Results 1 to 4 of 4
    Oct 03 2015
    Outskirts of civilization
    Using the main horn for alarm instead of the dedicated alarm horn in the back?
    My alarm horn module died, just as it did for many other B6 owners - damaged by leaked batteries inside the module. I've tried cleaning and repairing the module - it starts working for some people after cleaning - but I wasn't as lucky. So I wonder: is it possible to make the alarm use the main horn instead? I do believe some B6 variants did not have a dedicated horn module with backup battery power. But then, it's possible that those variants had no alarm whatsoever, I can't find any further details on this topic.
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    Interesting idea. I replaced my siren module a couple years ago, but then when the new one started flaking out I just disconnected it. I wouldn't mind having it hooked up to the horn. I realize that's not as secure as an independent siren, but it's better than what I have right now.
    I wonder if that's what the '98 - '05 Passat uses? A couple times at the junkyard I've gone searching in the RR corner of Passats for a siren, only to find nothing. If the Passat uses the horn, with otherwise the same setup, we should be able to copy what they did there.
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
    Nov 03 2011
    Manitoba, Canada.
    Using a regular horn for the alarm will be a nuisance, due to the much higher decibel level.
    Just imagine a windy night, or over-sensitive alarms on 4 cars. Those going off after midnight would cause distress and frustration for residents.
    In Germany, there are strict dB levels, that must be maintained. Traditional alarm sirens were replaced with low-tone beepers many years as a result. Any car imported into Germany will need a louder than normal alarm horn modified to comply with local regulations.
    2003 B6 Audi A4 Avant Quattro Sport | 3.0 V6 | 6MT | Denim Blue Pearl | B6 S4 “Black Optik” Grille | Votex Kit | Black Leather - Part Out.
    2012 B7 Seat Exeo ST Sport Tech | 2.0 TDI 170 | 6MT | Phantom Black Pearl | LED DRL’s | Bi-Xenons | AFS | LED Tails | LED RNS-E | AUX / iPod Input | Black Leather | Multi-Function Steering Wheel | Rear PDC.
    2002 Toyota Runx |1.4L DOHC 16V Auto.
    Oct 03 2015
    What you're saying makes sense and I agree with the sentiment, but for my car it's a non-issue. First and foremost, I only have the factory alarm and it never goes off by itself. If it does go off, it's because something happened, and I'll definitely appreciate the higher dB level. Also, I only set the alarm very rarely, when I do indeed want whatever little extra security it grants. Also, the horn won't necessarily be super loud if it's modulated with very short pulses.
