Results 1 to 3 of 3
    Nov 03 2011
    Manitoba, Canada.
    Highest Temperature Your Engine Has Reached (Overheated) And Survived.
    Hey guys!
    Iím just putting this out here, so we can have a rough idea how hot our engines can get, without destruction. Iíll start with mine. Feel free to give a mini write up as Iíve done, how you came to be running your motor that hot. Please maintain the same format below, for clarity:
    Model: B6 A4 Avant Quattro 6MT.
    Model year: 2003.
    Engine: 3.0 V6.
    Max coolant temperature reached: 133.5 degrees C.
    Duration: 16 - 28 minutes.
    Stationary / moving: Mixture of stationary and speeds up to 46mph.
    Coolant temperature after cruising at 40mph+ for 10 minutes: 116 degrees C.
    HVAC mode: Air con off, heater set to Hi, fan speed at max.
    Reason: Fan control module failure.
    Temperature logged via: VCDS.
    Ambient temperature: 16 - 34 degrees C.
    My FCM died, and for the past 2 weeks, I have been running the car without the fans, trying to maintain speeds above 50mph to provide cooling, and having my heater on max temp / max fan speed to draw some of the heat out of the coolant via the heater core.
    I havenít always been moving though, getting caught up in rush-hour traffic multiple times. FCM replaced, and engine runs great, with no adverse effects from the high temps reached.
    2003 B6 Audi A4 Avant Quattro Sport | 3.0 V6 | 6MT | Denim Blue Pearl | B6 S4 ďBlack OptikĒ Grille | Votex Kit | Black Leather - Part Out.
    2012 B7 Seat Exeo ST Sport Tech | 2.0 TDI 170 | 6MT | Phantom Black Pearl | LED DRLís | Bi-Xenons | AFS | LED Tails | LED RNS-E | AUX / iPod Input | Black Leather | Multi-Function Steering Wheel | Rear PDC.
    2002 Toyota Runx |1.4L DOHC 16V Auto.
    Jul 31 2014
    NH
    Hey guys!
    Model year: 2003.
    Engine: 3.0 V6.
    no adverse effects that you know about, but at that temp things can begin to warp, especially aluminum heads, and can lead to headgasket failures down the road, best to not chance it and replace the fcm or at the minimum run line with a switch to turn them on manually.
    Senior Member Two Rings alimo20's Avatar
    Jan 25 2011
    Philly
    Hey this is a great idea - here are my recents:
    Model: B6 A4 Avant Quattro TIP.
    Model year: 2002.
    Engine: 1.8T
    Max coolant temperature reached: 129 degrees C.
    Duration: 20-25 minutes.
    Stationary / moving: Mixture of stationary and speeds up to 20mph. - mostly city stop/go traffic
    Coolant temperature after cruising at 40mph+ for 10 minutes: unknown - turned engine off (probably not the best idea)
    Reason: Fan control module failure. Cluster temp gauge failure. Low coolant
    Temperature logged via: Torque Pro
    Ambient temperature: 28-30 degrees C
    new category:
    Times recurred: 10+? Unknown
    I am a moron - yes - but she wasn't showing any symptoms of overheating. I just 'felt' like it was running hot and then realized the fans were never coming on unless the HVAC system was on. Also had a coolant leak that was introducing air into the system. The cluster gauge was also incorrectly showing a 'normal' 12 o'clock the entire time - so I never realized it was incorrect. I overheated the engine at least 10 times before becoming aware of the issue. So far no problems that are immediately apparent
    034 HFC, StopTech SS Lines, B7 Interior Upgrade, 034 Silicone Vacuum and PCV Lines
