and also when I enter my reg on ebay and euro car parts they all say 2.0fsi 150bhp?
    Jan 24 2010
    Paramus,NJ USA
    Sorry forgot that was an option in europe.Not sure if anyone here knows what its supposed to have as we didnt have that engine in the USA.
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    AE86 20v, UZZ30 LS2, 2002 A4 B6 1.8t, E63 AMG
    San Diego, Ca
    mmmm...fuel stratified injection
    2007 Mercedes E63 AMG - Nardo Grey, Pano, LTH X-Pipe, Res Del, ROW Box Mod, Programa ELM, UPD Arms
    2003 Audi A4 1.8t Q Avant - Maestro, 225TT Inj, TP, FMIC, Thermal R&D Exh, KW V3, BBK / Ferrodo DS2500
    1992 SC400 - LS2 6.0, LTH, Tomei 2-Way, KW V3, BattleVersion Arms
    1986 Toyota Corolla GT-S SOLD - 20 Valve, Haltech E8, Toda 272 8.5mm, Toda Cam Gears, Silkroad High Rise Headers, TRD 2-Way, TRD SS Race
    May 05 2014
    B8 A5
    Adelaide Australia
    without turbo
    Dec 05 2007
    If you received the wrong tensioner, return it and get the right one.
    Aug 28 2018
    Cornwall
    I cannot find the tensioner anywhere online or on videos/photos or drawings
    Dec 05 2007
    Are you saying the original one on your car is hydraulic? And replacement that came in is not a hydraulic one? If so, then it is most likely an updated spring tensioner. And if so, it is much more reliable.
    I don't know your engine, but the US AMB engine code engines went through the same thing. They now sell a spring tensioner in place of the hydraulic one that came original on the car.
    Aug 28 2018
    Cornwall
    if you google this 06D 109 485 you will see what ive already got on my car plus a hydraulic ram
    Dec 05 2007
    Trying to understand what your issue is? With a clearer explanation, people may be able to assist better.
    I am conjecturing things in my head what your issue is, but are all assumptions. Assumption I have now is the hydraulic tensioner (one with extending rod) is not compatible with what you had me google.
    Then this is what it looks like installed? Not sure where the hydraulic tensioner (with rod) would then go. But I do get how you use that hex to tighten belt, torque the tensioner down with that flat faced hex bolt, then use the hydraulic tensioner to keep things locked. Need more pics to try and understand more, along with trying to figure what you are talking about. Mind you I don't know your car at all, but will try to help if I can.
    Jan 24 2010
    Paramus,NJ USA
    Im assuming your missing the hydralic piston for the tensioner correct??From what I understand you also need part number 06D109477A.Thats the hydralic piston that pushes up on the tensioner .
