Results 1 to 19 of 19
    Aug 30 2018
    Ohio
    Stock Max Boost Pressure?
    Hello!
    What is the common observed max boost pressure on a completely stock 8V A3?
    What about stock except for stage 1 tune on 91 octane?
    What about stock except for stage 1 tune on 93 octane?
    Full disclosure, I'm trying to determine safe max boost pressures depending upon octane for a United Motorsport loaded tune 8V A3.
    Dec 25 2004
    Earth
    I VCDS logged mine with stock and UM Stage 1 91 tune...2.6 bar...that day.
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Veteran Member Four Rings ralphie_43's Avatar
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by MikTip View Post
    I VCDS logged mine with stock and UM Stage 1 91 tune...26.6 bar...that day.
    26.6 bar or psi?
    Sent from my SM-G930V using Audizine mobile app
    Dec 25 2004
    Earth
    Quote Originally Posted by ralphie_43 View Post
    26.6 bar or psi?
    Sent from my sm-g930v using audizine mobile app
    oops!
    2.66
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    oops!
    2.66
    It's all good lol I was like i'm pretty sure it's not 26.6 bar but you never know
    Veteran Member Three Rings MichiganRS3's Avatar
    Apr 30 2015
    Michigan
    Really? 2.6 bar is like 38psi. Seems kinda high for an A3.
    `18 Mystic Blue Pearl Effect RS3
    10.6 @ 129mph / 2.82s - 0-60 - Stage 2 e85
    May 17 2016
    Hong Kong/LA
    1.8-1.9 bar is usually the upper limit for S3's stock IS38, but for IS20, I think it's 1.6 bar or 24 psi...
    Dec 25 2004
    Earth
    Quote Originally Posted by MichiganRS3 View Post
    A week after I got my S3 United Motorsports tune... I VCDS data logged it as the tune changed the way the OE boost gauge displayed boost...so I was curious of what the boost actually was...
    Thats what VCDS showed...
    May 17 2016
    Hong Kong/LA
    That can't be right, anything close to 2.4 bar is pretty much an instant boom for IS38... 1.9 bar IMO is already pushing it...
    Established Member Two Rings tdietro's Avatar
    Jan 09 2015
    Metro Houston, Texas, United States
    Quote Originally Posted by larbel View Post
    Perhaps the first bar is standard atmosphere? Then the 1.7ish bar over that is boost and equates to 24-25 PSI.
    Sent from my SM-G965U using Tapatalk
    May 17 2016
    Hong Kong/LA
    Quote Originally Posted by tdietro View Post
    Oh yeah, that's right! Totally forgot VCDS does that LOL
    Apr 30 2015
    Michigan
    This makes mores sense. I’ve never used VCDS, this is kind of wonky way of reporting.
    Dec 25 2004
    Earth
    substract about 1000 mbar from the total to get actual boost pressure
    1 bar = 14.7PSI = 1000mbar
    Aug 30 2018
    Ohio
    Thanks for all the good discussion!
    So would I be accurate in saying stock is around 18 psi, stage 1 91 octane is around 23 psi, and stage 1 93 octane is around 25 psi?
    These would all be maxes of course.
    Dec 25 2004
    Earth
    Quote Originally Posted by Hites View Post
    I'm stage 1, 91 octane...United MotorSports tune...
    I would say the specific numbers depend on the tune...your location, and engine mods...
    Aug 30 2018
    Ohio
    With UM offering the loaded tune for the 8V, I'm trying to determine what max boost pressure can be run with what octane.
    Like if I were in a pinch and a gas station only had nothing higher than 87 available, which when mixed with a tank of 93 would likely equal 88 or 89, what max boost pressure could I drop it to? 19 or 20? IDK. Might need to experiment, it sounds like...
    Dec 25 2004
    Earth
    I think your splitting hairs here...and penny pinching on gas while trying to drive a turbo car thats suppose to be run on premium....
    Aug 30 2018
    Ohio
    Correct me if I'm wrong, but starting in 2016, the A3 can run 87 octane. Obviously it'll pull timing like crazy if you drive it hard, but Audi says it can run 87. Sounds like this is uncharted territory.
    Dec 25 2004
    Earth
    The ECU adapts to the various octane/conditions...nothing new...just less performance, but only 4 octane worth.
    IMO if this is your main concern...dont buy a upgrade in power performance tune. Because you will burn more gas!
