Results 1 to 15 of 15
    Feb 17 2014
    british columbia
    Cam tensioner pad replacement
    My car has 162000 miles on it. Oil and filter changes every 3000 miles. It has the original cam tensioner pads still on it. When looking at them they look fine but as mentioned in other posts l am new to this. Do l need to have these pads replaced? We are planning a long road trip.
    thank you
    Jan 22 2017
    Acura MDX, 4Runner, FJR1300, Mastercraft, 89 Bronco 408w
    Wisconsin
    I replaced on my c5 a6 4.2 as I was trying to minimize chain noise at start up. If they aren't grooved noticeably, I wouldn't bother until I did valve conver gaskets and seals (which is inevitable).
    Bratcop
    Sent from my LG-US996 using Tapatalk
    Established Member Two Rings Watcher0691's Avatar
    Jul 20 2017
    2013 Audi A4 2.0T Quattro, (2) 2001 A6 2.7T Quattro, Dodge Stratus R/T full sub 510 cu.
    Ozark Missouri
    As I am rebuilding several 2.7T's at the moment, I ordered these from amazon.
    Sentinel Parts #C062 97-06 Audi Timing Chain Tensioner.
    These are the tensioner pads and not the tensioner. $13.50 a set, OEM quality or better.
    Watcher
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 04 Allroad, 16 PSD F350
    Longview, WA
    What's it like replacing these? Do the cams have to come out? Timing belt removed?
    --Mike--
    01 Casa S4
    03 Mugello RS6
    04 Cobalt Blue Allroad
    01 Aviator TT (sold)
    99.5 A4 (sold)
    Jan 22 2017
    Wisconsin
    Yes, cams loose and lifted a bit, timing belt off
    Jul 20 2017
    Ozark Missouri
    Quote Originally Posted by Kruat View Post
    Good question!!
    I would highly recommend that anyone attempting this follow Bently or AllData procedural steps!
    Because I do this on a regular basis with power-plant both installed and removed, I take short cuts that the factory omitted to prevent newbie Techs from screwing up the cam timing and destroying a customers engine.
    As long as you follow these basic rules:
    1. Engine at TDC and locked to prevent rotation.
    2. Lock camshaft and release belt tension
    3. Clean and mark both cam sprocket and chain before using special tool (Cam tension release tool)
    4.VERIFY marks after re-installing cam tensioner.
    Never have I ever experienced a problem, or failure by following the factory or "my short cut" steps.
    BTW... Did all of you in the Audi world know that you can rebuild your existing Cam Chain Tension assemblies?
    I do!
    I will try and find some time to document with pics and all how simple and inexpensive you can do this in the coming week.
    Watcher
    Nov 10 2004
    Longview, WA
    What do you use to lock the cam shafts I place? And in your experience, is it the pad that fails more then the actual tensioner?
    --Mike--
    01 Casa S4
    03 Mugello RS6
    99.5 A4 (sold)
    Established Member Two Rings climb4hope's Avatar
    Jan 16 2017
    01 Allroad 2.7T manual, 02 Allroad 2.7T auto, 01 S4 6sp (building)
    Seattle/WA
    There is a plastic plug on the left side of the engine behind the intercooler pipe. Unscrew 10mm bolt and there is a special tool that you bolt in instead of the plug. There is a hole in the crankshaft assembly that you need to align this will be your TDC position. The special tool is very inexpensive an is like $10 on ebay or so.
    Also if you have a lock bar for the cam sprockets, you don't necessarily need to mark the sprocket positions. The lock bar is $45-50. If you ever plan to do timing belt yourself or take it out in the future it is worth to invest, otherwise do marks for a one time job.
    - - - Updated - - -
    Here's the link for the tool to lock the crankshaft: https://www.ebay.com/itm/18mm-VW-Aud...cAAOSwMVdYESzb
    Jan 16 2017
    Seattle/WA
    In fact, seems like someone is selling a lock bar and the pin for < $25. I would definitely buy it: https://www.ebay.com/p/VW-AUDI-V6-Ca....c100005.m1851
    Jul 20 2017
    Ozark Missouri
    Quote Originally Posted by climb4hope View Post
    What this gentleman said about locking the engine
    As far as my experience with the pads vs tension assembly failing first... neither one to be honest. I have seen high mileage engines 150K+ with perfect looking pads and tension assemblies, as well as same mileage engines that looked like hell. Proper maintenance (oil change) and filter changes (I always change out the filter half way through a maintenance cycle) prevents a great deal of unnecessary wear and coking. Heat cycles is the biggest enemy of the tension pads as they can become brittle and fracture. The tension assembly itself... I have never personally seen a failure. I have seen one that the actuation solenoid failed (shorted out), and I just removed it and put a "used but good" solenoid in its place. To recondition one of these, I simply remove the solenoid, remove all internal parts (plastic piston, spring(s), etc, place in a ultrasonic cleaner with a non-caustic solution, 15 mins later you have a "very" clean housing and internal passages. lightly coat components with oil, reassemble and install. Word of caution with these... when you open your engine up visually inspect the chain and tension assembly before touching anything. Sometimes, (rarely) the large internal spring that provides the main tension force when no oil pressure is commanded/applied by the ECU, becomes weak or fractured, It will be very apparent.
    Also remember that Bank 1 (N205) and Bank 2 (N208) tension assemblies are different from each other and carry different part numbers. don't mix and match.
    Watcher
    Veteran Member Three Rings m_haiser's Avatar
    Apr 24 2011
    Highland Green Allroad
    Oregon Coast
    - - - Updated - - -
    fwiw my plug was an 8mm allen and made of aluminum. and a giant PITA to reach without removing intercooler hose first
    Jan 16 2017
    Seattle/WA
    Quote Originally Posted by m_haiser View Post
    I donít remember what was there originally but it could be that I swapped it for a 10mm bolt as it is much easier to unscrew it that way.
    Jan 16 2017
    Seattle/WA
    Quote Originally Posted by Watcher0691 View Post
    I do!
    Would really appreciate an info on the tensioners rebuild!
    Sep 16 2010
    Central Wash
    Good question!!
    Locking the engine is nice, but I've come down to not even bothering since you can almost NOT get this job done without turning the engine just a bit; either when removing the camshaft to get that extra bit of slack in the chain or when reinstalling.
    And not to nit-pick, you seem very thorough...but whats this about locking camshafts and how does it help? You almost MUST remove the intake cam on bank 1, and there's NO way around it on bank 2. So..how does locking camshafts helps the cam tensioner/ seal/ pad procedure ? For the timing belt part, sure..
    Jan 16 2017
    Seattle/WA
    You have to reinstall the timing belt correctly somehow, right ? Locking is just for that part of the job :)
